Something's broken
Hi!
After moving to newer hardware (i5 6600k => i7 13700) I get various troubles with a freshly installed Manjaro. The most annoying ones are the two below:
  1. I moved from a GeForce 680 to the internal graphics of my i7 13700.
    This was mainly due to limitations of the Nvidia drivers (eg. KiCad does not show crosshair with Nvidia because of OpenGL quirks… this is a known limitation under linux). Now, occasionally, one of my 2 screens get disabled in KDE after wake-up.
The one giving me troubles is connected via an HDMI/DVI (monitor)=>DP (PC) converter. I tested 3 different ones (2 HDMI/DP and 1 DVI/DP), and it’s always pretty sporadic.
  1. The software tool (pamac?) gives me reguarly the following error: “Remote peer disconnected” and after a minute, it opens nicely. This is kind of reproduciple… start and close the tool 3 or 4 times, and I get this problem
Tested with stable and testing branch and LTS, the newest stable and experimental kernels over the last month or so.
Any ideas?
Is this a 3D Shooter or why crosshair? :slight_smile:
Why DVI? Is this a older high refresh Monitor?
Switch between X11/Wayland in SDDM.
Did you changed your mirrors to your country under Properties?
And did you also Refresh Databases after it?
Additional Terminal command:
sudo pacman-mirrors --fasttrack
If this above isn’t helping already, show us your system:
inxi --admin --verbosity=5 --filter --no-host --width
Yes.
pacman works and everything updates with it.
pamac, however, “occasionally” is different… 4 starts, 1 “crash”.
I switched to testing due to these misbehaviors.
Btw: Kwin also seems to crash occasionally… ie the task bar occasionally disappears and returns to life after a few seconds. But this is “only” once a week… the other stuff happens basically daily.
CAD for electrical stuff… is a official package.
The new pc offers 1 DP and 1 HDMI.
Both monitors are a little dated had have DVI and HDMI.
So I need to convert one of them.
The converters were stolen from running dated i3 machines running pretty dated manjaro (maybe 2year old manjaro). So they are known to work.
Wayland seems to have issues with zoom…at least 2 or 3 weeks ago… but IIRC, I switcht already one from X11 to wayland and back to X11 without impact.
You still missed that…
Do you perhaps use anything other than the Breeze theme? A lot of problems occur with different screen things when I use Breath, but not with Breeze (I would prefer to also use Gnome’s icon set, but alas, not possible in Plasma 6, so far at least).
Also, try setting the task bar to not floating. Seems to be rather buggy that thing. As you say, crashes once a week, or something, when I use floating. Non floating seems to be working a little better, but no guarantees. It may crash anyway. 8)
Just in case you haven’t found the setting, or for others who read this and don’t know: right-click on Taskbar > Enter Edit Mode > Style “button” > Move the slider over to the left. It doesn’t look as good, but I’d choose that over crashes.
No… I’m sure I did it right!
