Mai 20 20:02:41 peddaahhKDE kernel: Linux version 5.15.38-1-MANJARO (builduser@fv-az38-945) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 9 07:52:21 UTC 2022
Mai 20 20:02:41 peddaahhKDE kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=ac415d4d-78df-4489-9bb0-0d9169da9b8c rw quiet apparmor=1 security=apparmor udev.log_priority=3
Mai 20 20:02:41 peddaahhKDE kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Mai 20 20:02:41 peddaahhKDE kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
Mai 20 20:02:41 peddaahhKDE kernel: x86/cpu: SGX disabled by BIOS.
Mai 20 20:02:41 peddaahhKDE kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mai 20 20:02:41 peddaahhKDE kernel: #7 #8 #9 #10 #11
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=2000 audit(1653069758.026:1): state=initialized audit_enabled=0 res=1
Mai 20 20:02:41 peddaahhKDE kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mai 20 20:02:41 peddaahhKDE kernel: ACPI Error: No handler for Region [VRTC] (000000003bd0be6b) [SystemCMOS] (20210730/evregion-130)
Mai 20 20:02:41 peddaahhKDE kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20210730/exfldio-261)
Mai 20 20:02:41 peddaahhKDE kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0.RTEC due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
Mai 20 20:02:41 peddaahhKDE kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._REG due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
Mai 20 20:02:41 peddaahhKDE kernel: SCSI subsystem initialized
Mai 20 20:02:41 peddaahhKDE kernel: VFS: Disk quotas dquot_6.6.0
Mai 20 20:02:41 peddaahhKDE kernel: Initialise system trusted keyrings
Mai 20 20:02:41 peddaahhKDE kernel: Key type blacklist registered
Mai 20 20:02:41 peddaahhKDE kernel: Key type asymmetric registered
Mai 20 20:02:41 peddaahhKDE kernel: Asymmetric key parser 'x509' registered
Mai 20 20:02:41 peddaahhKDE kernel: hpet_acpi_add: no address or irqs in _CRS
Mai 20 20:02:41 peddaahhKDE kernel: Loading compiled-in X.509 certificates
Mai 20 20:02:41 peddaahhKDE kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 1a38abe742a4d3b383eb89e2d4c7a2540cf16ee9'
Mai 20 20:02:41 peddaahhKDE kernel: Key type ._fscrypt registered
Mai 20 20:02:41 peddaahhKDE kernel: Key type .fscrypt registered
Mai 20 20:02:41 peddaahhKDE kernel: Key type fscrypt-provisioning registered
Mai 20 20:02:41 peddaahhKDE kernel: ata5.00: supports DRM functions and may not be fully accessible
Mai 20 20:02:41 peddaahhKDE kernel: scsi 4:0:0:0: Direct-Access ATA CT1000MX500SSD1 010 PQ: 0 ANSI: 5
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] 4096-byte physical blocks
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] Write Protect is off
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] supports TCG Opal
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: [sda] Attached SCSI disk
Mai 20 20:02:41 peddaahhKDE kernel: random: fast init done
Mai 20 20:02:41 peddaahhKDE kernel: random: lvm: uninitialized urandom read (4 bytes read)
Mai 20 20:02:41 peddaahhKDE kernel: sd 4:0:0:0: Attached scsi generic sg0 type 0
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1130 audit(1653069761.406:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.423:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=349 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.426:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=349 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.426:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=348 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE systemd-random-seed[343]: Kernel entropy pool is not initialized yet, waiting until it is.
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.443:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=351 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.453:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=352 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1400 audit(1653069761.476:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=350 comm="apparmor_parser"
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1130 audit(1653069761.476:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:41 peddaahhKDE kernel: audit: type=1130 audit(1653069761.483:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:41 peddaahhKDE systemd-journald[355]: File /var/log/journal/33fb46690d034c4b931224441a0fc5c8/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 20 20:02:41 peddaahhKDE kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Mai 20 20:02:41 peddaahhKDE razer_mount[566]: Driver razerkbd
Mai 20 20:02:41 peddaahhKDE razer_mount[567]: Device_ID 1-8
Mai 20 20:02:41 peddaahhKDE kernel: razerkbd: loading out-of-tree module taints kernel.
