I have Manjaro (duh) Gnome, the most recent update as per today 18/11/2022, and ever since I updated my devices, some actions happen twice when I do them.
For example, if I press Super to search for Spotify, when I press “s” once, “ss” appears in the searchbar, but it’s only sometimes & only if I was not previously on the searchbar already.
Now I noticed that also clicking on links, sometimes, opens the same tab twice.
I cannot yet seem to notice a patterns, but will update this post if I see it.
Inxi -v7azy says:
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cfa63bf8-bdef-44f1-b2ee-3e6277fd68b6 rw quiet
cryptdevice=UUID=6bb38075-a2fd-4bdf-875a-970e7707de37:luks-6bb38075-a2fd-4bdf-875a-970e7707de37
root=/dev/mapper/luks-6bb38075-a2fd-4bdf-875a-970e7707de37 splash
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: HP Pavilion Notebook v: Type1ProductConfigId
Mobo: HP model: 80A5 v: 91.1E serial: <superuser required> UEFI: Insyde
v: F.89 date: 11/02/2018
ID-1: BAT0 charge: 23.2 Wh (100.0%) condition: 23.2/23.2 Wh (100.0%)
volts: 16.8 min: 14.8 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full
RAM: total: 15.47 GiB used: 7.21 GiB (46.6%)
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19204
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Hewlett-Packard
driver: nouveau v: kernel non-free: 520.xx+ status: current (as of 2022-10)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1347 class-ID: 0302
Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 0bda:57c4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x159e built: 2012 res: 1600x900
dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43") diag: 438mm (17.2")
ratio: 16:9 modes: 1600x900
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 14e4:4365 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Device-1: luks-6bb38075-a2fd-4bdf-875a-970e7707de37 maj-min: 254:0
type: LUKS dm: dm-0 size: 195.52 GiB
Components:
p-1: sda6 maj-min: 8:6 size: 195.53 GiB
Local Storage: total: 931.51 GiB used: 137.33 GiB (14.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A6SH rev: DH61
dev-links: cdrom
ID-1: / raw-size: 195.52 GiB size: 191.39 GiB (97.89%)
used: 137.13 GiB (71.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6bb38075-a2fd-4bdf-875a-970e7707de37 label: N/A
uuid: cfa63bf8-bdef-44f1-b2ee-3e6277fd68b6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 206.3 MiB (80.6%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: SYSTEM
uuid: 7474-1CB9
ID-1: /dev/sda1 maj-min: 8:1 size: 1.73 GiB fs: ntfs label: N/A
uuid: 2EB8459DB8456485
ID-2: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 642.03 GiB fs: ntfs label: Windows
uuid: 28A0FD57A0FD2BC6
ID-4: /dev/sda5 maj-min: 8:5 size: 646 MiB fs: ntfs label: N/A
uuid: F4BA2504BA24C4C8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Realtek HP Truevision HD type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:57c4
Device-2: 1-6:5 info: E-Signal USB Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 12c9:1017 class-ID: 0300
Device-3: 1-7:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C pch: 42.0 C mobo: N/A
Processes: 274 Uptime: 6h 4m wakeups: 10 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1477 pm: pacman pkgs: 1460 libs: 400 tools: gnome-software,pamac
pm: flatpak pkgs: 8 pm: snap pkgs: 9 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.23
