For the last week or so I have noticed plasmashell is using around 33% CPU and Xorg around 16%
I have a 4 core machine, so that is about two whole cores.
It happens as soon as I log in, I suspect it is related to a recent update.
What can I do to resolve this?
Thanks,
Ian
I second that notion. After the last update, plasmashell and lattedock are using each ~30% CPU (as shown in $ top). I will reinstall soon and see, if I can narrow the problem down, but any help would be much appreciated.
Cheers
Julius
Tomek
29 November 2020 11:50
3
What cpu?
Plasma and other programs are starting so higher temporary cpu usage is obvious. You can disable desktop effects and startup programs.
KDE Plasma Version: 5.20.3
KDE Frameworks Version: 5.76.0
Qt Version: 5.15.2
Kernel Version: 5.8.18-1-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-2320 CPU @ 3.00GHz
Memory: 15.5 GiB of RAM
Graphics Processor: NVCE
Sorry I didn’t explain clearly. I wanted to convey that the high CPU usage is from straight after logon and doesn’t go down even hours later.
I have fixed it by using propitiatory drivers
Qt Version: 5.15.2
OS Type: 64-bit
Graphics Processor: GeForce GTX 555/PCIe/SSE2
