[SOLVED]When will the [multilib] for Artix be available?
repo
artix
#1
Hi. I plan to use Artix and I find the Artix website says that “The [multilib] repo will eventually be available.” So when will it be available, and any solution if I want it now? Can I just simply use the Arch one?
p.s.: Why do the following pages not available?
https://artix-linux.github.io/installation
https://artix-linux.github.io/why
Sorry for my poor English. Thanks for reading.
#2
NOTE :This isn’t the place to ask for Artix related questions as this is a Manjaro forums…
Yes you can use [multilib] from the Arch one by simply uncommeting these lines from /etc/pacman.conf (that is if you have installed Artix Linux of course) :
#[multilib]
#Include = /etc/pacman.d/mirrorlist-arch
Because https://artix-linux.github.io site’s development are not yet finished…
If you have any further questions, you should be asking in either :
http://systemd-free.org/comments.php
or
closed #3
