I updated my phone and now I seem to have some icons that are missing in the app launcher/menu, neochat and discover for example. Anyone else have this issue? Maybe I should just download the last image and leave it alone until the next plasma mobile release?
Did you reboot after the update?
I haven’t noticed any icons missing in the menu, unless the App is known to be missing an icon.
Yes, I rebooted and they remained missing. The name is visible and I can click to start the apps, just no visible icon. It was late when I performed the update so I did not have a chance investigate further. I will try to take a closer look at it again this evening.
It’s a well known fact that if something goes wrong you have to type some command.
IOW: which ones specifically, please???
I switched icons to the Adwaita set, and all icons except for Settings was visible. I then switched back to the Breeze set and all icons are now visible again.
I am sorry, I did not see your post in time. And unfortunately, I don’t recall the others. There were 5 or 6 missing.
