systemctl enable pulseaudio.service pulseaudio.socket
Failed to enable unit: Unit file pulseaudio.service does not exist.
systemctl --user status pulseaudio.service pulseaudio.socket
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; preset: enabled)
Active: active (running) since Sun 2022-12-18 18:19:34 CST; 26min ago
TriggeredBy: ● pulseaudio.socket
Main PID: 758 (pulseaudio)
Tasks: 12 (limit: 18927)
Memory: 20.1M
CPU: 1.938s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
├─758 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─963 /usr/lib/pulse/gsettings-helper
12月 18 18:19:33 lucifer systemd[749]: Starting Sound Service...
12月 18 18:19:34 lucifer pulseaudio[758]: Path Capture is not a volume or mute control
12月 18 18:19:34 lucifer pulseaudio[758]: module-combine is deprecated: Please use module-combine-sink ins>
12月 18 18:19:34 lucifer pulseaudio[758]: We will now load module-combine-sink. Please make sure to remove>
12月 18 18:19:34 lucifer systemd[749]: Started Sound Service.
12月 18 18:19:34 lucifer pulseaudio[758]: Could not find org.bluez.BatteryProviderManager1.RegisterBattery>
● pulseaudio.socket - Sound System
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: enabled)
Active: active (running) since Sun 2022-12-18 18:19:33 CST; 26min ago
Until: Sun 2022-12-18 18:19:33 CST; 26min ago
Triggers: ● pulseaudio.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
12月 18 18:19:33 lucifer systemd[749]: Listening on Sound System.
If you want more information just post command.Thanks in advance.