    ~  sudo pacman-mirrors --fasttrack         ✔  6s 
[sudo] Passwort für johannw:
::INFO Lade Mirrorliste herunter von  Manjaro
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Nutze benutzerspezifische Mirrordatei
::INFO Frage Mirrors ab - Dies kann einige Zeit in Anspruch nehmen
  0.248 Austria        : https://mirror.alwyzon.net/manjaro/
  0.233 Austria        : https://mirror.easyname.at/manjaro/
::INFO Schreibe Mirrorliste
::Austria         : https://mirror.easyname.at/manjaro/testing/$repo/$arch
::Austria         : https://mirror.alwyzon.net/manjaro/testing/$repo/$arch
::INFO Mirrorliste erzeugt und gespeichert nach: /etc/pacman.d/mirrorlist
    ~  inxi --admin --verbosity=5 --filter --no-host --width         ✔  5s 
  Kernel: 6.10.0-rc6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=35ecb9d8-fe25-4d84-804f-c4f8446c1652 rw quiet splash
    resume=UUID=d2889123-1476-47cb-8ffe-aaa9bd77ecd0 udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Desktop System: Dell product: Inspiron 3020 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0C0YYY v: A02 serial: <superuser required> part-nu: 0BD4
    uuid: <superuser required> UEFI: Dell v: 1.12.0 date: 01/30/2024
  System RAM: total: 16 GiB available: 15.31 GiB used: 10.01 GiB (65.4%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: DIMM1 type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMAA2GU6CJR8N-XN serial: <filter>
  Device-2: DIMM2 type: no module installed
  Info: model: 13th Gen Intel Core i7-13700 bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x123
  Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
    cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
    L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 948 high: 1397 min/max: 800/5100:5200:4100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1336 2: 800 3: 1101
    4: 1230 5: 1304 6: 800 7: 1052 8: 800 9: 1397 10: 800 11: 1270 12: 800
    13: 800 14: 800 15: 1280 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800
    22: 800 23: 800 24: 800 bogomips: 101400
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Dell
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
    built: 2022+ ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:a780 class-ID: 0300
  Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2
    chip-ID: 045e:0779 class-ID: 0102
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: BenQ GW2270 serial: <filter> built: 2019
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
    diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-2 model: BenQ GW2270 serial: <filter> built: 2019
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a780 memory: 7.48 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 24.1.3-manjaro1.1
    device-ID: 8086:a780 surfaces: xcb,xlib
  Device-1: Intel Alder Lake-S HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-3: GN Netcom Jabra SPEAK 510 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3.1:9
    chip-ID: 0b0e:0420 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.10.0-rc6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel port: 4000 bus-ID: 0000:01:00.0
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    driver: rtw89_8852be v: kernel port: 3000 bus-ID: 0000:02:00.0
    chip-ID: 10ec:b852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0bda:887b
  Report: rfkill ID: hci1 rfk-id: 8 state: up address: see --recommends
  Device-2: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3.3.1:11 chip-ID: 0bda:8771
  Report: ID: hci0 rfk-id: 7 state: up address: N/A
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 1.82 TiB used: 278.84 GiB (15.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 34.9 C
    scheme: GPT
  ID-1: / raw-size: 1.71 TiB size: 1.68 TiB (98.37%) used: 267.21 GiB (15.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 35ecb9d8-fe25-4d84-804f-c4f8446c1652
  ID-2: /boot/efi raw-size: 4.88 GiB size: 4.87 GiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 6143-6395
  ID-1: swap-1 type: partition size: 105.2 GiB used: 11.63 GiB (11.1%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: d2889123-1476-47cb-8ffe-aaa9bd77ecd0
  System Temperatures: cpu: 42.0 C mobo: 46.0 C sodimm: Mem C
  Fan Speeds (rpm): cpu: 922
  Processes: 626 Power: uptime: 2d 6h 16m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1669 pm: pacman pkgs: 1662 libs: 469 tools: pamac pm: flatpak
    pkgs: 7 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
    ~  pacman -Syuu         ✔
Fehler: Sie benötigen Root-Rechte, um diese Operation auszuführen.
    ~  sudo pacman -Syuu         1 ✘
:: Paketdatenbanken werden synchronisiert …
 core ist aktuell
 extra ist aktuell
 multilib ist aktuell
:: Vollständige Systemaktualisierung wird gestartet …
 Es gibt nichts zu tun
Well, it’s vanilla… just installed manjaro freshly…
I’ll try it…
If translations would work… in german translation, this option reads “floating”.
Anyways…something’s broken. I have 2 machines, one with an old setup that’s fine and a new one that is missbehaving.
The only differences I can see are
  • 2 year old config vs new config (both machines run up-to-date manjaro=
  • troubles with “new” hardware (intel seems to care about their drivers)
  • ram (old machine has 64GB, new one will get 64GB in Q3… so maybe some race condition due to swapping???