Mai 20 20:02:41 peddaahhKDE razer_mount[568]: Modprobing razerkbd
Mai 20 20:02:41 peddaahhKDE kernel: razerkbd: module verification failed: signature and/or required key missing - tainting kernel
Mai 20 20:02:41 peddaahhKDE kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mai 20 20:02:41 peddaahhKDE kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mai 20 20:02:42 peddaahhKDE razer_mount[586]: Modprobed razerkbd
Mai 20 20:02:42 peddaahhKDE kernel: Creating 1 MTD partitions on "0000:00:1f.5":
Mai 20 20:02:42 peddaahhKDE kernel: 0x000000000000-0x000001000000 : "BIOS"
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Mai 20 20:02:42 peddaahhKDE kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Mai 20 20:02:42 peddaahhKDE razer_mount[601]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[602]: Device_ID 1-8:1.1
Mai 20 20:02:42 peddaahhKDE razer_mount[604]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[605]: Device_ID 1-8:1.2
Mai 20 20:02:42 peddaahhKDE razer_mount[607]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[608]: Device_ID 1-8:1.0
Mai 20 20:02:42 peddaahhKDE kernel: i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
Mai 20 20:02:42 peddaahhKDE kernel: i915 0000:00:02.0: [drm] [ENCODER:113:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
Mai 20 20:02:42 peddaahhKDE razer_mount[655]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[656]: Device_ID 0003:1532:0246.0001
Mai 20 20:02:42 peddaahhKDE razer_mount[657]: Changing group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0001/
Mai 20 20:02:42 peddaahhKDE razer_mount[661]: Changed group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0001/
Mai 20 20:02:42 peddaahhKDE razer_mount[665]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[666]: Device_ID 0003:1532:0246.0003
Mai 20 20:02:42 peddaahhKDE razer_mount[667]: Changing group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0003/
Mai 20 20:02:42 peddaahhKDE razer_mount[670]: Driver razerkbd
Mai 20 20:02:42 peddaahhKDE razer_mount[671]: Changed group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0003/
Mai 20 20:02:42 peddaahhKDE razer_mount[672]: Device_ID 0003:1532:0246.0004
Mai 20 20:02:42 peddaahhKDE razer_mount[673]: Changing group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0004/
Mai 20 20:02:42 peddaahhKDE razer_mount[675]: Changed group /sys/bus/hid/drivers/razerkbd/0003:1532:0246.0004/
Mai 20 20:02:42 peddaahhKDE kernel: random: crng init done
Mai 20 20:02:42 peddaahhKDE kernel: random: 7 urandom warning(s) missed due to ratelimiting
Mai 20 20:02:43 peddaahhKDE kernel: dell_smbios: Unable to run on non-Dell system
Mai 20 20:02:43 peddaahhKDE kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Loading rules from directory /etc/polkit-1/rules.d
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Error opening rules directory: Error opening directory “/etc/polkit-1/rules.d”: Permission denied (g-file-error-quark, 2)
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Loading rules from directory /usr/share/polkit-1/rules.d
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Error opening rules directory: Error opening directory “/usr/share/polkit-1/rules.d”: Permission denied (g-file-error-quark, 2)
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Finished loading, compiling and executing 0 rules
Mai 20 20:02:43 peddaahhKDE polkitd[783]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Mai 20 20:02:43 peddaahhKDE bluetoothd[778]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:44 peddaahhKDE kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Mai 20 20:02:44 peddaahhKDE kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
Mai 20 20:02:44 peddaahhKDE kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
Mai 20 20:02:44 peddaahhKDE kernel: ucsi_ccg: probe of 0-0008 failed with error -110
Mai 20 20:02:44 peddaahhKDE kernel: kauditd_printk_skb: 176 callbacks suppressed
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1130 audit(1653069764.116:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1130 audit(1653069764.139:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1325 audit(1653069764.149:101): table=firewalld:7 family=1 entries=1 op=nft_register_table pid=876 subj==unconfined comm="firewalld"
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1300 audit(1653069764.149:101): arch=c000003e syscall=46 success=yes exit=84 a0=6 a1=7ffc7a707450 a2=0 a3=7ffc7a6f62ec items=0 ppid=1 pid=876 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="firewalld" exe="/usr/bin/python3.10" subj==unconfined key=(null)
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1327 audit(1653069764.149:101): proctitle=2F7573722F62696E2F707974686F6E002F7573722F62696E2F6669726577616C6C64002D2D6E6F666F726B002D2D6E6F706964
Mai 20 20:02:44 peddaahhKDE kernel: nvidia: module license 'NVIDIA' taints kernel.
