Hi! I recently installed manjaro-pipewire and been using it for a while (3 weeks~). But, since last week, sound icon at the bottom right shows “muted” icon and when I click on it there is no device. (No input nor output) I couldn’t find a reason for why does it happen randomly. (I mean sometimes it works just normal but most of the time I have to reboot a few times.) Thanks in advance.
Tem 01 15:15:02 ALPER-MANJARO kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Tem 01 15:15:02 ALPER-MANJARO kernel: #5 #6 #7
Tem 01 15:15:02 ALPER-MANJARO kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Tem 01 15:15:02 ALPER-MANJARO kernel: pnp 00:03: disabling [io 0x3322-0x3323] because it overlaps 0000:00:1d.6 BAR 13 [io 0x3000-0x3fff]
Tem 01 15:15:02 ALPER-MANJARO kernel: hpet_acpi_add: no address or irqs in _CRS
Tem 01 15:15:02 ALPER-MANJARO kernel: usb: port power management may be unreliable
Tem 01 15:15:02 ALPER-MANJARO kernel: vboxdrv: loading out-of-tree module taints kernel.
Tem 01 15:15:02 ALPER-MANJARO kernel: VBoxNetAdp: Successfully started.
Tem 01 15:15:02 ALPER-MANJARO kernel: VBoxNetFlt: Successfully started.
Tem 01 15:15:03 ALPER-MANJARO systemd-journald[306]: File /var/log/journal/267e08f7bada43b6affc1101c8bec101/system.journal corrupted or uncleanly shut down, renaming and replacing.
Tem 01 15:15:03 ALPER-MANJARO kernel: r8168 Copyright (C) 2021 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Tem 01 15:15:03 ALPER-MANJARO kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-72.ucode failed with error -2
Tem 01 15:15:03 ALPER-MANJARO kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Tem 01 15:15:04 ALPER-MANJARO kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Tem 01 15:15:05 ALPER-MANJARO NetworkManager[468]: <warn> [1656677705.5409] device (wlp0s20f3): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Tem 01 15:15:06 ALPER-MANJARO kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Tem 01 15:15:07 ALPER-MANJARO kernel: nvidia: module license 'NVIDIA' taints kernel.
Tem 01 15:15:07 ALPER-MANJARO kernel: Disabling lock debugging due to kernel taint
Tem 01 15:15:07 ALPER-MANJARO kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.48.07 Fri May 27 03:26:43 UTC 2022
Tem 01 15:15:09 ALPER-MANJARO kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20211217/nsarguments-61)
Tem 01 15:15:10 ALPER-MANJARO kernel: kauditd_printk_skb: 52 callbacks suppressed
Tem 01 15:15:10 ALPER-MANJARO sddm-helper[722]: gkr-pam: no password is available for user
Tem 01 15:15:10 ALPER-MANJARO NetworkManager[468]: <warn> [1656677710.8098] device (wlp0s20f3): no secrets: No agents were available for this request.
Tem 01 15:15:10 ALPER-MANJARO NetworkManager[468]: <warn> [1656677710.8102] device (wlp0s20f3): Activation: failed for connection 'Tenda_075BF8'
Tem 01 15:15:10 ALPER-MANJARO systemd-xdg-autostart-generator[730]: Configuration file /home/alper/.config/autostart/org.moson.matray.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Tem 01 15:15:10 ALPER-MANJARO systemd-xdg-autostart-generator[730]: Configuration file /home/alper/.config/autostart/io.optimus_manager.OptimusManagerQt.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Tem 01 15:15:10 ALPER-MANJARO systemd-xdg-autostart-generator[730]: /home/alper/.config/autostart/Turn On GSync.desktop: not generating unit, error parsing Exec= line: No such file or directory
Tem 01 15:15:10 ALPER-MANJARO sddm-helper[722]: gkr-pam: couldn't unlock the login keyring.
Tem 01 15:15:11 ALPER-MANJARO systemd-xdg-autostart-generator[765]: Configuration file /home/alper/.config/autostart/org.moson.matray.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Tem 01 15:15:11 ALPER-MANJARO systemd-xdg-autostart-generator[765]: Configuration file /home/alper/.config/autostart/io.optimus_manager.OptimusManagerQt.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Tem 01 15:15:11 ALPER-MANJARO systemd-xdg-autostart-generator[765]: /home/alper/.config/autostart/Turn On GSync.desktop: not generating unit, error parsing Exec= line: No such file or directory
Tem 01 15:15:11 ALPER-MANJARO klauncher[783]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Tem 01 15:15:11 ALPER-MANJARO kcminit_startup[789]: QDBusConnection: error: could not send signal to service "" path "//home/alper/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/alper/.kde4/share/config/kdeglobals
Tem 01 15:15:11 ALPER-MANJARO kwin_x11[800]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Tem 01 15:15:11 ALPER-MANJARO kwin_x11[800]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Tem 01 15:15:11 ALPER-MANJARO kwin_x11[800]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Tem 01 15:15:12 ALPER-MANJARO ksmserver[840]: Qt: Session management error: networkIdsList argument is NULL
Tem 01 15:15:12 ALPER-MANJARO kded5[797]: kf.coreaddons: "Could not load plugin from colord: The shared library was not found."
Tem 01 15:15:12 ALPER-MANJARO kded5[797]: kf.kded: found kded module "colord" by prepending 'kded_' to the library path, please fix your metadata.