Possible you did, but you didn’t wrote about it…
Er meint du sollst die Schwebende Taskleiste deaktivieren.
Did you disabled Fast Boot in your Bios?
This Intel CPU had recently bad media, because its heavily overclocked and the powerdraw is dangerous for your CPU with certain Motherboards.
You could manually adjust this settings in Bios or download a new bios which fixed the powerdraw issue from your CPU.
The big downside, some Bios updates are still in Beta and you lose your Warranty. I saw recently a Gigabyte Motherboard Bios which pretends to fix it, while it makes it even worse.
Simple question.
If you create a new User account in Manjaro, do you experience the same issue, or does it seem to magically go away?
Well, I thought “tested with stable and testing” implied that switching worked, but the problem remained…
Need to check this… ATM a non-interruptible task runs for the next hours.
Well, if that happens, it’ll will be a warranty case for Dell… Mfgs only learn by loosing money on repairs. But my PSU does not even have the power to reach the PL2 limit - I guess I’m fine.
Well that’s not as easy to test as I would like… this is my business-workstation.
Moving to another user would make me re-replicating several 100gb of data from the storage and re-configuring quite some stuff to make my business logic run from that user.
I tested my “disaster-plan” by switching from the old workstation to the new… so I know, most of this will work is already scripted, but the remainings still some manual work. Giving the current temperatures in my office, I’d love to spend these hours under some tree on a lake with some cold drink…
Any chance that renaming/removing “~/.config” would have a similar impact?
I noticed recently, that after a reboot, both monitors are working until I log in. When kwin (I’m running KDE) starts, the second monitor gets disabled.
Regards
You may have misunderstood.
The purpose of creating a new account was to see whether the condition exists in a fresh environment; if it did not, then that would infer the issue was related to your existing (user) configuration. The suggestion was not to move to another account.
Renaming ~/.config might be a bit drastic; but temporarily renaming directories beneath ~/.config that may contain settings you suspect might be contributing, is a reasonable approach. Whether this might actually produce results, I can’t say.
Well, all started with a fresh install… but fair enough, it would be a worthwile test if nothing helps.
However, I work on this machine… so not moving everything means no testing.
The issue is not permanent but sporadic…
My bet is on some kind of race-condition between the software and the DP-to-something adapters.
Fast-Boot was disabled already, but the Dell bios allows for a delayed boot process.
I set this delay to 5s and so far, both monitors got detected on every wakeup.
However, this misbehavior shows once almost every day… sometimes, I get 2-3 days without issue…
Oh, and the problem with the update-tool got more annoying with the last update.
Now every other start of the program, it crashes. Reported error: Remote peer disconnected
Regards
I don’t know if this will make a difference for your issues with pamac, but it appears that you have a custom mirror pool, possibly from running something like pacman-mirrors --country Austria. With only 2 servers in Austria, this may be a little limiting, and you may have better luck with a custom mirror pool from pacman-mirrors --continent.
Thanks for mentioning this.
With more mirrors, pamac seems stable… so how / where to file a bugreport.
I guess this should not makepamac crashing all the time, right?
Anyhow, disabled monitor after sleep is back… and another new symptom:
Half of the screen does not get the “background”.
After the monitor got dark, the background stayed black and no right-click popup.
Adding to the annoyance, my Jabra speaker randomly stops to playback audio.
I already updated the firmware on the speakers, but still at some point, audio just stops while the microphone still works.
Again, this worked on an older Manjaro installation…
OK… pamac still is not stable!
Here’s my journald output:
Jul 17 13:47:01 rechenknecht2 systemd-coredump[29893]: [🡕] Process 29870 (pamac-manager) of user 1000 dumped core.
