Iowait issues on Manjaro kernel
Hi,
I’ve already posted a topic before, where I described extreme slow boot times on an otherwise fast system: Windows boots in about 5 seconds after the UEFI screen, whereas Manjaro, EndeavourOS and Garuda boot slow (25-30 seconds from Grub to being able to use the Desktop).
After using Manjaro for a longer time now, I also noticed extreme iowait issues when updating games on Steam. Basically, installing/updating huge games causes the whole system to freeze and lock up. The monitoring program Glances shows about 30-60% iowait while doing so. This led me to the conclusion that the slow boot might be an iowait issue as well…
After trying various configs, I found out that Garuda with linux-zen seems to fix this issue for me (also only ~5 seconds of boot time), which leads me to the assumption, that the normal Arch kernel must be the culprit? (I guess my drives are not the cause, because it happens for all of them → 1x nvme - 3x ssd - 1x hdd - Also the issue does not happen on Windows at all.)
Since I’m not really much into the topic kernel and system config, I wanted to ask for advice on what would be the best to further debug this issue to eventually also get it fixed for Manjaro? (because it’s really a big annoyance)
Thanks,
Bernhard K.
The Filesystem you’re trying to write to might have something to do with iowait.
You should provide more info about the machine:
Hi @Rokolell,
In addition to the info requested by @freggel.doe, you could, and should check for any startup errors:
journalctl --boot --priority=4 --no-pager
This will output all warnings, errors, critical, alert and emergency messages that occurred during the boot. Do not fret if it’s long. Chances are it will be.
Provide it along with the other information requested.
Hey,
sure, here is my system info ( all drives use ext4 except the 1.82TiB Hdd, but I don’t think it matters cause Garuda uses btrfs and has the same issue without zen kernel ):
  Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=4bd45721-0b66-4ce8-b2a1-b606c585fad5 rw splash
    nvidia-drm.modeset=1 quiet vt.global_cursor_default=0
    cryptdevice=UUID=cd30fb77-e732-4a06-b6a7-5469cca30ecf:luks-cd30fb77-e732-4a06-b6a7-5469cca30ecf
    root=/dev/mapper/luks-cd30fb77-e732-4a06-b6a7-5469cca30ecf apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-21e703d9-f76c-4e28-bb5e-2e4ed9ab2646
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
  Type: Desktop Mobo: ASRock model: X99 Extreme4 serial: <superuser required>
    UEFI: American Megatrends v: P3.40 date: 06/03/2016
  RAM: total: 15.55 GiB used: 10.49 GiB (67.4%)
  RAM Report:
  Info: model: Intel Core i7-5930K bits: 64 type: MT MCP arch: Haswell
    family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x49
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 15 MiB desc: 1x15 MiB
  Speed (MHz): avg: 1446 high: 2463 min/max: 1200/3700 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1333 3: 1200
    4: 1249 5: 2463 6: 1200 7: 1424 8: 2286 9: 1200 10: 1263 11: 1344 12: 1200
    bogomips: 84006
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
    cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
    pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: ZOTAC driver: nvidia
    v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3
    bus-ID: 02:00.0 chip-ID: 10de:2182 class-ID: 0300
  Device-2: Logitech BRIO Ultra HD Webcam type: USB
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-6:2
    chip-ID: 046d:085e class-ID: 0300 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
    d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
  Device-1: Intel C610/X99 series HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
    class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio vendor: ZOTAC
    bus-ID: 02:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-3: RODE Microphones Podcaster type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-11:8 chip-ID: 19f7:0001
    class-ID: 0300
  Device-4: Logitech BRIO Ultra HD Webcam type: USB
  Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Sound Server-3: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Ethernet I218-V vendor: ASRock driver: e1000e v: kernel
    port: f020 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
  IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: CW_Wireguard state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  Device-1: luks-cd30fb77-e732-4a06-b6a7-5469cca30ecf maj-min: 254:0
    type: LUKS dm: dm-0 size: 471.64 GiB
  Components:
  p-1: sdd2 maj-min: 8:50 size: 471.65 GiB
  Device-2: luks-21e703d9-f76c-4e28-bb5e-2e4ed9ab2646 maj-min: 254:1
