Sound from the headphones is redirected to the microphone
When I talk to someone, they hear all the sounds from my computer. I tried different settings of alsamixer and nothing helped. My headphones are Sony MDR-ZX600AP. Same problem with intertal micro.
Please post the output of pa-info.
Memory blocks currently allocated: 2, size: 75,4 KiB.
Memory blocks allocated during the whole lifetime: 8563594, size: 2,0 GiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11,5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_00_1f.3.analog-stereo
Default source name: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Memory blocks of type POOL: 2 allocated/6824842 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/1346532 accumulated.
Memory blocks of type IMPORTED: 0 allocated/392220 accumulated.
25 module(s) loaded.
index: 0
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “Lennart Poettering”
module.description = “Automatically restore the volume/mute state of devices”
module.version = “14.0”
index: 1
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Automatically restore the volume/mute/device state of streams”
index: 2
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Automatically restore profile of cards”
index: 3
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Augment the property sets of streams with additional static information”
index: 4
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “David Henningsson”
module.description = “Switches ports and profiles when devices are plugged/unplugged”
index: 5
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Detect available audio hardware and load matching drivers”
index: 6
name:
argument: <device_id=“0” name=“pci-0000_00_1f.3” card_name=“alsa_card.pci-0000_00_1f.3” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”>
used: 0
load once: no
properties:
module.description = “ALSA Card”
index: 7
name:
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = “Adds JACK sink/source ports when JACK is started”
index: 8
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “Frédéric Dalleau, Pali Rohár”
module.description = “Policy module to make using bluetooth devices out-of-the-box easier”
index: 9
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “João Paulo Rechi Vita”
module.description = “Detect available Bluetooth daemon and load the corresponding discovery module”
index: 10
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers”
index: 11
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “Tanu Kaskinen”
module.description = “D-Bus interface”
index: 12
name:
argument: <>
used: -1
load once: no
properties:
module.description = “Native protocol (UNIX sockets)”
index: 13
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “Sylvain Baubeau”
module.description = “GSettings Adapter”
index: 14
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Automatically restore the default sink and source”
index: 15
name:
argument: <>
used: -1
load once: yes
properties:
module.author = “Colin Guthrie”
module.description = “Always keeps at least one sink loaded even if it’s a null one”
index: 16
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Automatically set device of streams based on intended roles of devices”
index: 17
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “When a sink/source is idle for too long, suspend it”
index: 18
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Create a client for each ConsoleKit session of this user”
index: 19
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Create a client for each login session of this user”
index: 20
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Position event sounds between L and R depending on the position on screen of the widget triggering them.”
index: 21
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Mute & cork streams with certain roles while others exist”
index: 22
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Detect when various filters are desirable”
index: 23
name:
argument: <>
used: -1
load once: yes
properties:
module.description = “Load filter sinks automatically when needed”
index: 24
name:
argument: <>
used: -1
load once: no
properties:
module.description = “Command line interface protocol (UNIX sockets)”
1 sink(s) available.
  • index: 0
    driver: <module-alsa-card.c>
    flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
    state: IDLE
    suspend cause: (none)
    priority: 9039
    volume: front-left: 26212 / 40% / -23,88 dB, front-right: 26212 / 40% / -23,88 dB
    balance 0,00
    base volume: 65536 / 100% / 0,00 dB
    volume steps: 65537
    muted: no
    current latency: 1418,44 ms
    max request: 344 KiB
    max rewind: 344 KiB
    monitor source: 0
    Stereo
    used by: 0
    linked by: 0
    configured latency: 2000,00 ms; range is 0,50 … 2000,00 ms
    card: 0 <alsa_card.pci-0000_00_1f.3>
    module: 6
    properties:
    alsa.resolution_bits = “16”
    device.api = “alsa”
    device.class = “sound”
    alsa.class = “generic”
    alsa.subclass = “generic-mix”
    alsa.name = “ALC255 Analog”
    alsa.id = “ALC255 Analog”
    alsa.subdevice = “0”
    alsa.subdevice_name = “subdevice #0
    alsa.device = “0”
    alsa.card = “0”
    alsa.card_name = “HDA Intel PCH”
    alsa.long_card_name = “HDA Intel PCH at 0xef328000 irq 130”
    alsa.driver_name = “snd_hda_intel”
    device.bus_path = “pci-0000:00:1f.3”
    sysfs.path = “/devices/pci0000:00/0000:00:1f.3/sound/card0”
    device.bus = “pci”
    device.vendor.id = “8086”
    device.vendor.name = “Intel Corporation”
    device.product.id = “9d71”
    device.product.name = “Sunrise Point-LP HD Audio”
    device.form_factor = “internal”
    device.string = “front:0”
    device.buffering.buffer_size = “352800”
    device.buffering.fragment_size = “176400”
    device.access_mode = “mmap+timer”
    device.profile.name = “analog-stereo”
    device.profile.description = “Analog Stereo”
    device.description = “Built-in Audio Analog Stereo”
    module-udev-detect.discovered = “1”
    device.icon_name = “audio-card-pci”
    ports:
    analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
    properties:
    device.icon_name = “audio-speakers”
    analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown)
    properties:
    device.icon_name = “audio-headphones”
    active port:
    2 source(s) available.
