Hi, so I’m on Manjaro Xfce and am using the Radeon drivers, I would like to switch from the Radeon drivers to the AMDGPU drivers, but I don’t know how, I have a Dell Inspiron 3583 Laptop with an AMD Radeon 520 Graphics Card. Please tell me if you need more info and I’ll edit the post.
Edit:
It worked after I followed instruction on the Archwiki:
https://wiki.archlinux.org/index.php/AMDGPU#Specify_the_correct_module_order
inxi -Fza ouput:
Kernel: 5.10.13-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=ab5a55f2-c66c-40b1-b2ef-5bc65e78af9e ro quiet apparmor=1
security=apparmor udev.log_priority=3 radeon.si_support=0
amdgpu.si_support=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 3583 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0M15G0 v: A00 serial: <filter> UEFI: Dell v: 1.11.0
date: 06/03/2020
ID-1: BAT0 charge: 32.9 Wh condition: 32.9/42.0 Wh (78%) volts: 12.7/11.4
model: BYD DELL 1VX1H95 type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 6 MiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0 class ID: 0300
Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile]
vendor: Dell driver: amdgpu v: kernel alternate: radeon bus ID: 01:00.0
chip ID: 1002:6665 class ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:4 chip ID: 0bda:5520 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati,intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8 class ID: 0403
Sound Server: ALSA v: k5.10.13-2-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 3000 bus ID: 02:00.0 chip ID: 10ec:8136
class ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
chip ID: 168c:0042 class ID: 0280
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-10:5
chip ID: 0cf3:e009 class ID: e001
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus ID: 1-10:5
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 10.97 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS512G NVMe 512GB size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 10410105 temp: 30.9 C scheme: GPT
ID-1: / raw size: 100.14 GiB size: 98.07 GiB (97.93%)
used: 10.97 GiB (11.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw size: 499 MiB size: 498 MiB (99.80%)
used: 1.4 MiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 24.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 0
Processes: 228 Uptime: 16m wakeups: 3 Memory: 7.64 GiB
used: 1.93 GiB (25.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1220 lib: 401 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01```
mhwd -lh -d output:
```06: PCI 300.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:1d.1/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: network
Model: "Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter"
Vendor: pci 0x168c "Qualcomm Atheros"
Device: pci 0x0042 "QCA9377 802.11ac Wireless Network Adapter"
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x1810
Revision: 0x31
Driver: "ath10k_pci"
Driver Modules: "ath10k_pci"
Device File: wlp3s0
Memory Range: 0xc2000000-0xc21fffff (rw,non-prefetchable)
IRQ: 141 (11112 events)
HW Address: b0:68:e6:77:d3:d5
Permanent HW Address: b0:68:e6:77:d3:d5
Link detected: yes
Module Alias: "pci:v0000168Cd00000042sv00001028sd00001810bc02sc80i00"
Driver Info #0:
Driver Status: ath10k_pci is active
Driver Activation Cmd: "modprobe ath10k_pci"
Attached to: #13 (PCI bridge)
07: PCI 17.0: 0106 SATA controller (AHCI 1.0)
SysFS ID: /devices/pci0000:00/0000:00:17.0
SysFS BusID: 0000:00:17.0
Hardware Class: storage
Device Name: "Onboard - SATA"