                                                       Stack trace of thread 29890:
                                                       #0  0x00007c6b7869897b n/a (libssl.so.3 + 0xa097b)
                                                       #1  0x00007c6b78675b58 n/a (libssl.so.3 + 0x7db58)
                                                       #2  0x00007c6b786672d2 n/a (libssl.so.3 + 0x6f2d2)
                                                       #3  0x00007c6b78668e67 n/a (libssl.so.3 + 0x70e67)
                                                       #4  0x00007c6b78684a0a n/a (libssl.so.3 + 0x8ca0a)
                                                       #5  0x00007c6b7867f41e n/a (libssl.so.3 + 0x8741e)
                                                       #6  0x00007c6b78bbc9d2 n/a (libcurl.so.4 + 0x839d2)
                                                       #7  0x00007c6b78bc36fb n/a (libcurl.so.4 + 0x8a6fb)
                                                       #8  0x00007c6b78bba51f n/a (libcurl.so.4 + 0x8151f)
                                                       #9  0x00007c6b78b59100 n/a (libcurl.so.4 + 0x20100)
                                                       #10 0x00007c6b78b4640e n/a (libcurl.so.4 + 0xd40e)
                                                       #11 0x00007c6b78b501b6 n/a (libcurl.so.4 + 0x171b6)
                                                       #12 0x00007c6b78b91870 n/a (libcurl.so.4 + 0x58870)
                                                       #13 0x00007c6b78b93f3d curl_multi_perform (libcurl.so.4 + 0x5af3d)
                                                       #14 0x00007c6b7998fa6e n/a (libalpm.so.14 + 0x1ea6e)
                                                       #15 0x00007c6b79983958 alpm_db_update (libalpm.so.14 + 0x12958)
                                                       #16 0x00007c6b7821dc70 n/a (libpamac-aur.so + 0x6c70)
                                                       #17 0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #18 0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #19 0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29882:
                                                       #0  0x00007c6b76322dab n/a (libstemmer.so.0 + 0x40dab)
                                                       #1  0x00007c6b76326526 n/a (libstemmer.so.0 + 0x44526)
                                                       #2  0x00007c6b763236d8 sb_stemmer_stem (libstemmer.so.0 + 0x416d8)
                                                       #3  0x00007c6b78194f7b as_stemmer_stem (libappstream.so.5 + 0x2ff7b)
                                                       #4  0x00007c6b781a28de n/a (libappstream.so.5 + 0x3d8de)
                                                       #5  0x00007c6b781a2f84 n/a (libappstream.so.5 + 0x3df84)
                                                       #6  0x00007c6b781a2fe9 n/a (libappstream.so.5 + 0x3dfe9)
                                                       #7  0x00007c6b781a306d as_component_search_matches (libappstream.so.5 + 0x3e06d)
                                                       #8  0x00007c6b781a318c as_component_search_matches_all (libappstream.so.5 + 0x3e18c)
                                                       #9  0x00007c6b7b4da430 n/a (libpamac-appstream.so + 0x6430)
                                                       #10 0x00007c6b7a723675 n/a (libpamac.so.11 + 0x35675)
                                                       #11 0x00007c6b7a723972 n/a (libpamac.so.11 + 0x35972)
                                                       #12 0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #13 0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #14 0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29870:
                                                       #0  0x00007c6b7a60a39d __poll (libc.so.6 + 0x10839d)
                                                       #1  0x00007c6b7a90092d n/a (libglib-2.0.so.0 + 0xbe92d)
                                                       #2  0x00007c6b7a89dfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                       #3  0x00007c6b7aaccc66 g_application_run (libgio-2.0.so.0 + 0xddc66)
                                                       #4  0x000059f977b28416 n/a (pamac-manager + 0xc416)
                                                       #5  0x00007c6b7a527c88 n/a (libc.so.6 + 0x25c88)
