Function keys for screen brightness don’t work.
volume functions keys say volume is going up and down but in youtube music they have no effect.
[demo@manjaro-live ~]$ inxi -Fazyr
Kernel: 5.15.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=56db831e-75d3-4b34-8c94-23ffcc0c9a4a rw udev.log_priority=3
Desktop: LXQt 1.0.0 tk: Qt 5.15.3 info: plank, lxqt-panel
wm: Openbox 3.6.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.26 date: 07/09/2021
ID-1: BAT0 charge: 53.5 Wh (79.6%) condition: 67.2/67.2 Wh (100.0%)
volts: 12.2 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: N/A cycles: 171
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max:
gen: 3 speed: 8 GT/s bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.3 compositor: Compton driver: X:
loaded: modesetting unloaded: vesa alternate: fbdev gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics built: 2017 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.26-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
modules: wl bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 960.81 GiB used: 11.1 GiB (1.2%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SMI (STMicroelectronics)
model: USB size: 29.3 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 29 GiB size: 28.38 GiB (97.85%) used: 11.1 GiB (39.1%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 46.0 C pch: 43.0 C mobo: N/A
Packages: pacman: 1064 lib: 302 flatpak: 0
Active pacman repo servers in: /etc/pacman.conf
1: http://repo.spinsbykilz.com/2/files/repository/stable/x86_64/
1: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
Processes: 230 Uptime: 11m wakeups: 1058 Memory: 15.27 GiB
used: 2.01 GiB (13.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Shell: Bash v: 5.1.16 running-in: qterminal
inxi: 3.3.13