Model: "Intel Cannon Point-LP SATA Controller [AHCI Mode]"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x9dd3 "Cannon Point-LP SATA Controller [AHCI Mode]"
SubDevice: pci 0x08ca
Revision: 0x30
Driver: "ahci"
Driver Modules: "ahci"
Memory Range: 0xc251c000-0xc251dfff (rw,non-prefetchable)
Memory Range: 0xc2523000-0xc25230ff (rw,non-prefetchable)
I/O Ports: 0x5090-0x5097 (rw)
I/O Ports: 0x5080-0x5083 (rw)
I/O Ports: 0x5060-0x507f (rw)
Memory Range: 0xc2522000-0xc25227ff (rw,non-prefetchable)
IRQ: 126 (no events)
Module Alias: "pci:v00008086d00009DD3sv00001028sd000008CAbc01sc06i01"
08: PCI 1c.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:1c.0
SysFS BusID: 0000:00:1c.0
Hardware Class: bridge
Model: "Intel Cannon Point-LP PCI Express Root Port #5"
Device: pci 0x9dbc "Cannon Point-LP PCI Express Root Port #5"
Revision: 0xf0
Driver: "pcieport"
IRQ: 122 (no events)
Module Alias: "pci:v00008086d00009DBCsv00001028sd000008CAbc06sc04i00"
09: PCI 08.0: 0880 System peripheral
SysFS ID: /devices/pci0000:00/0000:00:08.0
SysFS BusID: 0000:00:08.0
Hardware Class: unknown
Device Name: "Onboard - Other"
Model: "Intel Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model"
Device: pci 0x1911 "Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model"
Memory Range: 0xc2529000-0xc2529fff (rw,non-prefetchable,disabled)
IRQ: 255 (no events)
Module Alias: "pci:v00008086d00001911sv00001028sd000008CAbc08sc80i00"
10: PCI 15.1: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:15.1
SysFS BusID: 0000:00:15.1
Model: "Intel Cannon Point-LP Serial IO I2C Controller #1"
Device: pci 0x9de9 "Cannon Point-LP Serial IO I2C Controller #1"
Revision: 0x30
Driver: "intel-lpss"
Driver Modules: "intel_lpss_pci"
Memory Range: 0x9f801000-0x9f801fff (rw,non-prefetchable)
IRQ: 17 (no events)
Module Alias: "pci:v00008086d00009DE9sv00001028sd000008CAbc0Csc80i00"
Driver Info #0:
Driver Status: intel_lpss_pci is active
Driver Activation Cmd: "modprobe intel_lpss_pci"
11: PCI 1f.0: 0601 ISA bridge
SysFS ID: /devices/pci0000:00/0000:00:1f.0
SysFS BusID: 0000:00:1f.0
Model: "Intel Cannon Point-LP LPC Controller"
Device: pci 0x9d84 "Cannon Point-LP LPC Controller"
Revision: 0x30
Module Alias: "pci:v00008086d00009D84sv00001028sd000008CAbc06sc01i00"
12: PCI 200.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:1d.0/0000:02:00.0
SysFS BusID: 0000:02:00.0
Model: "Realtek RTL810xE PCI Express Fast Ethernet controller"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0x8136 "RTL810xE PCI Express Fast Ethernet controller"
Revision: 0x07
Driver: "r8169"
Driver Modules: "r8169"
Device File: enp2s0
I/O Ports: 0x3000-0x30ff (rw)
Memory Range: 0xc2404000-0xc2404fff (rw,non-prefetchable)
Memory Range: 0xc2400000-0xc2403fff (ro,non-prefetchable)
IRQ: 16 (1339118 events)
HW Address: d8:d0:90:5f:16:5d
Permanent HW Address: d8:d0:90:5f:16:5d
Link detected: no
Module Alias: "pci:v000010ECd00008136sv00001028sd000008CAbc02sc00i00"
Driver Info #0:
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Attached to: #24 (PCI bridge)
13: PCI 1d.1: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:1d.1
Model: "Intel Cannon Point-LP PCI Express Root Port #10"
Device: pci 0x9db1 "Cannon Point-LP PCI Express Root Port #10"
Revision: 0xf0
Driver: "pcieport"
IRQ: 124 (no events)
Module Alias: "pci:v00008086d00009DB1sv00001028sd000008CAbc06sc04i00"
14: PCI 04.0: 1180 Signal processing controller
SysFS ID: /devices/pci0000:00/0000:00:04.0
SysFS BusID: 0000:00:04.0
Model: "Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem"
Device: pci 0x1903 "Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem"
