Some problems with optimus-manager and switching
Hello all.
After messing around on Manjaro KDE for a while, I went back to GNOME yesterday (did a clean install). I had the installer set up nvidia-455xx-prime.
After first reboot, I set up optimus-manager, and used the Manjaro wiki and the Github instructions, I did uncomment the WaylandEnable=false. I have also installed gdm-prime.
I installed optimus-manager-qt and rebooted after installing and enabling optimus-manager.
Now, switching to to Nvidia resulted (note past tense, but might be current as well) the computer to come to a halt on my HP logo. I was able to use TTY2 to log in and startx. Upon logging in, I needed to insert keyring key. Going back to TTY1 seems to have weird effect to it, the optimus-manager was missing from the top panel, and it just felt weird…
Anyway, TTY2 worked fine.
Today, I tried to switch again, resulting in same process, so I did some digging and found this. I tried changing the settings in optimus-manager as suggested, but every change I tried resulted in the inability to switch to Nvidia (I tried more than 2 times on each setting). I finally reverted to default settings (and rebooted)… which now can’t switch to Nvidia.
I am currently at a loss working around this and I do not have enough knowledge to work through the log it self.
inxi -Fazy
~ >>> inxi -Fazy
  Kernel: 5.9.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=4aeb67d6-2818-4be4-b376-d5e17ef83701 rw quiet udev.log_priority=3
  Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
  date: 04/21/2020
  ID-1: BAT1 charge: 26.9 Wh condition: 26.9/52.8 Wh (51%) volts: 12.8/11.6
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Full
  Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
  L2 cache: 8192 KiB
  bogomips: 36812
  Speed: 857 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 878 2: 844 3: 846
  4: 840 5: 844 6: 842 7: 830 8: 848
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
  driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
  chip ID: 10de:1c8d
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
  Integrated Webcam
  type: USB driver: uvcvideo bus ID: 1-5:5 chip ID: 05c8:03bc
  Display: x11 server: X.org 1.20.9 compositor: gnome-shell
  driver: modesetting resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.2
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k5.9.10-1-MANJARO
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
  port: 4000 bus ID: 02:00.0 chip ID: 10ec:b822
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8168
  Local Storage: total: 1.60 TiB used: 466.23 GiB (28.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
  ID-2: /dev/sda type: USB vendor: Toshiba model: External USB 3.0
  size: 931.51 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 5438 scheme: MBR
  ID-3: /dev/sdb type: USB vendor: Western Digital model: WD My Passport 0740
  size: 465.73 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1007 scheme: GPT
  ID-1: / raw size: 237.97 GiB size: 233.24 GiB (98.01%)
  used: 51.55 GiB (22.1%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 57.0 C mobo: 29.8 C
  Processes: 270 Uptime: 15m Memory: 15.53 GiB used: 1.45 GiB (9.3%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
  pacman: 1387 lib: 432 flatpak: 0 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.1.08
optimus-manager log
[35] INFO: # Xorg pre-start hook
[35] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'intel', 'current_mode': None}
[35] INFO: Requested mode is: intel
[35] INFO: Checking for GDM display servers
[64] ERROR: Config parsing : error in option "dri" in section [intel] : invalid value "0"
[64] INFO: Falling back to default value "3"
[374] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[375] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[392] INFO: Loaded extra Intel Xorg options (0 lines)
[392] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[392] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20201126T100455', 'requested_mode': 'intel'}
[393] INFO: Xorg pre-start hook completed successfully.
[4] INFO: # Xorg post-start hook
[4] INFO: Running /etc/optimus-manager/xsetup-intel.sh
[7] ERROR: Config parsing : error in option "dri" in section [intel] : invalid value "0"
[7] INFO: Falling back to default value "3"
[158] INFO: Writing state {'type': 'done', 'switch_id': '20201126T100455', 'current_mode': 'intel'}
[159] INFO: Xorg post-start hook completed successfully.
[8] INFO: # Xorg pre-start hook
[8] INFO: Previous state was: {'type': 'done', 'switch_id': '20201126T100455', 'current_mode': 'intel'}
[8] INFO: Requested mode is: intel
[8] INFO: Checking for GDM display servers
[30] ERROR: Config parsing : error in option "dri" in section [intel] : invalid value "0"
[30] INFO: Falling back to default value "3"
[38] INFO: Loaded extra Intel Xorg options (0 lines)
[38] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[38] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20201126T100455', 'requested_mode': 'intel'}
[39] INFO: Xorg pre-start hook completed successfully.
[10] INFO: Writing state {'type': 'done', 'switch_id': '20201126T100455', 'current_mode': 'intel'}
[11] INFO: Xorg post-start hook completed successfully.
[13] INFO: # Xorg pre-start hook
[13] INFO: Previous state was: {'type': 'done', 'switch_id': '20201126T100455', 'current_mode': 'intel'}
[13] INFO: Requested mode is: intel
[13] INFO: Checking for GDM display servers
[45] ERROR: Config parsing : error in option "dri" in section [intel] : invalid value "0"
[45] INFO: Falling back to default value "3"
[54] INFO: Loaded extra Intel Xorg options (0 lines)
[54] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[54] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20201126T100455', 'requested_mode': 'intel'}
[54] INFO: Xorg pre-start hook completed successfully.
[9] INFO: # Xorg pre-start hook
[9] INFO: Previous state was: {'type': 'done', 'switch_id': '20201126T100455', 'current_mode': 'intel'}
[9] INFO: Requested mode is: intel
[9] INFO: Checking for GDM display servers
[39] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20201126T100455', 'requested_mode': 'intel'}
I know GDM doesn’t play well with optimus-manager, but I really don’t want to reinstall again, and I have actually come acustom to usinng GNOME :confounded:
Starting to think this install is somehow broken, theming is all over the place and looks weird for some applications, so I think my best bet is to reinstall.
So I installed GNOME again, still had strange theming problem, and optimus-manager just wouldn’t work properly for me. So after some trial and error I ended up again on KDE which seems to work much better with my hardware.