Mai 20 20:02:44 peddaahhKDE kernel: Disabling lock debugging due to kernel taint
Mai 20 20:02:44 peddaahhKDE kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.103.01 Thu Jan 6 12:10:04 UTC 2022
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1325 audit(1653069764.163:102): table=firewalld:8 family=1 entries=394 op=nft_register_obj pid=876 subj==unconfined comm="firewalld"
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1325 audit(1653069764.163:102): table=firewalld:8 family=1 entries=333 op=nft_register_chain pid=876 subj==unconfined comm="firewalld"
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1300 audit(1653069764.163:102): arch=c000003e syscall=46 success=yes exit=37416 a0=6 a1=7ffc7a707450 a2=0 a3=7ffc7a6f62ec items=0 ppid=1 pid=876 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="firewalld" exe="/usr/bin/python3.10" subj==unconfined key=(null)
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1327 audit(1653069764.163:102): proctitle=2F7573722F62696E2F707974686F6E002F7573722F62696E2F6669726577616C6C64002D2D6E6F666F726B002D2D6E6F706964
Mai 20 20:02:44 peddaahhKDE kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Mai 20 20:02:44 peddaahhKDE kernel: audit: type=1325 audit(1653069764.743:103): table=filter:9 family=2 entries=2 op=nft_register_chain pid=1109 subj==unconfined comm="iptables"
Mai 20 20:02:44 peddaahhKDE libvirtd[954]: cannot open directory '/run/media/peddaahh/01D7BA2F4A37D040': No such file or directory
Mai 20 20:02:44 peddaahhKDE libvirtd[954]: internal error: Failed to autostart storage pool '01D7BA2F4A37D040': cannot open directory '/run/media/peddaahh/01D7BA2F4A37D040': No such file or directory
Mai 20 20:02:45 peddaahhKDE kernel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
Mai 20 20:02:49 peddaahhKDE kernel: kauditd_printk_skb: 147 callbacks suppressed
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1130 audit(1653069769.179:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1101 audit(1653069769.199:158): pid=1285 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1103 audit(1653069769.199:159): pid=1285 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1006 audit(1653069769.199:160): pid=1285 uid=0 subj==unconfined old-auid=4294967295 auid=963 tty=(none) old-ses=4294967295 ses=1 res=1
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1300 audit(1653069769.199:160): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd10caf4d0 a2=3 a3=0 items=0 ppid=1 pid=1285 auid=963 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1327 audit(1653069769.199:160): proctitle="(systemd)"
Mai 20 20:02:49 peddaahhKDE systemd[1285]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1105 audit(1653069769.206:161): pid=1285 uid=0 auid=963 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:49 peddaahhKDE systemd[1285]: Failed to open configuration file '/var/lib/sddm/.config/systemd/user.conf': Permission denied
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1334 audit(1653069769.219:162): prog-id=21 op=LOAD
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1300 audit(1653069769.219:162): arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffe668382f0 a2=78 a3=7ffe668382f0 items=0 ppid=1 pid=1285 auid=963 uid=963 gid=963 euid=963 suid=963 fsuid=963 egid=963 sgid=963 fsgid=963 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Mai 20 20:02:49 peddaahhKDE kernel: audit: type=1327 audit(1653069769.219:162): proctitle="(systemd)"
Mai 20 20:02:49 peddaahhKDE systemd-xdg-autostart-generator[1291]: Opening /var/lib/sddm/.config/autostart failed, ignoring: Permission denied