Revision: 0x0c
Driver: "proc_thermal"
Driver Modules: "processor_thermal_device"
Memory Range: 0xc2510000-0xc2517fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d00001903sv00001028sd000008CAbc11sc80i00"
Driver Info #0:
Driver Status: processor_thermal_device is active
Driver Activation Cmd: "modprobe processor_thermal_device"
15: PCI 16.0: 0780 Communication controller
SysFS ID: /devices/pci0000:00/0000:00:16.0
SysFS BusID: 0000:00:16.0
Model: "Intel Cannon Point-LP MEI Controller #1"
Device: pci 0x9de0 "Cannon Point-LP MEI Controller #1"
Revision: 0x30
Driver: "mei_me"
Driver Modules: "mei_me"
Memory Range: 0xc2524000-0xc2524fff (rw,non-prefetchable)
IRQ: 138 (44 events)
Module Alias: "pci:v00008086d00009DE0sv00001028sd000008CAbc07sc80i00"
Driver Info #0:
Driver Status: mei_me is active
Driver Activation Cmd: "modprobe mei_me"
16: PCI 100.0: 0380 Display controller
SysFS ID: /devices/pci0000:00/0000:00:1c.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "ATI Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile]"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x6665 "Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile]"
Revision: 0xc3
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
Memory Range: 0xc0000000-0xc003ffff (rw,non-prefetchable)
I/O Ports: 0x4000-0x40ff (rw)
Memory Range: 0xc0040000-0xc005ffff (ro,non-prefetchable,disabled)
IRQ: 136 (107 events)
Module Alias: "pci:v00001002d00006665sv00001028sd000008CAbc03sc80i00"
Driver Info #0:
Driver Status: radeon is active
Driver Activation Cmd: "modprobe radeon"
Driver Info #1:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Attached to: #8 (PCI bridge)
17: PCI 1f.5: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:1f.5
SysFS BusID: 0000:00:1f.5
Model: "Intel Cannon Point-LP SPI Controller"
Device: pci 0x9da4 "Cannon Point-LP SPI Controller"
Revision: 0x30
Memory Range: 0xfe010000-0xfe010fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d00009DA4sv00001028sd000008CAbc0Csc80i00"
18: PCI 19.0: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:19.0
SysFS BusID: 0000:00:19.0
Model: "Intel Cannon Point-LP Serial IO I2C Host Controller"
Device: pci 0x9dc5 "Cannon Point-LP Serial IO I2C Host Controller"
Revision: 0x30
Memory Range: 0x9f802000-0x9f802fff (rw,non-prefetchable)
IRQ: 32 (no events)
Module Alias: "pci:v00008086d00009DC5sv00001028sd000008CAbc0Csc80i00"
Driver Info #0:
19: PCI 1f.3: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Device Name: "Onboard - Sound"
Model: "Intel Cannon Point-LP High Definition Audio Controller"
Device: pci 0x9dc8 "Cannon Point-LP High Definition Audio Controller"
Revision: 0x30
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xc2518000-0xc251bfff (rw,non-prefetchable)
Memory Range: 0xc2200000-0xc22fffff (rw,non-prefetchable)
IRQ: 142 (935 events)
Module Alias: "pci:v00008086d00009DC8sv00001028sd000008CAbc04sc03i80"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_soc_skl is active
Driver Activation Cmd: "modprobe snd_soc_skl"
Driver Info #2:
Driver Status: snd_sof_pci is active
Driver Activation Cmd: "modprobe snd_sof_pci"
20: PCI 00.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:00.0
SysFS BusID: 0000:00:00.0
Model: "Intel Coffee Lake HOST and DRAM Controller"
Device: pci 0x3e34 "Coffee Lake HOST and DRAM Controller"
Revision: 0x0c
Driver: "skl_uncore"
Driver Modules: "intel_uncore"
Module Alias: "pci:v00008086d00003E34sv00001028sd000008CAbc06sc00i00"
21: PCI 12.0: 1180 Signal processing controller
