[Solved] Thinkpad X250 - Sabrent USB audio input
audio
#1
Hi,
New to Manjaro/Arch and having an issue getting audio input via a Sabrent USB soundcard. There is some input (via a mic) however it is very low and grainy. Output however is working perfectly!
I have installed pulseaudio and confirmed the levels are correct via pavucontrol.
Some system details below.
System:    Host: hostname Kernel: 4.19.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: i3 4.16
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 2OCLS2BT00 v: ThinkPad X250 serial: <filter>
           Mobo: LENOVO model: 2OCLS2BT00 v: 0B98417 WIN serial: <filter> UEFI [Legacy]: LENOVO v: N10ET33W (1.12 )
           date: 04/06/2015
Battery:   ID-1: BAT1 charge: 0 Wh condition: N/A model: N/A status: Unknown
CPU:       Topology: Dual Core model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell rev: 4 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
           Speed: 798 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 798 2: 798 3: 799 4: 800
^[[AGraphics:  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.3 driver: intel unloaded: modesetting tty: N/A
           OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) v: 4.5 Mesa 18.3.1 direct render: Yes
Audio:     Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:03.0
           Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0
           Sound Server: ALSA v: k4.19.13-1-MANJARO
Network:   Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: 3080 bus ID: 00:19.0
           IF: enp0s25 state: down mac: <filter>
           Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
Drives:    Local Storage: total: 119.24 GiB used: 15.53 GiB (13.0%)
           ID-1: /dev/sda vendor: SanDisk model: SD7SB3Q128G1001 size: 119.24 GiB
Partition: ID-1: / size: 108.21 GiB used: 15.53 GiB (14.4%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 50.5 C mobo: N/A
           Fan Speeds (RPM): cpu: 3683
Info:      Processes: 162 Uptime: 1m Memory: 7.50 GiB used: 335.3 MiB (4.4%) Init: systemd Compilers: gcc: 8.2.1 Shell: zsh
           v: 5.6.2 inxi: 3.0.28
The device is detected and can be seen under lsusb.
lsusb
Bus 001 Device 002: ID 8087:8001 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 005: ID 5986:0366 Acer, Inc
Bus 002 Device 004: ID 8087:0a2a Intel Corp.
Bus 002 Device 003: ID 138a:0017 Validity Sensors, Inc. VFS 5011 fingerprint sensor
Bus 002 Device 002: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I was previously using Ubuntu where the device was functioning perfectly on Kernal 4.18. Which showed the device as below.
lsusb
If anyone could point me in the right direction it would be appreciated.
Cheers!
#2
I have used alsa-info.sh to upload ALSA information to: http://www.alsa-project.org/db/?f=c3029bc3f676cbd624744f2810f472edde1f186f
#3
Well after looking at this for a week I just tried to reinstall pulseaudio and would you look at that everything is now working.
Thanks anyway!
#4
I didn’t know it was possible to reboot files, but there you go. :rofl:
"Have you tried turning it off and on installing it again?
