Change permissions of a USB hard drive
Hello everyone,
I needed to reformat my USB hard drive and used gparted to do this. The owner is now root. I myself would like to be the owner with read and write permissions. I can’t manage to change that!
What filesystem did you create on your USB hdd ?
I created ext4
Gparted hast nothing to do with this.
  • The owner of a file on a ext4 filesystem is set, when the file is created.
    So create any directory / file on it, then change the owner to yourself.
  • The owner of the “root=/” of your ext4 filesystem is the owner of its mountpoint
    So change the ownership of the mountpoint to yourself
There is a [HowTo] about this, but i did not find it yet. :man_shrugging:
maybe [root tip] [How To] Mount partition using fstab
sudo chown -R $USER:$USER [path/to/device]
It doesn’t work. :innocent:I did:
sudo chown -R root:micha /run/media/micha/
XY problem. Read the tutorials I posted. :wink:
Wrong Command should be sudo chown -R micha:micha /run/media/micha/
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