                                                       #6  0x00007c6b7a527d4c __libc_start_main (libc.so.6 + 0x25d4c)
                                                       #7  0x000059f977b28545 n/a (pamac-manager + 0xc545)
                                                       Stack trace of thread 29885:
                                                       #0  0x00007c6b7a5a341d n/a (libc.so.6 + 0xa141d)
                                                       #1  0x00007c6b7a5a5dae __libc_free (libc.so.6 + 0xa3dae)
                                                       #2  0x00007c6b78c8492d BN_clear_free (libcrypto.so.3 + 0x8492d)
                                                       #3  0x00007c6b78c84d89 BN_MONT_CTX_free (libcrypto.so.3 + 0x84d89)
                                                       #4  0x00007c6b78cea5a1 EC_GROUP_free (libcrypto.so.3 + 0xea5a1)
                                                       #5  0x00007c6b78ce95b5 n/a (libcrypto.so.3 + 0xe95b5)
                                                       #6  0x00007c6b78ce974f n/a (libcrypto.so.3 + 0xe974f)
                                                       #7  0x00007c6b78e0f409 n/a (libcrypto.so.3 + 0x20f409)
                                                       #8  0x00007c6b78e0f5c5 n/a (libcrypto.so.3 + 0x20f5c5)
                                                       #9  0x00007c6b78c67b93 n/a (libcrypto.so.3 + 0x67b93)
                                                       #10 0x00007c6b78c686a0 ASN1_item_d2i_ex (libcrypto.so.3 + 0x686a0)
                                                       #11 0x00007c6b78e72847 n/a (libcrypto.so.3 + 0x272847)
                                                       #12 0x00007c6b78e10543 d2i_EC_PUBKEY (libcrypto.so.3 + 0x210543)
                                                       #13 0x00007c6b78e301ce n/a (libcrypto.so.3 + 0x2301ce)
                                                       #14 0x00007c6b78d1a0fc n/a (libcrypto.so.3 + 0x11a0fc)
                                                       #15 0x00007c6b78e32fb0 n/a (libcrypto.so.3 + 0x232fb0)
                                                       #16 0x00007c6b78d1a0fc n/a (libcrypto.so.3 + 0x11a0fc)
                                                       #17 0x00007c6b78d1a3ee OSSL_DECODER_from_bio (libcrypto.so.3 + 0x11a3ee)
                                                       #18 0x00007c6b78d1a711 OSSL_DECODER_from_data (libcrypto.so.3 + 0x11a711)
                                                       #19 0x00007c6b78e0f692 n/a (libcrypto.so.3 + 0x20f692)
                                                       #20 0x00007c6b78c67b93 n/a (libcrypto.so.3 + 0x67b93)
                                                       #21 0x00007c6b78c69c02 n/a (libcrypto.so.3 + 0x69c02)
                                                       #22 0x00007c6b78c67f75 n/a (libcrypto.so.3 + 0x67f75)
                                                       #23 0x00007c6b78c69c02 n/a (libcrypto.so.3 + 0x69c02)
                                                       #24 0x00007c6b78c67f75 n/a (libcrypto.so.3 + 0x67f75)
                                                       #25 0x00007c6b78c686a0 ASN1_item_d2i_ex (libcrypto.so.3 + 0x686a0)
                                                       #26 0x00007c6b78d9e382 PEM_X509_INFO_read_bio_ex (libcrypto.so.3 + 0x19e382)
                                                       #27 0x00007c6b78ddfe19 X509_load_cert_crl_file_ex (libcrypto.so.3 + 0x1dfe19)
                                                       #28 0x00007c6b78ddffd6 n/a (libcrypto.so.3 + 0x1dffd6)
                                                       #29 0x00007c6b78dfd83b X509_STORE_load_file_ex (libcrypto.so.3 + 0x1fd83b)
                                                       #30 0x00007c6b78bb14bd n/a (libcurl.so.4 + 0x784bd)
                                                       #31 0x00007c6b78bb19de n/a (libcurl.so.4 + 0x789de)
                                                       #32 0x00007c6b78c6c563 n/a (libcrypto.so.3 + 0x6c563)
                                                       #33 0x00007c6b78c706f7 n/a (libcrypto.so.3 + 0x706f7)
                                                       #34 0x00007c6b78c7088b BIO_read (libcrypto.so.3 + 0x7088b)
                                                       #35 0x00007c6b7866c83c n/a (libssl.so.3 + 0x7483c)
