Hello i`m new to the forum, and i hope someone can help me.
Yesterday i did a pacman -Syu but everything froze… i tried to redo the update via chroot but i get this output:
pacman: error while loading shared libraries: /usr/lib/libcurl.so.4: file too short
Your filesystem may be damaged. Boot up from the live USB, but do notchroot or mount your root filesystem. Open up a terminal window and run an fsck on the root filesystem instead.
Only when the root filesystem checks out clean can you try chrooting and updating your system that way.
[manjaro-gnome /]# pacman-mirrors -f && pacman -Syyu
/usr/bin/pacman-mirrors: line 20: from: command not found
/usr/bin/pacman-mirrors: line 21: from: command not found
/usr/bin/pacman-mirrors: line 23: _: command not found
/usr/bin/pacman-mirrors: line 26: try:: command not found
/usr/bin/pacman-mirrors: line 27: syntax error near unexpected token `('
/usr/bin/pacman-mirrors: line 27: ` pm = pacman_mirrors.PacmanMirrors()'
the second cmd does not go though
any suggestions?
