[SOLVED] Random freezes when resuming from suspend
"usb-devices " is a command.
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh=12
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev=04.14
S:  Manufacturer=Linux 4.14.102-1-MANJARO xhci-hcd
S:  Product=xHCI Host Controller
S:  SerialNumber=0000:00:14.0
C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
T:  Bus=01 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#=  6 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=0bda ProdID=58c2 Rev=62.02
S:  Manufacturer=CN0JCXG0724876CKA1VYA00
S:  Product=Integrated_Webcam_HD
S:  SerialNumber=200901010001
C:  #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=0e(video) Sub=01 Prot=00 Driver=uvcvideo
I:  If#=0x1 Alt= 0 #EPs= 0 Cls=0e(video) Sub=02 Prot=00 Driver=uvcvideo
T:  Bus=01 Lev=01 Prnt=01 Port=05 Cnt=02 Dev#=  7 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=8087 ProdID=0a2a Rev=00.01
C:  #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:  If#=0x0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I:  If#=0x1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
T:  Bus=01 Lev=01 Prnt=01 Port=06 Cnt=03 Dev#=  8 Spd=12  MxCh= 0
D:  Ver= 2.01 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=2386 ProdID=3111 Rev=00.00
S:  Manufacturer=Raydium Corporation
S:  Product=Raydium Touch System
C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=96mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=03(HID  ) Sub=00 Prot=00 Driver=usbhid
T:  Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#=  9 Spd=480 MxCh= 0
P:  Vendor=0bda ProdID=0177 Rev=77.11
S:  Manufacturer=Generic
S:  Product=USB2.0-CRW
S:  SerialNumber=20121112761000000
C:  #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=ums-realtek
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=5000 MxCh= 6
D:  Ver= 3.00 Cls=09(hub  ) Sub=00 Prot=03 MxPS= 9 #Cfgs=  1
P:  Vendor=1d6b ProdID=0003 Rev=04.14
See what happens when you run this command:
sudo rmmod usbhid && sleep 20 && sudo modprobe usbhid
Test your kb and trackpad operation after running that command (if successful).
Also, please post:
lsmod
Should it be “modprobe” instead of “modprbe”?
Sorry that was a typo. I found out that module was associated to your touchsreen driver. It could also be linked to your kb as many of these type devices have an “hid” suffix.
Please post:
udevadm info --export-db | grep -i keyboard
lsmod
E: NAME="AT Translated Set 2 keyboard"
E: ID_INPUT_KEYBOARD=1
E: KEYBOARD_KEY_81=playpause
E: KEYBOARD_KEY_82=stopcd
E: KEYBOARD_KEY_83=previoussong
E: KEYBOARD_KEY_84=nextsong
E: KEYBOARD_KEY_85=brightnessdown
E: KEYBOARD_KEY_86=brightnessup
E: KEYBOARD_KEY_87=battery
E: KEYBOARD_KEY_88=unknown
E: KEYBOARD_KEY_89=ejectclosecd
E: KEYBOARD_KEY_8a=suspend
E: KEYBOARD_KEY_8b=switchvideomode
E: KEYBOARD_KEY_8c=unknown
E: KEYBOARD_KEY_8f=switchvideomode
E: KEYBOARD_KEY_90=previoussong
E: KEYBOARD_KEY_91=prog1
E: KEYBOARD_KEY_92=media
E: KEYBOARD_KEY_93=unknown
E: KEYBOARD_KEY_95=camera
E: KEYBOARD_KEY_97=email
E: KEYBOARD_KEY_98=f21
E: KEYBOARD_KEY_99=nextsong
E: KEYBOARD_KEY_9a=setup
E: KEYBOARD_KEY_9b=switchvideomode
E: KEYBOARD_KEY_9e=f21
E: KEYBOARD_KEY_a2=playpause
E: KEYBOARD_KEY_a4=stopcd
E: KEYBOARD_KEY_d8=screenlock
E: KEYBOARD_KEY_d9=f21
E: KEYBOARD_KEY_ed=media
Module                  Size  Used by
btrfs                1339392  0
zstd_compress         180224  1 btrfs
zstd_decompress        81920  1 btrfs
xxhash                 16384  2 zstd_compress,zstd_decompress
xor                    24576  1 btrfs
raid6_pq              122880  1 btrfs
ufs                    86016  0
hfsplus               118784  0
hfs                    69632  0
minix                  40960  0
ntfs                  225280  0
msdos                  20480  0
jfs                   208896  0
xfs                  1445888  0
libcrc32c              16384  1 xfs
rfcomm                 86016  16
ccm                    20480  9
fuse                  118784  3
arc4                   16384  2
iwlmvm                344064  0
snd_hda_codec_hdmi     57344  1
mac80211              905216  1 iwlmvm