  • index: 0
    flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
    state: IDLE
    priority: 1030
    volume: front-left: 65364 / 100% / -0,07 dB, front-right: 65364 / 100% / -0,07 dB
    balance 0,00
    volume steps: 65537
    muted: no
    current latency: 0,00 ms
    max rewind: 344 KiB
    Stereo
    used by: 0
    linked by: 0
    monitor_of: 0
    module: 6
    properties:
    device.description = “Monitor of Built-in Audio Analog Stereo”
    device.class = “monitor”
    alsa.card = “0”
    device.bus = “pci”
    device.string = “0”
    index: 1
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9039
    volume: front-left: 32589 / 50% / -18,20 dB, front-right: 32589 / 50% / -18,20 dB
    balance 0,00
    base volume: 6554 / 10% / -60,00 dB
    volume steps: 65537
    muted: no
    max rewind: 0 KiB
    Stereo
    used by: 0
    linked by: 0
    configured latency: 0,00 ms; range is 0,50 … 2000,00 ms
    module: 6
    properties:
    device.api = “alsa”
    alsa.device = “0”
    alsa.card = “0”
    device.bus = “pci”
    ports:
    analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
    properties:
    device.icon_name = “audio-input-microphone”
    analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: unknown)
    properties:
    active port:
    6 client(s) logged in.
    index: 0
    driver: <module-systemd-login.c>
    owner module: 19
    properties:
    application.name = “Login Session 2”
    systemd-login.session = “2”
    index: 1
    driver: <protocol-native.c>
    owner module: 12
    properties:
    application.name = “libcanberra”
    native-protocol.peer = “UNIX socket client”
    native-protocol.version = “34”
    application.version = “0.30”
    application.id = “org.freedesktop.libcanberra”
    application.process.id = “1182”
    application.process.user = “tytcoh”
    application.process.host = “tyt-pc”
    application.process.binary = “plasmashell”
    application.language = “en_US.UTF-8”
    window.x11.display = “:0”
    application.process.machine_id = “ba96bf4087f74eeda66d05f4d2331fb7”
    application.process.session_id = “2”
    index: 2
    owner module: 12
    properties:
    application.name = “QPulse”
    index: 3
    owner module: 12
    properties:
    application.process.id = “1207”
    application.process.binary = “kdeconnectd”
    index: 11
    owner module: 12
    properties:
    application.process.id = “4006”
    application.process.binary = “systemsettings5”
    index: 32
    driver: <cli.c>
    owner module: 24
    properties:
    application.name = “UNIX socket client”
    1 card(s) available.
    index: 0
    owner module: 6
    properties:
    alsa.card = “0”
    device.bus = “pci”
    device.string = “0”
    device.description = “Built-in Audio”
    profiles:
    input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
    output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
    output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
    output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
    output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
    output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
    output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
    output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
    output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
    output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
    output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
    output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
    output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
    output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
    output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
    output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
    output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
    output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
    output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
    output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
    output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
    output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
    output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
    output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
    output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
    output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
    output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
    off: Off (priority 0, available: unknown)
    active profile: output:analog-stereo+input:analog-stereo
    sinks:
    alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
    sources:
    alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
    alsa_input.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
    ports:
    properties:
    properties:
    properties:
    properties:
    hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
    properties:
    device.icon_name = “video-display”
    hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
    properties:
    hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
    properties:
    hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
    properties:
    hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
    properties:
    0 sink input(s) available.
    0 source output(s) available.
    1 cache entrie(s) available.
    name:
    index: 0
    Stereo
    length: 11776
    duration: 0,1 s
    volume: n/a
    balance 0,00
    lazy: no
    filename: <n/a>
    properties:
    media.role = “event”
    event.id = “audio-volume-change”
    event.description = “Volume Control Feedback Sound”
    media.name = “audio-volume-change”
    media.filename = “/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga”
That doesn’t seem to be the entire output. And please use the preformatted text option (</> icon, or Ctrl+Shift+C) when posting the output of programs.
Memory blocks currently allocated: 3, size: 85,9 KiB.
Memory blocks allocated during the whole lifetime: 12777942, size: 1,9 GiB.
Total sample cache size: 21,9 KiB.
Memory blocks of type POOL: 3 allocated/9951506 accumulated.
Memory blocks of type FIXED: 0 allocated/2082446 accumulated.