                                                       #36 0x00007c6b7867097b n/a (libssl.so.3 + 0x7897b)
                                                       #37 0x00007c6b7866b2ba n/a (libssl.so.3 + 0x732ba)
                                                       #38 0x00007c6b78668e4e n/a (libssl.so.3 + 0x70e4e)
                                                       #39 0x00007c6b78684a0a n/a (libssl.so.3 + 0x8ca0a)
                                                       #40 0x00007c6b7867f41e n/a (libssl.so.3 + 0x8741e)
                                                       #41 0x00007c6b78bbc9d2 n/a (libcurl.so.4 + 0x839d2)
                                                       #42 0x00007c6b78bc36fb n/a (libcurl.so.4 + 0x8a6fb)
                                                       #43 0x00007c6b78bba51f n/a (libcurl.so.4 + 0x8151f)
                                                       #44 0x00007c6b78b59100 n/a (libcurl.so.4 + 0x20100)
                                                       #45 0x00007c6b78b4640e n/a (libcurl.so.4 + 0xd40e)
                                                       #46 0x00007c6b78b501b6 n/a (libcurl.so.4 + 0x171b6)
                                                       #47 0x00007c6b78b91870 n/a (libcurl.so.4 + 0x58870)
                                                       #48 0x00007c6b78b93f3d curl_multi_perform (libcurl.so.4 + 0x5af3d)
                                                       #49 0x00007c6b7998fa6e n/a (libalpm.so.14 + 0x1ea6e)
                                                       #50 0x00007c6b79983958 alpm_db_update (libalpm.so.14 + 0x12958)
                                                       #51 0x00007c6b7821dc70 n/a (libpamac-aur.so + 0x6c70)
                                                       #52 0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #53 0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #54 0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29884:
                                                       #0  0x00007c6b7a615e9d syscall (libc.so.6 + 0x113e9d)
                                                       #1  0x00007c6b7a8f98cc n/a (libglib-2.0.so.0 + 0xb78cc)
                                                       #2  0x00007c6b78193878 n/a (libappstream.so.5 + 0x2e878)
                                                       #3  0x00007c6b78195012 as_stemmer_get (libappstream.so.5 + 0x30012)
                                                       #4  0x00007c6b781a29e2 n/a (libappstream.so.5 + 0x3d9e2)
                                                       #5  0x00007c6b781a2b61 n/a (libappstream.so.5 + 0x3db61)
                                                       #6  0x00007c6b781a2dbd n/a (libappstream.so.5 + 0x3ddbd)
                                                       #7  0x00007c6b781a2fe9 n/a (libappstream.so.5 + 0x3dfe9)
                                                       #8  0x00007c6b781a306d as_component_search_matches (libappstream.so.5 + 0x3e06d)
                                                       #9  0x00007c6b781a318c as_component_search_matches_all (libappstream.so.5 + 0x3e18c)
                                                       #10 0x00007c6b7815eb12 n/a (libpamac-flatpak.so + 0xbb12)
                                                       #11 0x00007c6b7a7349c4 n/a (libpamac.so.11 + 0x469c4)
                                                       Stack trace of thread 29872:
                                                       #3  0x00007c6b7a89e01a n/a (libglib-2.0.so.0 + 0x5c01a)
                                                       #4  0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #5  0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #6  0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29878:
                                                       #1  0x00007c6b7a8f9a10 g_cond_wait (libglib-2.0.so.0 + 0xb7a10)
                                                       #2  0x00007c6b7a86790c n/a (libglib-2.0.so.0 + 0x2590c)
                                                       #3  0x00007c6b7a86797d g_async_queue_pop (libglib-2.0.so.0 + 0x2597d)
                                                       #4  0x00007c6b7a2255fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
