Golfy
13 October 2024 14:27
1
It’s happen after long time idle (near one hour), my laptop (with hybrid graphic card intel/nvidia) seems to be awake with desktop but… I can’t click anywhere: applications and taskbar are frozen.
My workaround is to open a VTY with [Alt]+[Shift]+[F3] , login then launching htop (with column ‘command’ and tree view) and kill (-7) kwin_x11
kwin_x11 is automaticaly restarted (I’ve to go back to [Alt]+[Shift]+[F2] ) and I could close my documents before a restart (I don’t want to continue a strange session).
Does someone has the same problem? Are they others solutions?
I’ve cleaned kde cache, update system, etc.
Problem is there since kde6 (and I’m not an expert of log files that could help for troubleshooting this)
The same happened to me. When I turned off the display and slept overnight, the screen got stuck when I turned it on the next day. I had to restart kwin_x11 to continue using it. This was very frustrating for me.
@Golfy
@ilovesusu
Does this also happen when using Wayland?
Golfy
14 October 2024 05:58
4
I can’t use wayland because nvidia issue with second screen (HDMI output isn’t seen).
Linux sound like to be stable and fun, but without second screen, without nvidia, without KDE
Humor appart, I’m trying to understand why and how this happens to open a ticket at nvidia or kde support: but I’m not enough experimented to know where to search…
Instead of killing kwin_x11
, try the following command which is the correct way to restart Plasma 6 without closing your open apps:
kquitapp6 plasmashell; kstart plasmashell
The output of inxi -zv8
& error logs would be quite helpful in diagnosing what is causing the session freezes.
Golfy:
Possibly you can change the settings on the monitor itself. Some monitors apparently default to auto – you might be able to change that to see if magic happens.
Good luck.
Golfy
14 October 2024 06:39
7
It’s more complex: [HowTo] Use Wayland with proprietary NVIDIA drivers
I remember manjaro team have to reverse back to an older nvidia driver to avoid a bug (from Nvidia).
Ah yes, Nvidia… always Nvidia. I suppose I was fortunate in choosing AMD graphics. So many seem to have a wide range of issues with Nvidia/Wayland combinations.
I’ve been using an RX 580 with Wayland for about a year without any issues. All I can do is wish you luck.
Cheers.
Kobold
14 October 2024 14:59
9
Yeah more experimental setup’s has more problems.
But using Manjaro KDE on a single GPU with a single Monitor.
Is a solid experience.
I read somewhere that nvidia has energy saving problem’s.
Is this a option for you to disable this feature?
I can power off and on my Monitor connected with Display Port on my PC with my nvidia card under KDE without problems. But if this is related to HDMI or a dual GPU issue or dual Monitor issue? IDK
Golfy
20 October 2024 18:49
10
scotty65:
inxi -zv8
Hi @scotty65 !
I’ve tried tonight your solution (kquitapp6 plasmashell
), but it doesn’t work. An error message said:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: from 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
A killed again x11 and it went back but without menu bar, I’ve had to write kstart plasmashell
in a previously console.
Golfy
20 October 2024 18:51
11
by the way, here is my inxi -zv8 :
Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=dca8cecc-c26f-4f8b-b39c-1a12c8ae0445 rw quiet apparmor=1
security=apparmor resume=UUID=d97779d9-142d-430d-b9c0-e61a86feea80
udev.log_priority=3 sysrq_always_enabled=1 nvidia_drm.modeset=0
nvidia_drm.fbdev=0
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: Dell product: G7 7700 v: N/A
serial: <superuser required> Chassis: type: 10
Mobo: Dell model: 0M7GYR v: A00 serial: <superuser required>
part-nu: 09F9 uuid: <superuser required> UEFI: Dell v: 1.33.0
date: 06/03/2024
ID-1: BAT0 charge: 82.4 Wh (100.0%) condition: 82.4/97.0 Wh (84.9%)
volts: 12.6 min: 11.4 model: BYD DELL XYCW01A type: Li-poly
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX
Anywhere 2S serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.39 GiB used: 10.8 GiB (70.2%)
Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: 80CE00000000 part-no: M471A1K43DB1-CWE
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB speed:
serial: <filter>
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4369 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 4369 2: 4369 3: 4369 4: 4369 5: 4369 6: 4369
7: 4369 8: 4369 9: 4369 10: 4369 11: 4369 12: 4369 bogomips: 62431
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
ibrs ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled
via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM:
SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
chip-ID: 0bda:565a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1182x285mm (46.54x11.22")
s-diag: 1216mm (47.87")