iwlwifi               311296  1 iwlmvm
snd_hda_codec_realtek   110592  1
snd_hda_codec_generic    86016  1 snd_hda_codec_realtek
bnep                   24576  2
cfg80211              733184  3 iwlmvm,iwlwifi,mac80211
snd_soc_skl            94208  0
snd_soc_skl_ipc        73728  1 snd_soc_skl
snd_soc_sst_ipc        16384  1 snd_soc_skl_ipc
snd_soc_sst_dsp        36864  1 snd_soc_skl_ipc
snd_hda_ext_core       28672  1 snd_soc_skl
snd_soc_sst_match      16384  1 snd_soc_skl
snd_soc_core          266240  1 snd_soc_skl
iTCO_wdt               16384  0
snd_compress           24576  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
iTCO_vendor_support    16384  1 iTCO_wdt
hid_sensor_rotation    16384  0
hid_sensor_magn_3d     16384  0
hid_sensor_incl_3d     16384  0
hid_sensor_gyro_3d     16384  0
hid_sensor_accel_3d    16384  0
hid_sensor_trigger     16384  11 hid_sensor_gyro_3d,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
industrialio_triggered_buffer    16384  5 hid_sensor_gyro_3d,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
kfifo_buf              16384  1 industrialio_triggered_buffer
hid_sensor_iio_common    16384  6 hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
nls_iso8859_1          16384  1
industrialio           81920  8 industrialio_triggered_buffer,hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_incl_3d,kfifo_buf,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
nls_cp437              20480  1
vfat                   20480  1
fat                    81920  2 msdos,vfat
hid_sensor_hub         20480  7 hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_iio_common,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
idma64                 20480  0
intel_ishtp_hid        24576  0
msr                    16384  0
uvcvideo              102400  0
btusb                  53248  0
videobuf2_vmalloc      16384  1 uvcvideo
btrtl                  16384  1 btusb
videobuf2_memops       16384  1 videobuf2_vmalloc
btbcm                  16384  1 btusb
videobuf2_v4l2         28672  1 uvcvideo
btintel                16384  1 btusb
videobuf2_core         45056  2 videobuf2_v4l2,uvcvideo
videodev              208896  3 videobuf2_core,videobuf2_v4l2,uvcvideo
bluetooth             634880  41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
joydev                 24576  0
i915                 1937408  8
media                  45056  2 videodev,uvcvideo
dell_wmi               16384  0
mousedev               24576  0
wmi_bmof               16384  0
ecdh_generic           24576  1 bluetooth
snd_hda_intel          45056  3
intel_rapl             24576  0
x86_pkg_temp_thermal    16384  0
intel_powerclamp       16384  0
coretemp               16384  0
snd_hda_codec         151552  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
dell_laptop            24576  1
dell_smbios            16384  2 dell_wmi,dell_laptop
i2c_algo_bit           16384  1 i915
kvm_intel             233472  0
rfkill                 28672  7 bluetooth,dell_laptop,cfg80211
dcdbas                 16384  1 dell_smbios
drm_kms_helper        196608  1 i915
dell_smm_hwmon         16384  0
snd_hda_core           90112  7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_skl
snd_hwdep              16384  1 snd_hda_codec
kvm                   712704  1 kvm_intel
snd_pcm               118784  8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd_timer              36864  1 snd_pcm
drm                   434176  6 drm_kms_helper,i915
evdev                  24576  18
input_leds             16384  0
led_class              16384  3 input_leds,iwlmvm,dell_laptop
mac_hid                16384  0
psmouse               172032  0
irqbypass              16384  1 kvm
intel_cstate           16384  0
intel_rapl_perf        16384  0
snd                    94208  16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
i2c_i801               28672  0
pcspkr                 16384  0
soundcore              16384  1 snd
shpchp                 40960  0
intel_gtt              24576  1 i915
intel_lpss_pci         20480  0
agpgart                49152  2 intel_gtt,drm