Memory blocks of type IMPORTED: 0 allocated/743990 accumulated.
index: 0
name:
argument: <>
used: -1
load once: yes
properties:
index: 1
name:
argument: <>
used: -1
load once: yes
properties:
index: 2
name:
argument: <>
used: -1
load once: yes
properties:
index: 3
name:
argument: <>
used: -1
load once: yes
properties:
index: 4
name:
argument: <>
used: -1
load once: yes
properties:
index: 5
name:
argument: <>
used: -1
load once: yes
properties:
index: 6
name:
used: 0
load once: no
properties:
index: 7
name:
used: -1
load once: yes
properties:
index: 8
name:
argument: <>
used: -1
load once: yes
properties:
index: 9
name:
argument: <>
used: -1
load once: yes
properties:
index: 10
name:
argument: <>
used: -1
load once: yes
properties:
index: 11
name:
argument: <>
used: -1
load once: yes
properties:
index: 12
name:
argument: <>
used: -1
load once: no
properties:
index: 13
name:
argument: <>
used: -1
load once: yes
properties:
index: 14
name:
argument: <>
used: -1
load once: yes
properties:
index: 15
name:
argument: <>
used: -1
load once: yes
properties:
index: 16
name:
argument: <>
used: -1
load once: yes
properties:
index: 17
name:
argument: <>
used: -1
load once: yes
properties:
index: 18
name:
argument: <>
used: -1
load once: yes
properties:
index: 19
name:
argument: <>
used: -1
load once: yes
properties:
index: 20
name:
argument: <>
used: -1
load once: yes
properties:
index: 21
name:
argument: <>
used: -1
load once: yes
properties:
index: 22
name:
argument: <>
used: -1
load once: yes
properties:
index: 23
name:
argument: <>
used: -1
load once: yes
properties:
index: 24
name:
argument: <>
used: -1
load once: no
properties:
  • index: 0
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9039
    volume: front-left: 40177 / 61% / -12,75 dB, front-right: 40177 / 61% / -12,75 dB
    balance 0,00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 0
    sample spec: s16le 2ch 48000Hz
    Stereo
    used by: 0
    linked by: 0
    configured latency: 0,00 ms; range is 0,50 … 1837,50 ms
    module: 6
    properties:
    device.api = “alsa”
    alsa.device = “0”
    alsa.card = “0”
    device.bus = “pci”
    ports:
    analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
    properties:
    analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
    properties:
    active port:
  • index: 0
    state: SUSPENDED
    suspend cause: IDLE
    priority: 1030
    balance 0,00
    volume steps: 65537
    muted: no
    max rewind: 0 KiB
    Stereo
    used by: 0
    linked by: 0
    monitor_of: 0
    module: 6
    properties:
    alsa.card = “0”
    device.bus = “pci”
    device.string = “0”
    index: 1
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9039
    balance 0,00
    volume steps: 65537
    muted: no
    max rewind: 0 KiB
    Stereo
    used by: 0
    linked by: 0
    module: 6
    properties:
    device.api = “alsa”
    alsa.device = “0”
    alsa.card = “0”
    device.bus = “pci”
    ports:
    properties:
    analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: no)
    properties:
    active port:
    index: 0
    owner module: 19
    properties:
    index: 1
    owner module: 12
    properties:
    index: 2
    owner module: 12
    properties:
    index: 3
    owner module: 12
    properties:
    index: 285
    owner module: 12
    properties:
    application.name = “KDE Power Management System”
    application.id = “org.kde.org_kde_powerdevil”
    application.icon_name = “”
    application.process.id = “1244”
    application.process.binary = “org_kde_powerdevil”
    index: 286
    driver: <cli.c>
    owner module: 24
    properties:
    index: 0
    owner module: 6
    properties:
    alsa.card = “0”
    device.bus = “pci”
    device.string = “0”
    profiles:
    sinks:
    sources:
    ports:
    properties:
    properties:
    properties:
    properties:
    properties:
    properties:
    properties:
    properties:
    properties:
    2 cache entrie(s) available.
    name:
    index: 0
    Stereo
    length: 11776
    duration: 0,1 s
    volume: n/a
    balance 0,00
    lazy: no
    filename: <n/a>
    properties:
    name:
    index: 1
    Stereo
    length: 10696
    duration: 0,1 s
    volume: n/a
    balance 0,00
    lazy: no
    filename: <n/a>
    properties:
    event.description = “Message dialog shown”
    event.id = “dialog-information”
    media.name = “dialog-information”
    media.filename = “/usr/share/sounds/freedesktop/stereo/dialog-information.oga”
    application.name = “Sublime Text”
    window.x11.screen = “0”
    application.process.id = “10925”
    application.process.binary = “sublime_text”
    application.icon_name = “sublime-text”
This is the output of pacmd info.
PulseAudio data is showing 2 source(s) available for audio capture
The default source used by any software package is marked with an asterisk
 * index: 0
This is the audio sink output monitor, for capturing audio played to headphones
Audio input from the microphone is the non-default source
   index: 1
So I suggest you change the default-source with this command
pacmd set-default-source alsa_input.pci-0000_00_1f.3.analog-stereo
PulseAudio GUI controls do not usually show default sink and source (except for pasystray)
but defaults can be checked with this command
pacmd dump | grep default