    type: LUKS dm: dm-1 size: 17.1 GiB
  Components:
  p-1: sdd3 maj-min: 8:51 size: 17.11 GiB
  Local Storage: total: 3.79 TiB used: 1.78 TiB (46.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 512GB
    lanes: 4 type: SSD serial: <filter> rev: 1B0QBXX7 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    type: SSD serial: <filter> rev: 020 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
    type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT128M4SSD2
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 040H scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT525MX300SSD1
    size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: R040 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.02
    dev-links: cdrom
  ID-1: / raw-size: 471.64 GiB size: 463.17 GiB (98.20%)
    used: 251.58 GiB (54.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-cd30fb77-e732-4a06-b6a7-5469cca30ecf label: N/A
    uuid: 4bd45721-0b66-4ce8-b2a1-b606c585fad5
    used: 440 KiB (0.1%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: NO_LABEL
    uuid: 6961-E4A7
  ID-3: /mnt/Games raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 834.96 GiB (91.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Games
    uuid: a93faa7e-3a61-4d46-a246-b9e60c24d34a
  ID-4: /run/media/bernhard/Seagate ST2000DM006 raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 732.97 GiB (39.3%) fs: ntfs dev: /dev/sdb2
    maj-min: 8:18 label: Seagate ST2000DM006 uuid: AE58C6C858C68E91
  ID-1: swap-1 type: partition size: 17.1 GiB used: 256 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-21e703d9-f76c-4e28-bb5e-2e4ed9ab2646 label: swap
    uuid: 3ac7b8bf-e403-4439-a36f-4ce9f75dbd71
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: NO_LABEL
    uuid: 7FE8-A61D
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 459.54 GiB fs: btrfs label: N/A
    uuid: 8c0a770d-e913-4d71-aa45-1c00c3434e05
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 17.1 GiB fs: swap label: swap
    uuid: 39ba73a2-d39d-4825-85e1-7d07a5320d4a
  ID-4: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sdc2 maj-min: 8:34 size: 119.23 GiB fs: ntfs label: N/A
    uuid: AA8CDFD38CDF97E1
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Intel Hub ports: 6 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:800a class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8002 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 3-4:2 info: Canon LiDE 400 type: <vendor specific> driver: N/A
    interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04a9:1912
    class-ID: 0000 serial: <filter>
  Device-2: 3-11:8 info: RODE Microphones Podcaster type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.0
    speed: 12 Mb/s power: 100mA chip-ID: 19f7:0001 class-ID: 0300
  Device-3: 3-12:9 info: ROCCAT Kone AIMO Mouse type: Mouse,Keyboard
    power: 500mA chip-ID: 1e7d:2e27 class-ID: 0300
  Device-4: 3-14:10 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
    serial: <filter>
  Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Device-1: 4-6:2 info: Logitech BRIO Ultra HD Webcam type: Video,Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.1
    speed: 5 Gb/s power: 896mA chip-ID: 046d:085e class-ID: 0300
    serial: <filter>
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 403 Uptime: 4h 57m wakeups: 0 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1876
  pacman: 1838 lib: 504 flatpak: 38 Shell: Zsh v: 5.8.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.15
Here is the journal log:
Mai 12 13:10:59 bernhard-pc3 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mai 12 13:10:59 bernhard-pc3 kernel:   #7  #8  #9 #10 #11
Mai 12 13:10:59 bernhard-pc3 kernel: pmd_set_huge: Cannot satisfy [mem 0xf1000000-0xf1200000] with a huge-page mapping due to MTRR override.
Mai 12 13:10:59 bernhard-pc3 kernel: ata4.00: supports DRM functions and may not be fully accessible
Mai 12 13:10:59 bernhard-pc3 kernel: ata10.00: supports DRM functions and may not be fully accessible
Mai 12 13:10:59 bernhard-pc3 kernel: nvidia: loading out-of-tree module taints kernel.
Mai 12 13:10:59 bernhard-pc3 kernel: nvidia: module license 'NVIDIA' taints kernel.
Mai 12 13:10:59 bernhard-pc3 kernel: Disabling lock debugging due to kernel taint
Mai 12 13:10:59 bernhard-pc3 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  510.60.02  Wed Mar 16 11:24:05 UTC 2022
Mai 12 13:10:59 bernhard-pc3 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Mai 12 13:10:59 bernhard-pc3 kernel: usb 3-9: device descriptor read/64, error -71
Mai 12 13:10:59 bernhard-pc3 kernel: usb 3-9: Device not responding to setup address.
