[Solved] Some transmission package don't find libeevent
I found an error in some packges in my manjaro for arm in my pinebook for transmission making these programs unable to find libevent.
For example transmission-cli gives this message
[leandro@pinobianco ~]$ transmission-cli
transmission-cli: error while loading shared libraries: libevent-2.1.so.6: cannot open shared object file: No such file or directory
And ldd confirms this message:
[leandro@pinobianco ~]$ ldd /usr/bin/transmission-cli
[Some libraries]
libevent-2.1.so.6 => not found
The same for transmission-gtk
Instead transmission-remote works well.
Thanks for reporting.
The transmission packages did not get updated in the repo.
But I just fixed it, so the transmission 2.94-2 packages should work, when the mirrors sync.
Yes, I can confirm the transmission-cli and transmission-gtk work fine now!
Thanks!
