For Hibernation you need a Swap Partition (or a Swap File).
The contents of the RAM are written to that Swap space when the system is hibernated.
If that 128 GB RAM of yours is fully used
and you want to then hibernate the system
you need about as much Swap, but likely only half of that because the data is being written in compressed form - 150 GB are too much - but will do. Just a lot of wasted space …
Swap space doesn’t have a file system, so: no
don’t format it as ext4.
You “format” it as Swap.
It is all in that wiki you linked to.
… on wakeup from hibernation, these 150 GB need to be read back,
which will take time.
Not an issue with an NVME - but still a waste of valuable space that cannot be used for “real” things … IMO (in my opinion)
When an initramfs with the base hook is used, which is the default, the resume hook is required in /etc/mkinitcpio.conf. Whether by label or by UUID, the swap partition is referred to with a udev device node, so the resume hook must go after the udev hook. This example was made starting from the default hook configuration:
regenerate it mkinitcpio -P
Then you add the uuid of the swap partition as kernel parameter
Required kernel parameters
The kernel parameter resume=swap_device must be used. Any of the persistent block device naming methods can be used as swap_device. For example:
resume=UUID=4209c845-f495-4c43-8a03-5363dd433153
and since that last one was in the line GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub
you have to regenerate that too sudo update-grub