processor_thermal_device    16384  0
mei_me                 45056  0
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
intel_soc_dts_iosf     16384  1 processor_thermal_device
sysimgblt              16384  1 drm_kms_helper
mei                   114688  1 mei_me
fb_sys_fops            16384  1 drm_kms_helper
intel_pch_thermal      16384  0
intel_lpss             16384  1 intel_lpss_pci
intel_ish_ipc          20480  0
wmi                    28672  2 dell_wmi,wmi_bmof
thermal                20480  0
intel_ishtp            45056  2 intel_ishtp_hid,intel_ish_ipc
i2c_hid                24576  0
battery                20480  0
soc_button_array       16384  0
int3403_thermal        16384  0
intel_vbtn             16384  0
tpm_crb                16384  0
video                  45056  3 dell_wmi,dell_laptop,i915
tpm_tis                16384  0
intel_hid              16384  0
tpm_tis_core           20480  1 tpm_tis
pinctrl_sunrisepoint    28672  0
sparse_keymap          16384  3 intel_hid,dell_wmi,intel_vbtn
int3402_thermal        16384  0
int3400_thermal        16384  0
pinctrl_intel          24576  1 pinctrl_sunrisepoint
tpm                    65536  3 tpm_tis,tpm_crb,tpm_tis_core
int340x_thermal_zone    16384  3 int3403_thermal,int3402_thermal,processor_thermal_device
acpi_thermal_rel       16384  1 int3400_thermal
acpi_pad               16384  0
ac                     16384  0
pcc_cpufreq            16384  0
button                 16384  0
sch_fq_codel           20480  5
uinput                 20480  0
pci_stub               16384  1
vboxpci                28672  0
vboxnetflt             32768  0
vboxnetadp             28672  0
vboxdrv               499712  3 vboxpci,vboxnetadp,vboxnetflt
crypto_user            16384  0
ip_tables              28672  0
x_tables               45056  1 ip_tables
ext4                  720896  1
crc32c_generic         16384  0
crc16                  16384  2 bluetooth,ext4
mbcache                16384  1 ext4
jbd2                  118784  1 ext4
fscrypto               32768  1 ext4
algif_skcipher         16384  0
af_alg                 28672  1 algif_skcipher
ums_realtek            20480  0
uas                    28672  0
usb_storage            73728  2 uas,ums_realtek
hid_multitouch         24576  0
hid                   131072  4 i2c_hid,hid_multitouch,hid_sensor_hub,intel_ishtp_hid
dm_crypt               40960  2
dm_mod                143360  5 dm_crypt
sd_mod                 61440  4
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
crc32c_intel           24576  4
ghash_clmulni_intel    16384  0
pcbc                   16384  0
serio_raw              16384  0
atkbd                  32768  0
libps2                 16384  2 atkbd,psmouse
ahci                   40960  3
libahci                40960  1 ahci
aesni_intel           188416  10
aes_x86_64             20480  1 aesni_intel
crypto_simd            16384  1 aesni_intel
xhci_pci               16384  0
glue_helper            16384  1 aesni_intel
libata                278528  2 libahci,ahci
cryptd                 28672  5 crypto_simd,ghash_clmulni_intel,aesni_intel
xhci_hcd              245760  1 xhci_pci
scsi_mod              212992  4 sd_mod,usb_storage,uas,libata
usbcore               286720  7 xhci_hcd,usb_storage,uvcvideo,btusb,xhci_pci,uas,ums_realtek
usb_common             16384  1 usbcore
i8042                  32768  1 dell_laptop
serio                  28672  6 serio_raw,atkbd,psmouse,i8042
Run:
sudo rmmod psmouse && sleep 20 && sudo modprobe psmouse
Test your trackpad operation after running that command. Post any errors and the effect of the command.
Run:
sudo rmmod i2c_hid && sleep 20 && sudo modprobe i2c_hid
Both commands do not produce errors. The trackpad works as expected after both.
Anyway, if things work fine with pre-419 kernels, that’s enough for the moment. 414 will stop being maintained in one year, but 4.4 will be maintained until January 2023. I will have changed this laptop by then… :wink:
Update.
Kernel 501 seems to have fixed the regression. I’ve been using it for a few days without experiencing freezes. Fingers crossed.
