Sometimes when i start my pc, Manjaro stops during boot and only resumes when i press enter. This is especially a problem if it happens when i’m starting the pc remotely with wake-on-lan, which makes it unusable until i’m at home to to fix it. I’ve checked the kernel log and i believe there is some fsck error that could be causing this. Is there some way to make it not wait for user input ?
A part of the kernel log is below. Around 16:15 is when it started booting and 17:14 is when i came home to press the key to resume booting.
Oct 12 16:15:43 mp-um350 systemd[1]: First Boot Complete skipped, unmet condition check ConditionFirstBoot=yes
Oct 12 16:15:43 mp-um350 systemd[1]: Rebuild Journal Catalog skipped, unmet condition check ConditionNeedsUpdate=/var
Oct 12 16:15:43 mp-um350 systemd[1]: Save Transient machine-id to Disk skipped, unmet condition check ConditionPathIsMountPoint=/etc/machine-id
Oct 12 16:15:43 mp-um350 systemd[1]: Update is Completed skipped, no trigger condition checks were met.
Oct 12 16:15:43 mp-um350 systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Oct 12 16:15:43 mp-um350 systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Oct 12 16:15:43 mp-um350 kernel: Bluetooth: hci0: Intel BT fw patch 0x43 completed & activated
Oct 12 16:15:48 mp-um350 systemd[1]: systemd-rfkill.service: Deactivated successfully.
Oct 12 16:21:05 mp-um350 kernel: EXT4-fs (sda3): error count since last fsck: 9
Oct 12 16:21:05 mp-um350 kernel: EXT4-fs (sda3): initial error at time 1777319432: __ext4_get_inode_loc_noinmem:4954: inode 26900763: block 107481009
Oct 12 16:21:05 mp-um350 kernel: EXT4-fs (sda3): last error at time 1777319433: ext4_journal_check_start:87
Oct 12 17:14:10 mp-um350 systemd[1]: plymouth-start.service: start-post operation timed out. Terminating.
Oct 12 17:14:10 mp-um350 systemd[1]: plymouth-start.service: Failed with result 'timeout'.
Oct 12 17:14:10 mp-um350 systemd[1]: Failed to start Show Plymouth Boot Screen.
Oct 12 17:14:10 mp-um350 systemd[1]: Dispatch Password Requests to Console Directory Watch skipped, unmet condition check ConditionPathExists=!/run/plymouth/pid
Oct 12 17:14:10 mp-um350 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