Mai 12 13:10:59 bernhard-pc3 kernel: usb 3-9: device not accepting address 5, error -71
Mai 12 13:10:59 bernhard-pc3 kernel: usb 3-9: device not accepting address 6, error -71
Mai 12 13:10:59 bernhard-pc3 kernel: usb usb3-port9: unable to enumerate USB device
Mai 12 13:10:59 bernhard-pc3 kernel: hid-generic 0003:19F7:0001.0002: No inputs registered, leaving
Mai 12 13:10:59 bernhard-pc3 kernel: VBoxNetAdp: Successfully started.
Mai 12 13:10:59 bernhard-pc3 kernel: VBoxNetFlt: Successfully started.
Mai 12 13:10:59 bernhard-pc3 systemd-vconsole-setup[418]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Mai 12 13:10:59 bernhard-pc3 systemd-vconsole-setup[418]: Fonts will not be copied to remaining consoles
Mai 12 13:11:14 bernhard-pc3 kernel: kauditd_printk_skb: 14 callbacks suppressed
Mai 12 13:11:14 bernhard-pc3 kernel: i2c i2c-6: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Mai 12 13:11:14 bernhard-pc3 kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Mai 12 13:11:14 bernhard-pc3 kernel: EDAC sbridge: Couldn't find mci handler
Mai 12 13:11:14 bernhard-pc3 kernel: EDAC sbridge: Failed to register device with error -19.
Mai 12 13:11:15 bernhard-pc3 kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Mai 12 13:11:15 bernhard-pc3 kernel: EDAC sbridge: Couldn't find mci handler
Mai 12 13:11:15 bernhard-pc3 kernel: EDAC sbridge: Failed to register device with error -19.
Mai 12 13:11:15 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 24000
Mai 12 13:11:15 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 32000
Mai 12 13:11:15 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 48000
Mai 12 13:11:15 bernhard-pc3 kernel: usb 3-11: 1:1: cannot get freq at ep 0x1
Mai 12 13:11:15 bernhard-pc3 kernel: usb 3-11: 2:1: cannot get freq at ep 0x82
Mai 12 13:11:15 bernhard-pc3 systemd-udevd[491]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Mai 12 13:11:16 bernhard-pc3 kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Mai 12 13:11:16 bernhard-pc3 kernel: EDAC sbridge: Couldn't find mci handler
Mai 12 13:11:16 bernhard-pc3 kernel: EDAC sbridge: Failed to register device with error -19.
Mai 12 13:11:16 bernhard-pc3 kernel: nvidia-gpu 0000:02:00.3: i2c timeout error e0000000
Mai 12 13:11:16 bernhard-pc3 kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
Mai 12 13:11:16 bernhard-pc3 kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
Mai 12 13:11:16 bernhard-pc3 kernel: ucsi_ccg: probe of 5-0008 failed with error -110
Mai 12 13:11:18 bernhard-pc3 wireplumber[1429]: Failed to set scheduler settings: Operation not permitted
Mai 12 13:11:19 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 48000
Mai 12 13:11:19 bernhard-pc3 kernel: usb 3-11: 1:1: cannot get freq at ep 0x1
Mai 12 13:11:21 bernhard-pc3 klauncher[1474]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mai 12 13:11:22 bernhard-pc3 kernel: kauditd_printk_skb: 48 callbacks suppressed
Mai 12 13:11:22 bernhard-pc3 backlighthelper[1671]: org.kde.powerdevil: no kernel backlight interface found
Mai 12 13:11:22 bernhard-pc3 akonadi_control[1727]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mai 12 13:11:23 bernhard-pc3 akonadiserver[1777]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mai 12 11:53:39 bernhard-pc3 kioslave5[5595]: kf.kio.slaves.trash: Directory "/run/media/bernhard/Seagate ST2000DM006/.Trash-1000" exists but didn't pass the security checks, can't use it
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:03:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:03:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:05:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:05:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:07:34 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:07:34 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:08:04 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:08:04 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:09:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:09:46 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:09:46 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:10:40 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:40 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:10:55 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:10:55 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:11:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:11:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:14:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:14:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:17:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:17:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
Mai 12 12:19:16 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:19:16 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:36:22 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:36:22 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Mai 12 12:37:15 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:37:15 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 12:39:26 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 12:39:26 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 12:41:00 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 12:45:57 bernhard-pc3 kernel: SUPR0GipMap: fGetGipCpu=0x1b