Mai 20 20:02:49 peddaahhKDE systemd[1285]: Failed to open "/var/lib/sddm/.config/systemd/user.control", ignoring: Permission denied
Mai 20 20:02:49 peddaahhKDE systemd[1285]: Failed to open "/var/lib/sddm/.config/systemd/user", ignoring: Permission denied
Mai 20 20:02:49 peddaahhKDE systemd[1285]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Mai 20 20:02:49 peddaahhKDE systemd[1285]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Mai 20 20:02:49 peddaahhKDE systemd[1285]: Failed to start Update XDG user dir configuration.
Mai 20 20:02:49 peddaahhKDE sddm-helper[1294]: Could not open stderr to "/var/lib/sddm/.local/share/sddm/xorg-session.log"
Mai 20 20:02:49 peddaahhKDE sddm-greeter[1294]: QFont::fromString: Invalid description '(empty)'
Mai 20 20:02:49 peddaahhKDE sddm-greeter[1294]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe5ce253f0), parent's thread is QThread(0x55ab029ae390), current thread is QThread(0x55ab02a9d770)
Mai 20 20:02:49 peddaahhKDE sddm-greeter[1294]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Mai 20 20:02:49 peddaahhKDE sddm-greeter[1294]: inotify_add_watch(/var/lib/sddm/.config) failed: (Permission denied)
Mai 20 20:02:49 peddaahhKDE sddm-greeter[1294]: Failed to establish shared memory mapping, will fallback to private memory -- memory usage will increase
Mai 20 20:02:50 peddaahhKDE udisksd[1302]: udisks daemon version 2.9.4 starting
Mai 20 20:02:50 peddaahhKDE udisksd[1302]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Mai 20 20:02:50 peddaahhKDE upowerd[1312]: energy_full (74,166400) is greater than energy_full_design (70,840000)
Mai 20 20:02:50 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:452:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Mai 20 20:02:50 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Login.qml:103:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Mai 20 20:02:51 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:65:17: Unable to assign [undefined] to QColor
Mai 20 20:02:51 peddaahhKDE sddm-greeter[1294]: Failed to establish shared memory mapping, will fallback to private memory -- memory usage will increase
Mai 20 20:02:51 peddaahhKDE sddm-greeter[1294]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.26'
Mai 20 20:02:51 peddaahhKDE sddm-greeter[1294]: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Mai 20 20:02:51 peddaahhKDE kernel: Bridge firewalling registered
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.7 (nf_tables): Chain 'DOCKER' does not exist
Try `iptables -h' or 'iptables --help' for more information.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER' failed: iptables v1.8.7 (nf_tables): Chain 'DOCKER' does not exist
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.7 (nf_tables): Chain 'DOCKER' does not exist
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING' failed: iptables: Bad rule (does a matching rule exist in that chain?).
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -F DOCKER' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -X DOCKER' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION-STAGE-1' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION-STAGE-1' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION-STAGE-2' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION-STAGE-2' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION' failed: iptables: No chain/target/match by that name.
Mai 20 20:02:51 peddaahhKDE firewalld[876]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -D FORWARD -i docker0 -o docker0 -j DROP' failed: iptables: Bad rule (does a matching rule exist in that chain?).
