Hi all,
I just got notified during system update that kernel release 5.9.16 (5.9.16-1-MANJARO in my case) is the last 5.9 release, so I used the kernel manager gui to install 5.10.2-2-MANJARO.
Since I am using a Thinkpad E14 G2 laptop with AMD Renior CPU (see below for details), using a kernel older than 5.8 brings other implications – so simply switching to the latest LTS kernel is not an option, as this is a 5.4 series kernel.
Currently, I have both named kernels installed and can boot into either one.
System configuration details:
- I am using the shortly-suspend workaround for both kernels to get Fn keys working at all.
- The BIOS version installed on my machine is 1.08.
- BIOS is configured to use Fn key functionality (e.g. changing volume) only when “Fn” key is pressed, so I have F[1…12] behaviour as default action.
What does work on 5.9 and does not work on 5.10 is the following: - Sound output
- Fn keys (e.g. switching sound via Fn+F3 key)
inxi output (under 5.10.2-2-MANJARO):
$ inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=07137b52-d252-4c63-95e3-824440c8e13a rw quiet apparmor=1
security=apparmor resume=UUID=6cfccd53-5e9a-4db9-a7ca-0d648868e0f8
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20T6000MGE v: ThinkPad E14 Gen 2
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20T6000MGE serial: <filter> UEFI: LENOVO
v: R1AET32W (1.08 ) date: 08/14/2020
ID-1: BAT0 charge: 34.1 Wh condition: 45.9/45.0 Wh (102%) volts: 11.7/11.1
model: Sunwoda 5B10X025 type: Li-poly serial: <filter> status: Discharging
cycles: 33
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 L2 cache: 4 MiB
bogomips: 31948
Speed: 1398 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
1: 1398 2: 1397 3: 1397 4: 1397 5: 1397 6: 1395 7: 1397 8: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 04:00.0
chip ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
chip ID: 04f2:b6be serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.2-2-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.3.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 04:00.1
chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus ID: 03:00.0 chip ID: 8086:2723
Local Storage: total: 476.94 GiB used: 856.29 GiB (179.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNT512G MEMORY
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 0106AELA temp: 26.9 C
ID-1: / raw size: 50 GiB size: 48.97 GiB (97.93%) used: 17.08 GiB (34.9%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 29 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw size: 100 GiB size: 97.93 GiB (97.93%)
used: 76.24 GiB (77.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 36.9 C mobo: 0.0 C gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): cpu: 0
Processes: 294 Uptime: 3m wakeups: 1 Memory: 14.93 GiB used: 1.14 GiB (7.6%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1399 lib: 416
flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
Loaded sound modules:
$ lsmod|grep snd
snd_hda_codec_realtek 143360 0
snd_hda_codec_hdmi 73728 0
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
snd_hda_intel 57344 0
snd_intel_dspcfg 24576 1 snd_hda_intel
soundwire_intel 45056 1 snd_intel_dspcfg
snd_hda_codec 172032 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 106496 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep 16384 1 snd_hda_codec
snd_soc_core 323584 1 soundwire_intel
snd_compress 32768 1 snd_soc_core
ac97_bus 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_pcm 147456 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
ledtrig_audio 16384 2 snd_hda_codec_generic,thinkpad_acpi
snd_timer 45056 1 snd_pcm
snd_rn_pci_acp3x 20480 0
snd_pci_acp3x 20480 0
snd 114688 11 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,thinkpad_acpi,snd_soc_core,snd_pcm
soundcore 16384 1 snd
Error messages only present on 5.10.2-2-MANJARO:
sudo journalctl -x -p3 -b0
Dez 31 13:33:03 achtender kernel: hdaudio hdaudioC0D0: Unable to bind the codec
Dez 31 13:33:03 achtender kernel: hdaudio hdaudioC1D0: Unable to bind the codec
Your help and support is really appreciated.
Thanks and BR,
Boeschmann