Mai 12 12:45:58 bernhard-pc3 kernel: vboxdrv: 000000007014a42a VMMR0.r0
Mai 12 12:45:58 bernhard-pc3 kernel: vboxdrv: 00000000e810bbb0 VBoxDDR0.r0
Mai 12 12:45:58 bernhard-pc3 kernel: vboxdrv: 00000000299f958e VBoxEhciR0.r0
Mai 12 12:45:58 bernhard-pc3 kernel: VMMR0InitVM: eflags=246 fKernelFeatures=0x0 (SUPKERNELFEATURES_SMAP=0)
Mai 12 13:03:16 bernhard-pc3 kernel: NVRM: GPU at PCI:0000:02:00: GPU-229711c0-10e0-fd13-7bba-6208983fa8d5
Mai 12 13:03:16 bernhard-pc3 kernel: NVRM: Xid (PCI:0000:02:00): 31, pid=2315, Ch 00000020, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x0_050df000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 13:08:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:08:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 13:09:01 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:16:10 bernhard-pc3 kernel: NVRM: Xid (PCI:0000:02:00): 31, pid=4317, Ch 00000050, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x0_05f91000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
Mai 12 13:29:28 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 13:29:29 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 13:29:29 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 13:30:01 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:31:31 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 13:39:35 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:35 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 13:39:43 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 13:39:43 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 13:40:56 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:48:07 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:54:25 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:54:28 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 13:54:38 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 14:05:58 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 48000
Mai 12 14:09:54 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:09:54 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:09:54 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:12:51 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:12:51 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 14:13:13 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 48000
Mai 12 14:14:14 bernhard-pc3 kernel: usb 4-6: current rate 16000 is different from the runtime rate 48000
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:19:32 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:19:32 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 14:20:12 bernhard-pc3 xdg-desktop-portal-kde[1770]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:22:45 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:22:45 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:23:03 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:03 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Mai 12 14:23:24 bernhard-pc3 kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Mai 12 14:23:24 bernhard-pc3 kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Mai 12 15:04:51 bernhard-pc3 pipewire-pulse[1743]: mod.protocol-pulse: client 0x56452510c5f0: send channel:4294967295 20, error -32: Broken pipe
Mai 12 16:03:15 bernhard-pc3 sudo[32292]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sda
Mai 12 16:03:15 bernhard-pc3 sudo[32294]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdb
Mai 12 16:03:15 bernhard-pc3 sudo[32296]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdc
Mai 12 16:03:15 bernhard-pc3 sudo[32298]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdd
Mai 12 16:08:24 bernhard-pc3 sudo[32683]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sda
Mai 12 16:08:24 bernhard-pc3 sudo[32686]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdb
Mai 12 16:08:24 bernhard-pc3 sudo[32689]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdc
Mai 12 16:08:24 bernhard-pc3 sudo[32692]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/hddtemp -nq -u C /dev/sdd
Mai 12 16:08:24 bernhard-pc3 sudo[32705]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/file -s /dev/sdb1
Mai 12 16:08:24 bernhard-pc3 sudo[32707]: bernhard : a password is required ; TTY=pts/4 ; PWD=/home/bernhard ; USER=root ; COMMAND=/sbin/file -s /dev/sdc1
Hope it help. :slightly_smiling_face:
Thanks,
Bernhard
AFAIK, /dev/sr* is for optical drives. And there are quite a lot of these errors here. So perhaps there is an optical device or something causing the holdup?
Nope, I disconnected the drive and nothing changed. Would have been really surprising tbh.
I’m still pretty sure it’s caused by the kernel, but it’s hard to confirm/debug.
May 13 06:15:53 Dell15R kernel: Buffer I/O error on dev sr0, logical block 1, async page read
This is caused by Wine. It specifically happens here when scanning with QuickPar.
Being a Wine dev, I’d say: That makes sense! :smiley:
*bump *
Since this didn’t yield any result, what are some other places where I might get an answer?
I guess asking on lkml is a bit overkill, since I can’t 100% confirm, if it’s really the kernel…
Thanks,
Bernhard
Are you really sure that it is kernel depended?
systemd-analyze critical-chain default.target
systemd-analyze blame
Pretty sure. (No issues with zen-kernel on Garuda!)