                                                       #5  0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #6  0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #7  0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29883:
                                                       #0  0x00007c6b7a5914e9 n/a (libc.so.6 + 0x8f4e9)
                                                       #1  0x00007c6b7a596bf3 n/a (libc.so.6 + 0x94bf3)
                                                       #2  0x00007c6b7a8d32ee g_thread_join (libglib-2.0.so.0 + 0x912ee)
                                                       #3  0x00007c6b7821fc79 n/a (libpamac-aur.so + 0x8c79)
                                                       #4  0x00007c6b7821f831 n/a (libpamac-aur.so + 0x8831)
                                                       #5  0x00007c6b78220205 n/a (libpamac-aur.so + 0x9205)
                                                       #6  0x00007c6b7a723a0b n/a (libpamac.so.11 + 0x35a0b)
                                                       #7  0x00007c6b7a723d62 n/a (libpamac.so.11 + 0x35d62)
                                                       #8  0x00007c6b7a8ce266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                       #9  0x00007c6b7a594ded n/a (libc.so.6 + 0x92ded)
                                                       #10 0x00007c6b7a6180dc n/a (libc.so.6 + 0x1160dc)
                                                       Stack trace of thread 29873:
                                                       #2  0x00007c6b7a89f7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
                                                       #3  0x00007c6b7ab01574 n/a (libgio-2.0.so.0 + 0x112574)
                                                       Stack trace of thread 29871:
                                                       #3  0x00007c6b7a8d36b7 n/a (libglib-2.0.so.0 + 0x916b7)
                                                       Stack trace of thread 29876:
                                                       #1  0x00007c6b7a8fa367 g_cond_wait_until (libglib-2.0.so.0 + 0xb8367)
                                                       #2  0x00007c6b7a8678d5 n/a (libglib-2.0.so.0 + 0x258d5)
                                                       #3  0x00007c6b7a867a48 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x25a48)
                                                       #4  0x00007c6b7a8d40b0 n/a (libglib-2.0.so.0 + 0x920b0)
                                                       Stack trace of thread 29888:
                                                       #0  0x00007c6b7a591740 n/a (libc.so.6 + 0x8f740)
                                                       #1  0x00007c6b7a5985b8 pthread_mutex_lock (libc.so.6 + 0x965b8)
                                                       #2  0x00007c6b7815ea53 n/a (libpamac-flatpak.so + 0xba53)
                                                       #3  0x00007c6b7a7349c4 n/a (libpamac.so.11 + 0x469c4)
                                                       Stack trace of thread 29886:
                                                       #2  0x00007c6b7a723391 n/a (libpamac.so.11 + 0x35391)
                                                       #3  0x00007c6b7a723972 n/a (libpamac.so.11 + 0x35972)
                                                       Stack trace of thread 29877:
                                                       #3  0x00007c6b754bd2fe n/a (libdconfsettings.so + 0x62fe)
                                                       Stack trace of thread 29887:
this is from dmesg:
[10535.074846] traps: update_aur_db[29890] general protection fault ip:7c6b7869897b sp:7c6b57dfeec0 error:0 in libssl.so.3[a097b,7c6b7860b000+93000]
seems libssl is the problem.
For the audio-problem… it seems that pipewire is the problem… IIRC, the older setup used PulseAudio…
Jul 17 13:01:09 rechenknecht2 pipewire[1027]: spa.alsa: front:2p: (250 suppressed) snd_pcm_avail after recover: Datenübergabe unterbrochen (broken pipe)
I will not condemn or condone the use of pamac’s AUR functionlity - but fact is that the Pamac GUI fairly often creates issues when AUR access is enabled.
Please disable AUR in the pamac settings.
You can do this from terminal by editing /etc/pamac.conf
## Allow Pamac to search and install packages from AUR:
#EnableAUR
What’s good about this is that it prevents automatic search/install, but you can still do it manually with the -a option :smiley:
