Hello,
I had this problem with a previous kernel, switched back to a lower one, waited for the next kernel to come and the sound worked. I now have the same problem with 5.13 and would like to know why and rectify the problem.
cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xdf340000 irq 154
Please, help.
Thankl you!
P.S. The sound works in 5.13 and the previous kernel, but does not always. A restart of the system usually solves the problem.
Fabby
July 19, 2021, 8:02am
2
Welcome to Manjaro!
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the trees for the wood any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Then file a bug upstream or keep using 5.10 LTS instead of using the latest (but not always greatest) stable kernels… (which is what I do)
system
Closed
August 3, 2021, 8:03am
3