As a side note: No, it’s not slow because of LUKS…
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @17.809s
└─multi-user.target @17.809s
  └─snapd.service @17.268s +540ms
    └─basic.target @17.255s
      └─sockets.target @17.255s
        └─snapd.socket @17.253s +1ms
          └─sysinit.target @17.247s
            └─systemd-update-done.service @17.241s +6ms
              └─ldconfig.service @16.871s +368ms
                └─local-fs.target @16.870s
                  └─tmp.mount @16.868s +2ms
                    └─swap.target @16.866s
                      └─dev-mapper-luks\x2d21e703d9\x2df76c\x2d4e28\x2dbb5e\x2d2e4ed9ab2646.swap @16.854s +12ms
                        └─dev-mapper-luks\x2d21e703d9\x2df76c\x2d4e28\x2dbb5e\x2d2e4ed9ab2646.device @16.853s
16.410s dev-mapper-luks\x2dcd30fb77\x2de732\x2d4a06\x2db6a7\x2d5469cca30ecf.device
13.502s updatedb.service
 1.694s linux-module-cleanup.service
 1.207s systemd-random-seed.service
 1.159s packagekit.service
  587ms tlp.service
  540ms snapd.service
  507ms udisks2.service
  425ms run-media-bernhard-Seagate\x20ST2000DM006.mount
  406ms apparmor.service
  368ms ldconfig.service
  290ms ModemManager.service
  250ms plymouth-deactivate.service
  249ms plymouth-quit-wait.service
  249ms plymouth-quit.service
  207ms user@1000.service
  206ms NetworkManager-wait-online.service
  206ms systemd-journal-flush.service
  181ms systemd-udev-trigger.service
  171ms cups.service
  171ms polkit.service
  147ms lvm2-monitor.service
  146ms upower.service
  143ms systemd-modules-load.service
  118ms systemd-tmpfiles-setup.service
  114ms avahi-daemon.service
  112ms bluetooth.service
  104ms dbus.service
  104ms systemd-tmpfiles-clean.service
   98ms systemd-logind.service
   89ms systemd-journald.service
   82ms systemd-udevd.service
   81ms systemd-vconsole-setup.service
   73ms systemd-sysusers.service
   62ms NetworkManager.service
   61ms accounts-daemon.service
   54ms boot-efi.mount
   48ms plymouth-read-write.service
   41ms systemd-timesyncd.service
   40ms systemd-tmpfiles-setup-dev.service
   27ms modprobe@fuse.service
   26ms systemd-fsck@dev-disk-by\x2duuid-6961\x2dE4A7.service
   25ms pamac-daemon.service
   22ms plymouth-start.service
   21ms systemd-journal-catalog-update.service
   19ms alsa-restore.service
   14ms systemd-update-utmp.service
   13ms mnt-Games.mount
   13ms dev-hugepages.mount
   13ms ufw.service
   12ms dev-mqueue.mount
   12ms snapd.apparmor.service
   12ms dev-mapper-luks\x2d21e703d9\x2df76c\x2d4e28\x2dbb5e\x2d2e4ed9ab2646.swap
So linux-zen is at version 5.17 at archlinux: svntogit-packages/PKGBUILD at packages/linux-zen · archlinux/svntogit-packages · GitHub
But you are using:
So try a kernel upgrade:
sudo mhwd-kernel --install linux517
No difference with 5.17.
ok, garuda + linux-zen + luks boots in 5 sec. Then it must be some differences of the encryption algorithm.
Can you check this?
dmsetup table crypto <device>
It’s not an encryption issue because it also happens on a fresh Manjaro install without encryption.
Btw, I think I have to take the zen thing back: Iirc Endevaour also uses linux-zen and had the same slow boot issues as well. This begs the question, what’s the difference betweeen Endeavour unsing zen and Garuda (Dagonized) using zen? Only can think of btrfs right now.
Edit: I guess, I’ll ask on the Garuda forums, maybe they can answer my last question. (Hopefully I can find a solution for Manjaro, because I prefer it. :wink: )
I fixed the iowait issues by enabling fstrim.timer service. Tbh, I don’t really understand why this isn’t enabled by default. Even Debian does it…