Mai 20 20:02:52 peddaahhKDE tlp[1502]: Error in configuration at INTEL_GPU_MIN_FREQ_ON_AC="300": frequency invalid or out of range (see 'tlp-stat -g').
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:420: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/Battery.qml:27: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:158: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/ActionButton.qml:102: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/ActionButton.qml:39: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/ActionButton.qml:55: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/ActionButton.qml:41: TypeError: Cannot read property 'largeSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/ActionButton.qml:42: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Login.qml:120: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Login.qml:115: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/SessionManagementScreen.qml:84: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/SessionManagementScreen.qml:114: TypeError: Cannot read property 'largeSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/SessionManagementScreen.qml:100: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/SessionManagementScreen.qml:101: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/SessionManagementScreen.qml:91: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:103: TypeError: Cannot read property 'largeSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:69: TypeError: Cannot read property 'largeSpacing' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:95: TypeError: Cannot read property 'gridUnit' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:75: TypeError: Cannot read property 'longDuration' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:239: TypeError: Cannot read property 'longDuration' of null
Mai 20 20:02:53 peddaahhKDE sddm-greeter[1294]: file:///usr/share/sddm/themes/ArchLinux_SDDM_ku7/Main.qml:425: TypeError: Cannot read property 'longDuration' of null
Mai 20 20:02:53 peddaahhKDE systemd[1673]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[peddaahh] ruser=[<unknown>] rhost=[<unknown>]
Mai 20 20:02:53 peddaahhKDE systemd-xdg-autostart-generator[1679]: /home/peddaahh/.config/autostart/thunderbird.desktop:1: Unknown section 'Desktop Action ComposeMessage'. Ignoring.
Mai 20 20:02:53 peddaahhKDE systemd-journald[355]: File /var/log/journal/33fb46690d034c4b931224441a0fc5c8/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Mai 20 20:02:53 peddaahhKDE systemd-xdg-autostart-generator[1679]: /home/peddaahh/.config/autostart/thunderbird.desktop:5: Unknown section 'Desktop Action OpenAddressBook'. Ignoring.
Mai 20 20:02:53 peddaahhKDE systemd-xdg-autostart-generator[1679]: /home/peddaahh/.config/autostart/thunderbird.desktop:10: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Mai 20 20:02:53 peddaahhKDE systemd-xdg-autostart-generator[1679]: Configuration file /home/peddaahh/.config/autostart/slimbookbattery-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Mai 20 20:02:53 peddaahhKDE systemd[1673]: onedrive.service: Main process exited, code=exited, status=1/FAILURE
Mai 20 20:02:53 peddaahhKDE systemd[1673]: onedrive.service: Failed with result 'exit-code'.
Mai 20 20:02:54 peddaahhKDE startplasma-x11[1691]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Mai 20 20:02:54 peddaahhKDE ksplashqml[1702]: file:///home/peddaahh/.local/share/plasma/look-and-feel/com.github.vinceliuice.Orchis/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
Mai 20 20:02:54 peddaahhKDE ksplashqml[1702]: file:///home/peddaahh/.local/share/plasma/look-and-feel/com.github.vinceliuice.Orchis/contents/splash/Splash.qml:88: ReferenceError: bottomRect is not defined
Mai 20 20:02:54 peddaahhKDE startplasma-x11[1691]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Mai 20 20:02:54 peddaahhKDE startplasma-x11[1691]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Mai 20 20:02:54 peddaahhKDE systemd-xdg-autostart-generator[1730]: /home/peddaahh/.config/autostart/thunderbird.desktop:1: Unknown section 'Desktop Action ComposeMessage'. Ignoring.
Mai 20 20:02:54 peddaahhKDE systemd-xdg-autostart-generator[1730]: /home/peddaahh/.config/autostart/thunderbird.desktop:5: Unknown section 'Desktop Action OpenAddressBook'. Ignoring.
