Hi all,
I met several cases where the video and sound became laggy after a system update but always solved after reboot(s). But this update caused the sound lost. No sound anymore. I have tried almost every method that I can find, but not helped.
I tried to change from PulseAudio to PipeWire, but there are so many dependencies and conflict packages link each other. It seems difficult to solve.
Need help!
Thanks.
❯ inxi -zv8
Kernel: 6.6.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=9cebd54b-4e71-47fe-bfb7-9667278d87e7 rw quiet splash apparmor=1
Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: Win Element product: S600 v: N/A
serial: <superuser required>
Mobo: Win Element model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.27
date: 10/13/2023
System RAM: total: 32 GiB available: 31.08 GiB used: 6.23 GiB (20.0%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Crucial Technology part-no: CT16G56C46S5.M8G1
serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
serial: <filter>
Info: model: 13th Gen Intel Core i7-1370P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4305
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 3900 min/max: 400/5000:5200:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3900 2: 3900 3: 3900
4: 3900 5: 3900 6: 3900 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900 12: 3900
13: 3900 14: 3900 15: 3900 16: 3900 17: 3900 18: 3900 19: 3900 20: 3900
bogomips: 87580
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: reg_file_data_sampling status: Vulnerable: No microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: disabled;
PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] driver: i915 v: kernel
arch: Xe process: Intel 7 (10nm) built: 2022+ ports: active: HDMI-A-1
empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:a7a0
class-ID: 0300
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-1 model: AOC U27U2G6R4B res: mode: 3840x2160 hz: 60
scale: 100% (1) dpi: 163 size: 600x340mm (23.62x13.39") diag: 690mm (27.15")
modes: N/A
Monitor-2: HDMI-A-1 model: AOC U27U2G6R4B serial: <filter> built: 2023
res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
x: 0.302 y: 0.635 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 3840x2160, 1920x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 30.35 GiB unified: yes display-ID: :1.0
Info: Tools: api: eglinfo,glxinfo wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake-P/U/H cAVS driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca
class-ID: 0403
API: ALSA v: k6.6.94-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.5 status: active with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-4: PulseAudio v: N/A status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
class-ID: 0200
Device-3: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
class-ID: 0200
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0033
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 931.51 GiB used: 301.66 GiB (32.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR411 temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 20.45 GiB (20.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9cebd54b-4e71-47fe-bfb7-9667278d87e7
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 3C4E-F609
ID-3: /home raw-size: 831.22 GiB size: 817.1 GiB (98.30%)
used: 281.21 GiB (34.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 0be234ef-1418-4255-985c-ae1c2d73dd01
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-3: 1-6.1:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-6.1.2:5 info: Logitech MK260 Wireless Combo Receiver
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52e class-ID: 0301
Device-2: 1-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 61.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1432 libs: 390 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0
1: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
2: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
3: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
4: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 409
1: cpu: 5.1% command: com.github.amezin.ddterm started-by: gjs pid: 5872
mem: 89.0 MiB (0.2%)
2: cpu: 3.5% command: chrome pid: 3309 mem: 453.3 MiB (1.4%)
3: cpu: 3.4% command: chrome pid: 5514 mem: 344.3 MiB (1.0%)
4: cpu: 3.1% command: chrome pid: 6070 mem: 111.2 MiB (0.3%)
5: cpu: 2.3% command: WeChatAppEx pid: 2021 mem: 134.4 MiB (0.4%)
Memory top: 5 of 409
1: mem: 831.6 MiB (2.6%) command: Telegram pid: 1413 cpu: 0.1%
2: mem: 537.9 MiB (1.6%) command: chrome pid: 2434 cpu: 2.0%
3: mem: 476.9 MiB (1.4%) command: gnome-shell pid: 1100 cpu: 2.2%
4: mem: 453.3 MiB (1.4%) command: chrome pid: 3309 cpu: 3.5%
5: mem: 344.3 MiB (1.0%) command: chrome pid: 5514 cpu: 3.4%
Processes: 409 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: gsd-power,
tool: systemctl
Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: gjs inxi: 3.3.38
❯ systemctl --user status pulseaudio
× pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: failed (Result: exit-code) since Wed 2025-06-25 10:23:45 CST; 47min ago
Invocation: affbb5870c77442bbdf8009ee1133aa3
TriggeredBy: × pulseaudio.socket
Process: 1839 ExecStart=/usr/bin/pulseaudio --daemonize=no --log-target=journal (code=exit>
Main PID: 1839 (code=exited, status=1/FAILURE)
Jun 25 10:23:45 tiger systemd[979]: pulseaudio.service: Scheduled restart job, restart counter>
Jun 25 10:23:45 tiger systemd[979]: pulseaudio.service: Start request repeated too quickly.
Jun 25 10:23:45 tiger systemd[979]: pulseaudio.service: Failed with result 'exit-code'.
Jun 25 10:23:45 tiger systemd[979]: Failed to start Sound Service.
lines 1-12/12 (END)
