When I use my external DAC over digital output (Toslink) from my mainboard’s soundcard as default device, PulseAudio sometimes just stops playing sound (e.g. music) or sending input (e.g. mic input to Discord) for about 1-4 seconds. This only seems to happen with digital output selected.
Also, KDE’s microphone icon in the taskbar just keeps disappearing randomly for a few milliseconds.
How can I fix this?
pacmd list-sinks (only digital output device)
* index: 2
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 9037
volume: front-left: 64861 / 99% / -0.27 dB, front-right: 64861 / 99% / -0.27 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 7.57 ms
max request: 1 KiB
max rewind: 1 KiB
monitor source: 4
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 2
linked by: 2
configured latency: 7.52 ms; range is 0.50 .. 2000.00 ms
card: 3 <alsa_card.pci-0000_00_1b.0>
module: 9
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC1150 Digital"
alsa.id = "ALC1150 Digital"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "1"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xfb330000 irq 51"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "8d20"
device.product.name = "C610/X99 series chipset HD Audio Controller"
device.string = "iec958:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "iec958-stereo"
device.profile.description = "Digital Stereo (IEC958)"
device.description = "Built-in Audio Digital Stereo (IEC958)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <iec958-stereo-output>
inxi:
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: X99 Extreme4 serial: <filter> UEFI: American Megatrends v: P3.40 date: 06/03/2016
CPU: Info: 6-Core model: Intel Core i7-5930K bits: 64 type: MT MCP arch: Haswell rev: 2 cache: L2: 15 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 84006
Speed: 1660 MHz min/max: 1200/3700 MHz Core speeds (MHz): 1: 1660 2: 1961 3: 1200 4: 1793 5: 3002 6: 1200 7: 1200
8: 3531 9: 1200 10: 3461 11: 3313 12: 1200
Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: ZOTAC driver: nvidia v: 470.63.01 bus-ID: 02:00.0
chip-ID: 10de:2182
Device-2: Logitech BRIO Ultra HD Webcam type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-2:2
chip-ID: 046d:085e
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia resolution: 1: 1920x1080
2: 1920x1080~60Hz s-dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel C610/X99 series HD Audio vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8d20
Device-2: NVIDIA TU116 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 02:00.1
chip-ID: 10de:1aeb
Device-3: RODE Microphones Podcaster type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-12:4
chip-ID: 19f7:0001
Device-4: Logitech BRIO Ultra HD Webcam type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-2:2
chip-ID: 046d:085e
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Ethernet I218-V vendor: ASRock driver: e1000e v: kernel port: f020 bus-ID: 00:19.0
chip-ID: 8086:15a1
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 3.67 TiB used: 1.01 TiB (27.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 950 PRO 512GB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> temp: 33.9 C
ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
ID-3: /dev/sdb vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB speed: 6.0 Gb/s serial: <filter>
ID-4: /dev/sdc vendor: Crucial model: CT525MX300SSD1 size: 489.05 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 463.17 GiB used: 39.24 GiB (8.5%) fs: ext4 dev: /dev/dm-0
mapped: luks-cd30fb77-e732-4a06-b6a7-5469cca30ecf
ID-2: /boot/efi size: 299.4 MiB used: 440 KiB (0.1%) fs: vfat dev: /dev/sdc1
Swap: ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
mapped: luks-21e703d9-f76c-4e28-bb5e-2e4ed9ab2646
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Repos: Packages: 1457 pacman: 1452 flatpak: 5
1: https://mirror.deace.id/manjaro/stable/$repo/$arch
2: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
3: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
Info: Processes: 364 Uptime: 29m Memory: 15.55 GiB used: 3.94 GiB (25.3%) Init: systemd v: 248 Compilers: gcc: 11.1.0
alt: 10 clang: 12.0.1 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