Mai 20 20:02:54 peddaahhKDE systemd-xdg-autostart-generator[1730]: /home/peddaahh/.config/autostart/thunderbird.desktop:10: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Mai 20 20:02:54 peddaahhKDE systemd-xdg-autostart-generator[1730]: Configuration file /home/peddaahh/.config/autostart/slimbookbattery-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Mai 20 20:02:55 peddaahhKDE NetworkManager[948]: <warn> [1653069775.0725] device (wlo1): no secrets: No agents were available for this request.
Mai 20 20:02:55 peddaahhKDE NetworkManager[948]: <warn> [1653069775.0730] device (wlo1): Activation: failed for connection 'WLAN'
Mai 20 20:02:55 peddaahhKDE klauncher[1738]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mai 20 20:02:55 peddaahhKDE kcminit_startup[1742]: QDBusConnection: error: could not send signal to service "" path "//home/peddaahh/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/peddaahh/.kde4/share/config/kdeglobals
Mai 20 20:02:55 peddaahhKDE kded5[1750]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Mai 20 20:02:55 peddaahhKDE kded5[1750]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Mai 20 20:02:55 peddaahhKDE kded5[1750]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Mai 20 20:02:56 peddaahhKDE kwin_x11[1753]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Mai 20 20:02:56 peddaahhKDE kwin_x11[1753]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Mai 20 20:02:56 peddaahhKDE ksmserver[1767]: Qt: Session management error: networkIdsList argument is NULL
Mai 20 20:02:57 peddaahhKDE kded5[1750]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.11'
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 491, resource id: 64, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 492, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 493, resource id: 161, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 494, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 495, resource id: 1600511211, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 496, resource id: 5, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:57 peddaahhKDE bluetoothd[778]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:57 peddaahhKDE bluetoothd[778]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:57 peddaahhKDE bluetoothd[778]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:57 peddaahhKDE bluetoothd[778]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:57 peddaahhKDE bluetoothd[778]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Mai 20 20:02:57 peddaahhKDE kernel: kauditd_printk_skb: 157 callbacks suppressed
Mai 20 20:02:57 peddaahhKDE kernel: audit: type=1130 audit(1653069777.443:230): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:57 peddaahhKDE polkitd[783]: Registered Authentication Agent for unix-session:2 (system bus name :1.41 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Mai 20 20:02:57 peddaahhKDE kwalletd5[1690]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Mai 20 20:02:57 peddaahhKDE kwalletd5[1910]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
Mai 20 20:02:57 peddaahhKDE kded5[1750]: kscreen.kded: PowerDevil SuspendSession action not available!
Mai 20 20:02:58 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: org.kde.powerdevil.discretegpuhelper.hasdualgpu failed
Mai 20 20:02:58 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "DBus Backend error: service start org.kde.powerdevil.chargethresholdhelper failed: Failed to execute program org.kde.powerdevil.chargethresholdhelper: Permission denied"
Mai 20 20:02:58 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Mai 20 20:02:58 peddaahhKDE bluetoothd[778]: Failed to set mode: Blocked through rfkill (0x12)
Mai 20 20:02:58 peddaahhKDE kded5[1750]: kf.bluezqt: PendingCall Error: "Blocked through rfkill"
Mai 20 20:02:58 peddaahhKDE fingerprint-polkit-agent[1854]: "Cannot register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject"
Mai 20 20:02:58 peddaahhKDE fingerprint-polkit-agent[1854]: Could not register listener "/fingerprintgui/PolicyKit1/AuthenticationAgent". Aborting.
Mai 20 20:02:58 peddaahhKDE kwalletd5[1690]: Application ' "kded5" ' using kwallet without parent window!