SysFS ID: /devices/pci0000:00/0000:00:12.0
SysFS BusID: 0000:00:12.0
Model: "Intel Cannon Point-LP Thermal Controller"
Device: pci 0x9df9 "Cannon Point-LP Thermal Controller"
Revision: 0x30
Driver: "intel_pch_thermal"
Driver Modules: "intel_pch_thermal"
Memory Range: 0xc2528000-0xc2528fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d00009DF9sv00001028sd000008CAbc11sc80i00"
Driver Info #0:
Driver Status: intel_pch_thermal is active
Driver Activation Cmd: "modprobe intel_pch_thermal"
22: PCI 1d.4: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:1d.4
SysFS BusID: 0000:00:1d.4
Model: "Intel Cannon Point-LP PCI Express Root Port #13"
Device: pci 0x9db4 "Cannon Point-LP PCI Express Root Port #13"
Revision: 0xf0
Driver: "pcieport"
IRQ: 125 (no events)
Module Alias: "pci:v00008086d00009DB4sv00001028sd000008CAbc06sc04i00"
23: PCI 15.0: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:15.0
SysFS BusID: 0000:00:15.0
Model: "Intel Cannon Point-LP Serial IO I2C Controller #0"
Device: pci 0x9de8 "Cannon Point-LP Serial IO I2C Controller #0"
Revision: 0x30
Memory Range: 0x9f800000-0x9f800fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d00009DE8sv00001028sd000008CAbc0Csc80i00"
Driver Info #0:
24: PCI 1d.0: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:1d.0
Model: "Intel Cannon Point-LP PCI Express Root Port #9"
Device: pci 0x9db0 "Cannon Point-LP PCI Express Root Port #9"
Revision: 0xf0
Driver: "pcieport"
IRQ: 123 (no events)
Module Alias: "pci:v00008086d00009DB0sv00001028sd000008CAbc06sc04i00"
25: PCI 14.2: 0500 RAM memory
SysFS ID: /devices/pci0000:00/0000:00:14.2
SysFS BusID: 0000:00:14.2
Model: "Intel Cannon Point-LP Shared SRAM"
Device: pci 0x9def "Cannon Point-LP Shared SRAM"
Revision: 0x30
Memory Range: 0xc251e000-0xc251ffff (rw,non-prefetchable,disabled)
Memory Range: 0xc2527000-0xc2527fff (rw,non-prefetchable,disabled)
Module Alias: "pci:v00008086d00009DEFsv00001028sd000008CAbc05sc00i00"
26: PCI 400.0: 0108 Non-Volatile memory controller (NVM Express)
SysFS ID: /devices/pci0000:00/0000:00:1d.4/0000:04:00.0
SysFS BusID: 0000:04:00.0
Model: "KIOXIA Non-Volatile memory controller"
Vendor: pci 0x1e0f "KIOXIA Corporation"
Device: pci 0x0001
SubVendor: pci 0x1e0f "KIOXIA Corporation"
SubDevice: pci 0x0001
Driver: "nvme"
Driver Modules: "nvme"
Memory Range: 0xc2300000-0xc2303fff (rw,non-prefetchable)
Module Alias: "pci:v00001E0Fd00000001sv00001E0Fsd00000001bc01sc08i02"
Attached to: #22 (PCI bridge)
27: PCI 02.0: 0300 VGA compatible controller (VGA)
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Onboard - Video"
Model: "Intel UHD Graphics 620 (Whiskey Lake)"
Device: pci 0x3ea0 "UHD Graphics 620 (Whiskey Lake)"
Revision: 0x02
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xc1000000-0xc1ffffff (rw,non-prefetchable)
Memory Range: 0xa0000000-0xafffffff (ro,non-prefetchable)
I/O Ports: 0x5000-0x503f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 140 (149188 events)
Module Alias: "pci:v00008086d00003EA0sv00001028sd000008CAbc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
28: PCI 14.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Hardware Class: usb controller
Model: "Intel Cannon Point-LP USB 3.1 xHCI Controller"
Device: pci 0x9ded "Cannon Point-LP USB 3.1 xHCI Controller"
Revision: 0x30
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0xc2500000-0xc250ffff (rw,non-prefetchable)
IRQ: 137 (264 events)
Module Alias: "pci:v00008086d00009DEDsv00001028sd000008CAbc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
29: PCI 1f.4: 0c05 SMBus