Monitor-1: HDMI-1-0 pos: primary,left res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 144 dpi: 128
size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa
v: 24.2.4-arch1.0.1 glx-v: 1.4 direct-render: yes renderer: Mesa Intel
UHD Graphics (CML GT2) device-ID: 8086:9bc4 memory: 7.51 GiB
unified: yes
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.120
device-ID: 10de:1f15 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel
v: 24.2.4-arch1.0.1 device-ID: 8086:9bc4 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Dell driver: r8168 v: 8.053.00-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.38 TiB used: 921.34 GiB (65.4%)
model: WDBRPG0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Toshiba model: KBG40ZNS512G
NVMe KIOXIA 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 10410106 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 914.28 GiB size: 898.86 GiB (98.31%)
used: 618.76 GiB (68.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: dca8cecc-c26f-4f8b-b39c-1a12c8ae0445
used: 28.4 MiB (9.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 7F76-1603
ID-3: /mnt/administratifs raw-size: N/A size: 3.57 TiB
used: 599.21 GiB (16.4%) fs: cifs dev: /dev/administratifs
ID-4: /run/media/david/Win11 raw-size: 455.5 GiB
size: 455.5 GiB (100.00%) used: 297.32 GiB (65.3%) fs: ntfs
dev: /dev/nvme1n1p3 maj-min: 259:7 label: Win11 uuid: 4E9CA42F9CA4140D
ID-1: swap-1 type: partition size: 16.93 GiB used: 5.23 GiB (30.9%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: d97779d9-142d-430d-b9c0-e61a86feea80
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 150 MiB fs: vfat label: ESP
uuid: DC0E-737B
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 128 MiB
fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme1n1p4 maj-min: 259:8 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: B0F6506BF6503436
ID-4: /dev/nvme1n1p5 maj-min: 259:9 size: 18.64 GiB fs: ntfs
label: Image uuid: B60450B3045077F7
ID-5: /dev/nvme1n1p6 maj-min: 259:10 size: 1.39 GiB fs: ntfs
label: DELLSUPPORT uuid: 3CEE8CACEE8C604E
Device-1: 1-2:2 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-2: 1-3:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-3.4:5 info: Apple Aluminium Keyboard (ANSI)
type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 202mA
chip-ID: 05ac:024f class-ID: 0301 serial: <filter>
Device-2: 1-5:4 info: Realtek Integrated_Webcam_HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:565a class-ID: 0e02
serial: <filter>
Device-3: 1-9:9 info: Shenzhen Goodix FingerPrint
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:538d class-ID: ff00
Device-4: 1-11:7 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 187c:0550
class-ID: 0300 serial: <filter>
Device-5: 1-14:8 info: Intel AX201 Bluetooth type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-4: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 64.0 C pch: 61.0 C mobo: 54.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 2434
Packages: 2158 pm: pacman pkgs: 2081 libs: 546 tools: pamac,yay
pm: flatpak pkgs: 44 pm: snap pkgs: 33
1: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
2: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
CPU top: 5 of 382
1: cpu: 9.8% command: plasmashell pid: 30972 mem: 449.7 MiB (2.8%)
2: cpu: 6.7% command: htop pid: 30528 mem: 7.87 MiB (0.0%)
3: cpu: 5.4% command: kwin_x11 pid: 30735 mem: 396.5 MiB (2.5%)
4: cpu: 4.4% command: firefox pid: 3732 mem: 480.5 MiB (3.0%)
5: cpu: 4.1% command: VirtualBoxVM pid: 4784 mem: 1877.3 MiB (11.9%)
Memory top: 5 of 382
1: mem: 1877.3 MiB (11.9%) command: VirtualBoxVM pid: 4784 cpu: 4.1%
2: mem: 878.4 MiB (5.5%) command: thunderbird pid: 3820 cpu: 0.9%
3: mem: 480.5 MiB (3.0%) command: firefox pid: 3732 cpu: 4.4%
4: mem: 449.7 MiB (2.8%) command: plasmashell pid: 30972 cpu: 9.8%
5: mem: 396.5 MiB (2.5%) command: kwin_x11 pid: 30735 cpu: 5.4%
Processes: 382 Power: uptime: 8h 36m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.14 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 256
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.36
BG405
20 October 2024 19:48
12
Going this far into swap space will cause issues. That’s about the point when mine starts to struggle.
What’s eating up all the RAM? Browser session a possibility, if playing lots of YouTube videos. But I often get weeks of uptime (sometimes longer) even with quite heavy use, before all the memory leaks from Firefox accumulate and start causing excess swap usage.
Restarting Firefox (when it starts to get sluggish, in my case a few days to a week or two, usually) clears a lot out, but not all of it.
I find it handy to have watch -n30 free -h
running in a Terminal. Adjust that value to a lower one (maybe 5 seconds) and keep an eye on it when you are running programs (especially the browser, as mentioned above!).
