Hello i just installed Manjaro Xfce, and this is my first time to use Linux os.
after the installation, the sound doesn’t work. what can i do ?
and this is the output of inxi -Fazy
> Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
> root=UUID=5e613210-0c3c-4cbb-8d5d-fce9ad4ac476 rw quiet apparmor=1
> security=apparmor resume=UUID=861a5a96-5795-46e8-ae94-35df54f0c97a
> udev.log_priority=3
> Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
> dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Convertible System: HP product: HP Pavilion x360 Convertible 14-dh1xxx
> v: Type1ProductConfigId serial: <filter> Chassis: type: 31 serial: <filter>
> Mobo: HP model: 8670 v: 90.08 serial: <filter> UEFI: Insyde v: F.09
> date: 11/11/2020
> Battery:
> ID-1: BAT0 charge: 8.0 Wh (20.4%) condition: 39.2/39.2 Wh (100.0%)
> volts: 10.7 min: 11.3 model: 333-1C-3B-A HT03041XL type: Li-ion
> serial: <filter> status: Discharging
> Device-1: hid-0018:04F3:23DD.0002-battery model: ELAN2514:00 04F3:23DD
> serial: N/A charge: N/A status: N/A
> CPU:
> Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
> arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
> microcode: DE cache: L2: 8 MiB
> flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> bogomips: 36799
> Speed: 512 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 512 2: 543 3: 585
> 4: 516 5: 547 6: 542 7: 549 8: 530
> Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass
> mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1
> mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
> Type: srbds mitigation: TSX disabled
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel
> bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
> Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
> driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
> chip-ID: 10de:1d13 class-ID: 0302
> Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
> type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 05c8:03d3 class-ID: 0e02
> Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia
> unloaded: intel,nouveau alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1
> Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
> s-diag: 485mm (19.1")
> Monitor-1: eDP-1 res: 1600x900 dpi: 132 size: 309x174mm (12.2x6.9")
> diag: 355mm (14")
> OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.2
> direct render: Yes
> Audio:
> Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
> driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
> bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
> Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
> Sound Server-2: JACK v: 0.125.0 running: no
> Sound Server-3: PulseAudio v: 14.2 running: yes
> Sound Server-4: PipeWire v: 0.3.25 running: no
> Network:
> Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
> vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
> port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
> IF: wlo1 state: up mac: <filter>
> Bluetooth:
> Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
> bus-ID: 1-10:5 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
> Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
> rfk-block: hardware: no software: yes address: see --recommends
> RAID:
> Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
> v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: class-ID: 0104
> Drives:
> Local Storage: total: 1.14 TiB used: 11.44 GiB (1.0%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 238.47 GiB
> block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
> rotation: SSD serial: <filter> rev: ADHA0102 temp: 42.9 C scheme: GPT
> ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0
> size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
> rotation: 5400 rpm serial: <filter> rev: 1A04 scheme: GPT
> Partition:
> ID-1: / raw-size: 70.12 GiB size: 68.46 GiB (97.64%) used: 11.44 GiB (16.7%)
> fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
> ID-2: /boot/efi raw-size: 900 MiB size: 898.2 MiB (99.80%)
> used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
> Swap:
> Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
> ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
> dev: /dev/nvme0n1p6 maj-min: 259:6
> Sensors:
> System Temperatures: cpu: 46.0 C mobo: 41.0 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 248 Uptime: 14m wakeups: 3 Memory: 15.34 GiB
> used: 2.63 GiB (17.2%) Init: systemd v: 247 tool: systemctl Compilers:
> gcc: 10.2.0 Packages: 1131 pacman: 1121 lib: 328 flatpak: 10 Shell: Bash
> v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.04
thank you in advance