Tem 01 15:15:12 ALPER-MANJARO kded5[797]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
Tem 01 15:15:12 ALPER-MANJARO plasma_session[777]: org.kde.plasma.session: failed to parse "/home/alper/.config/autostart/Turn On GSync.desktop" for autostart
Tem 01 15:15:12 ALPER-MANJARO kded5[797]: "/home/alper/.local/share/icc/." is not an ICC profile
Tem 01 15:15:12 ALPER-MANJARO kded5[797]: "/home/alper/.local/share/icc/.." is not an ICC profile
Tem 01 15:15:12 ALPER-MANJARO kernel: ntfs3: Unknown parameter 'windows_names'
Tem 01 15:15:12 ALPER-MANJARO plasmashell[856]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Tem 01 15:15:12 ALPER-MANJARO plasmashell[856]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Tem 01 15:15:12 ALPER-MANJARO kwin_x11[800]: kwin_core: XCB error: 10 (BadAccess), sequence: 827, resource id: 1991, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Tem 01 15:15:12 ALPER-MANJARO org_kde_powerdevil[855]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Tem 01 15:15:12 ALPER-MANJARO xdg-desktop-por[901]: Failed connect to PipeWire: Couldn't connect to PipeWire
Tem 01 15:15:12 ALPER-MANJARO baloo_file[852]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.26'
Tem 01 15:15:13 ALPER-MANJARO org_kde_powerdevil[855]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Tem 01 15:15:13 ALPER-MANJARO org_kde_powerdevil[855]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Tem 01 15:15:13 ALPER-MANJARO kded5[797]: "/home/alper/.local/share/icc/." is not an ICC profile
Tem 01 15:15:13 ALPER-MANJARO kded5[797]: "/home/alper/.local/share/icc/.." is not an ICC profile
Tem 01 15:15:13 ALPER-MANJARO kded5[797]: EDID ICC Profile already exists "/home/alper/.local/share/icc/edid-453da0f15e5d9f0230b19da7a2c71171.icc"
Tem 01 15:15:13 ALPER-MANJARO kded5[797]: Failed to register device: "device id 'xrandr-BOE' already exists"
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "kontact.desktop" QSharedPointer(0x565258657550)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5652586d4140)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "kontact.desktop" QSharedPointer(0x565258749c70)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5652586d4270)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "kontact.desktop" QSharedPointer(0x565257cdbbb0)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56525877eb50)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "kontact.desktop" QSharedPointer(0x56525877bfa0)
Tem 01 15:15:13 ALPER-MANJARO plasmashell[856]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56525877ec80)
Tem 01 15:15:14 ALPER-MANJARO pipewire-media-session[1052]: ms.core: can't start monitor: Host is down
Tem 01 15:15:14 ALPER-MANJARO systemd[724]: pipewire-media-session.service: Failed with result 'exit-code'.
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Tem 01 15:15:14 ALPER-MANJARO systemd[724]: pipewire-media-session.service: Failed to schedule restart job: Unit pipewire.socket is masked.
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Tem 01 15:15:14 ALPER-MANJARO bluetoothd[605]: Failed to set mode: Failed (0x03)
Tem 01 15:15:14 ALPER-MANJARO kded5[797]: kf.bluezqt: PendingCall Error: "Failed"
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Tem 01 15:15:14 ALPER-MANJARO kwin_x11[800]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2607, resource id: 4194347, major code: 18 (ChangeProperty), minor code: 0
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Tem 01 15:15:14 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/PopupDialog.qml:138: TypeError: Cannot call method 'destroy' of null
Tem 01 15:15:15 ALPER-MANJARO plasmashell[856]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Tem 01 15:15:15 ALPER-MANJARO plasmashell[856]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Tem 01 15:15:15 ALPER-MANJARO plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Tem 01 15:15:15 ALPER-MANJARO plasmashell[856]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Tem 01 15:15:16 ALPER-MANJARO plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Tem 01 15:15:16 ALPER-MANJARO plasmashell[856]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Tem 01 15:15:18 ALPER-MANJARO plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Tem 01 15:15:21 ALPER-MANJARO kwin_x11[800]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6200, resource id: 48234654, major code: 18 (ChangeProperty), minor code: 0
Tem 01 15:15:21 ALPER-MANJARO plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Tem 01 15:15:24 ALPER-MANJARO kernel: kauditd_printk_skb: 14 callbacks suppressed
Tem 01 15:15:30 ALPER-MANJARO plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Tem 01 15:15:57 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Tem 01 15:15:57 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: device [8086:06b6] error status/mask=00001000/00002000
Tem 01 15:15:57 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: [12] Timeout
Tem 01 15:17:09 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Tem 01 15:17:09 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: device [8086:06b6] error status/mask=00001000/00002000
Tem 01 15:17:09 ALPER-MANJARO kernel: pcieport 0000:00:1d.6: [12] Timeout
Tem 01 15:17:49 ALPER-MANJARO kstart5[1704]: Omitting both --window and --windowclass arguments is not recommended
Tem 01 15:17:49 ALPER-MANJARO kwin_x11[800]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56922, resource id: 77594633, major code: 18 (ChangeProperty), minor code: 0
Tem 01 15:18:15 ALPER-MANJARO kstart5[1813]: Omitting both --window and --windowclass arguments is not recommended
Tem 01 15:18:15 ALPER-MANJARO kwin_x11[800]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63092, resource id: 79691785, major code: 18 (ChangeProperty), minor code: 0
