Because I didn’t know I can use such options after the system is installed. I always thought that this option was only available during the installation. I have no preferences, I would like to use the best option.
You’re right, this should be done at first. But now, for me, reinstalling again 4 systems (3 Manjaro and 1 W10) it’s a lot of work. That’s why I’m looking for a solution which let me to encrypt my disks as they are now…
Do you know which kind of performance loss (if there is) has an encrypted disk? I also have doubts about how will live with the grub and the BitLocker’s feature of W10.
The problem is that all those settings needed for encryption, if you overwrite them from backup (and don’t create them manually) the system won’t boot. You can only overwrite /home.
