Hello,
As described in the title, sometimes my computer reboot instead of sleeping. I don’t find why. I expected it to be solved with my suspend problem, but actually not. It seems it is two different things.
If needed :
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=0423bfc7-2401-4c0d-aff1-d445732fd0ba rw rootflags=subvol=@ quiet
cryptdevice=UUID=0601a8bf-665e-43b5-a183-1a9cc8d83bc4:luks-0601a8bf-665e-43b5-a183-1a9cc8d83bc4
root=/dev/mapper/luks-0601a8bf-665e-43b5-a183-1a9cc8d83bc4
resume=/dev/mapper/luks-fcec610d-0b7b-4609-9fe0-be9508822a57
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Notebook product: <filter> v: N/A serial: <filter>
Chassis: No Enclosure type: 10 serial: <filter>
Mobo: Notebook model: <filter> serial: <filter> UEFI: American Megatrends
v: 5.12 date: 11/01/2017
ID-1: BAT0 charge: 36.8 Wh (100.0%) condition: 36.8/45.3 Wh (81.3%)
volts: 17.2 min: 15.1 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 3.72 GiB used: 2.44 GiB (65.6%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 1525
3: 1042 4: 1011 5: 800 6: 792 7: 700 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b59e class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f040
bus-ID: 01:00.0 chip-ID: 8086:2526 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: e000 bus-ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-5:2 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: luks-bca40e75-a646-43ce-94bf-baa9e8465544 maj-min: 254:2
type: LUKS dm: dm-2 size: 931.51 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 931.51 GiB
Device-2: luks-0601a8bf-665e-43b5-a183-1a9cc8d83bc4 maj-min: 254:0
type: LUKS dm: dm-0 size: 102.71 GiB
Components:
p-1: sdb2 maj-min: 8:18 size: 102.71 GiB
Device-3: luks-fcec610d-0b7b-4609-9fe0-be9508822a57 maj-min: 254:1
type: LUKS dm: dm-1 size: 8.79 GiB
Components:
p-1: sdb3 maj-min: 8:19 size: 8.79 GiB
Local Storage: total: 1.02 TiB used: 424.33 GiB (40.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-00Z10T0
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS120G2G0B-00EPW0 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: GPT
ID-1: / raw-size: 102.71 GiB size: 102.71 GiB (100.00%)
used: 14.22 GiB (13.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0601a8bf-665e-43b5-a183-1a9cc8d83bc4 label: root
uuid: 0423bfc7-2401-4c0d-aff1-d445732fd0ba
used: 712 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: BOOT
uuid: 94E5-C199
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 409.89 GiB (44.0%) fs: btrfs dev: /dev/dm-2 maj-min: 254:2
mapped: luks-bca40e75-a646-43ce-94bf-baa9e8465544 label: home
uuid: b21ad208-5212-46c6-a90b-ebf8a9be1460
ID-4: /run/timeshift/backup raw-size: 102.71 GiB size: 102.71 GiB (100.00%)
ID-5: /var/cache raw-size: 102.71 GiB size: 102.71 GiB (100.00%)
ID-6: /var/log raw-size: 102.71 GiB size: 102.71 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.79 GiB used: 225.8 MiB (2.5%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-fcec610d-0b7b-4609-9fe0-be9508822a57 label: swap
uuid: 044553cb-9ce4-41c0-9d95-b5f54a38361d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 1-6:3 info: Chicony Chicony USB2.0 Camera type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 335 Uptime: 2h 53m wakeups: 426 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1332 pacman: 1325 lib: 345
flatpak: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Thanks