SysFS ID: /devices/pci0000:00/0000:00:1f.4
SysFS BusID: 0000:00:1f.4
Model: "Intel Cannon Point-LP SMBus Controller"
Device: pci 0x9da3 "Cannon Point-LP SMBus Controller"
Revision: 0x30
Driver: "i801_smbus"
Driver Modules: "i2c_i801"
Memory Range: 0xc2520000-0xc25200ff (rw,non-prefetchable)
I/O Ports: 0xefa0-0xefbf (rw)
Module Alias: "pci:v00008086d00009DA3sv00001028sd000008CAbc0Csc05i00"
Driver Info #0:
Driver Status: i2c_i801 is active
Driver Activation Cmd: "modprobe i2c_i801"
02: USB 00.0: 11500 Bluetooth Device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0
SysFS BusID: 1-10:1.0
Hardware Class: bluetooth
Model: "Qualcomm Atheros Bluetooth Device"
Hotplug: USB
Vendor: usb 0x0cf3 "Qualcomm Atheros Communications"
Device: usb 0xe009
Revision: "0.01"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v0CF3pE009d0001dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Attached to: #6 (Hub)
03: USB 00.0: 10f01 WebCam
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0
SysFS BusID: 1-2:1.0
Hardware Class: camera
Model: "Samsung Electronics Galaxy series, misc. (MTP mode)"
Hotplug: USB
Vendor: usb 0x04e8 "Samsung Electronics Co., Ltd"
Device: usb 0x6860 "Galaxy series, misc. (MTP mode)"
Revision: "4.00"
Serial ID: "R58N40PQWKK"
Speed: 480 Mbps
Module Alias: "usb:v04E8p6860d0400dc00dsc00dp00ic06isc01ip01in00"
04: USB 00.0: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0
SysFS BusID: 1-6:1.0
Model: "Realtek Integrated_Webcam_HD"
Hotplug: USB
Vendor: usb 0x0bda "Realtek Semiconductor Corp."
Device: usb 0x5520 "Integrated_Webcam_HD"
Revision: "85.11"
Serial ID: "200901010001"
Driver: "uvcvideo"
Driver Modules: "uvcvideo"
Device File: /dev/input/event19
Device Files: /dev/input/event19, /dev/input/by-id/usb-CNFHH46P25342016C900_Integrated_Webcam_HD_200901010001-event-if00, /dev/input/by-path/pci-0000:00:14.0-usb-0:6:1.0-event
Device Number: char 13:83
Speed: 480 Mbps
Module Alias: "usb:v0BDAp5520d8511dcEFdsc02dp01ic0Eisc01ip00in00"
Driver Info #0:
Driver Status: uvcvideo is active
Driver Activation Cmd: "modprobe uvcvideo"
06: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-0:1.0
SysFS BusID: 1-0:1.0
Hardware Class: hub
Model: "Linux Foundation 2.0 root hub"
Hotplug: USB
Vendor: usb 0x1d6b "Linux Foundation"
Device: usb 0x0002 "2.0 root hub"
Revision: "5.10"
Serial ID: "0000:00:14.0"
Driver: "hub"
Driver Modules: "usbcore"
Speed: 480 Mbps
Module Alias: "usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00"
08: USB 00.0: 10800 Keyboard
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0
SysFS BusID: 1-1:1.0
Hardware Class: keyboard
Model: "Dell Model L100 Keyboard"
Hotplug: USB
Vendor: usb 0x413c "Dell Computer Corp."
Device: usb 0x2105 "Model L100 Keyboard"
Revision: "3.50"
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/event12
Device Files: /dev/input/event12, /dev/input/by-id/usb-Dell_Dell_USB_Keyboard-event-kbd, /dev/input/by-path/pci-0000:00:14.0-usb-0:1:1.0-event-kbd
Device Number: char 13:76
Speed: 1.5 Mbps
Module Alias: "usb:v413Cp2105d0350dc00dsc00dp00ic03isc01ip01in00"
Driver Info #0:
XkbRules: xfree86
XkbModel: pc104
09: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb2/2-0:1.0
SysFS BusID: 2-0:1.0
Hardware Class: hub
Model: "Linux Foundation 3.0 root hub"
Hotplug: USB
Device: usb 0x0003 "3.0 root hub"
Revision: "5.10"
Driver: "hub"
Module Alias: "usb:v1D6Bp0003d0510dc09dsc00dp03ic09isc00ip00in00"```
`mhwd -li -d` output:
``` NAME: video-linux
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
Warning: no installed configs for USB devices found!```
