Not able to install extension pack for Oracle Virtual Box- VirtualBox 6.1.14 Oracle VM VirtualBox Extension Pack
Error-
Failed to install the Extension Pack **/home/nszen/Downloads/Oracle_VM_VirtualBox_Extension_Pack-6.1.14.vbox-extpack** .
The installer failed with exit code 1: [sudo] password for ,username>: sudo: /usr/lib/virtualbox/VBoxExtPackHelperApp --stdout /tmp/VBoxExtPackHelper-qotkpg/stdout --stderr /tmp/VBoxExtPackHelper-qotkpg/stderr --elevated install --base-dir /usr/lib/virtualbox/ExtensionPacks --cert-dir /usr/share/virtualbox/ExtPackCertificates --name **'Oracle VM VirtualBox Extension Pack'** --tarball /home/nszen/Downloads/Oracle_VM_VirtualBox_Extension_Pack-6.1.14.vbox-extpack --sha-256 b224e796e886b19bce69f0aaedf6ca82bad0ca29c61fb0ed86166efb84356942: command not found
sudo: /usr/lib/virtualbox/VBoxExtPackHelperApp --stdout /tmp/VBoxExtPackHelper-qotkpg/stdout --stderr /tmp/VBoxExtPackHelper-qotkpg/stderr --elevated install --base-dir /usr/lib/virtualbox/ExtensionPacks --cert-dir /usr/share/virtualbox/ExtPackCertificates --name **'Oracle VM VirtualBox Extension Pack'** --tarball /home/username/Downloads/Oracle_VM_VirtualBox_Extension_Pack-6.1.14.vbox-extpack --sha-256 b224e796e886b19bce69f0aaedf6ca82bad0ca29c61fb0ed86166efb84356942: command not found
/bin/gksu: line 31: echo: write error: Broken pipe.
|Result Code:|NS_ERROR_FAILURE (0x80004005)|
|Component:|ExtPackManagerWrap|
|Interface:|IExtPackManager {70401eef-c8e9-466b-9660-45cb3e9979e4}|
Kindly, assist in resolving the issue- as I need to install the extension pack to run Windows 10 in virtual mode with access to USB-ports.
System Summary
OS: Manjaro Linux x86_64
Host: GA-78LMT-S2PT
Kernel: 5.8.6-1-MANJARO
Uptime: 29 mins
Packages: 1119 (pacman), 6 (snap)
Shell: bash 5.0.18
Resolution: 1920x1080
DE: Xfce 4.14
WM: Xfwm4
WM Theme: Matcha-sea
Theme: Matcha-sea [GTK2], Adwaita [GTK3]
Icons: Papirus-Maia [GTK2], Adwaita [GTK3]
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: AMD Phenom II X2 560 (2) @ 3.300GHz
GPU: NVIDIA GeForce GT 710
Memory: 1659MiB / 3932MiB