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 10 (BadAccess), sequence: 870, resource id: 639, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 989, resource id: 54525956, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1057, resource id: 54525957, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1082, resource id: -1006600144, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1083, resource id: 32695, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1084, resource id: 37, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1085, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1086, resource id: -1006605120, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: kwin_core: XCB error: 147 (BadOutput), sequence: 1087, resource id: 32695, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Mai 20 20:02:58 peddaahhKDE pulseaudio[1827]: stat('/etc/pulse/default.pa.d'): No such file or directory
Mai 20 20:02:58 peddaahhKDE systemd[1673]: xdg-document-portal.service: Main process exited, code=exited, status=6/NOTCONFIGURED
Mai 20 20:02:58 peddaahhKDE systemd[1673]: xdg-document-portal.service: Failed with result 'exit-code'.
Mai 20 20:02:58 peddaahhKDE kwin_x11[1753]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Mai 20 20:02:59 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mai 20 20:02:59 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Mai 20 20:02:59 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: The profile "AC" tried to activate "BrightnessControl" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Mai 20 20:02:59 peddaahhKDE org_kde_powerdevil[1804]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "DBus Backend error: service start org.kde.powerdevil.chargethresholdhelper failed: Failed to execute program org.kde.powerdevil.chargethresholdhelper: Permission denied"
Mai 20 20:02:59 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1528, resource id: 71303172, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:02:59 peddaahhKDE kernel: audit: type=1105 audit(1653069779.203:231): pid=2229 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:59 peddaahhKDE pkexec[2229]: peddaahh: Executing command [USER=root] [TTY=unknown] [CWD=/home/peddaahh] [COMMAND=/usr/bin/slimbookbattery-pkexec autostart]
Mai 20 20:02:59 peddaahhKDE kernel: audit: type=1130 audit(1653069779.316:232): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:02:59 peddaahhKDE plasmashell[1798]: qml: JSON.parse: Parse error
Mai 20 20:02:59 peddaahhKDE plasmashell[1798]: qml: load backend: backend/Scene.qml
Mai 20 20:02:59 peddaahhKDE kernel: audit: type=1334 audit(1653069779.886:233): prog-id=25 op=LOAD
Mai 20 20:02:59 peddaahhKDE kernel: audit: type=1334 audit(1653069779.886:234): prog-id=26 op=LOAD
Mai 20 20:02:59 peddaahhKDE kernel: audit: type=1334 audit(1653069779.886:235): prog-id=27 op=LOAD
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Mai 20 20:03:00 peddaahhKDE kernel: audit: type=1130 audit(1653069780.019:236): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:00 peddaahhKDE kernel: audit: type=1334 audit(1653069780.053:237): prog-id=28 op=LOAD
Mai 20 20:03:00 peddaahhKDE kernel: audit: type=1130 audit(1653069780.153:238): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: QProcess: Destroyed while process ("/bin/sh") is still running.
Mai 20 20:03:00 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2689, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///home/peddaahh/.local/share/plasma/plasmoids/com.pajuelo.plasmaConfSaver/contents/ui/FullRepresentation.qml:36:33: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///home/peddaahh/.local/share/plasma/plasmoids/com.pajuelo.plasmaConfSaver/contents/ui/FullRepresentation.qml:32:33: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///home/peddaahh/.local/share/plasma/plasmoids/com.pajuelo.plasmaConfSaver/contents/ui/FullRepresentation.qml:31:33: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///home/peddaahh/.local/share/plasma/plasmoids/com.pajuelo.plasmaConfSaver/contents/ui/FullRepresentation.qml:30:31: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///home/peddaahh/.local/share/plasma/plasmoids/com.pajuelo.plasmaConfSaver/contents/ui/main.qml:23: TypeError: Cannot call method 'substr' of undefined
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Mai 20 20:03:00 peddaahhKDE plasmashell[1798]: qml: ----python helper connected----
Mai 20 20:03:01 peddaahhKDE plasmashell[1798]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Mai 20 20:03:01 peddaahhKDE kernel: audit: type=1131 audit(1653069781.583:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:01 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Mai 20 20:03:01 peddaahhKDE plasmashell[1798]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mai 20 20:03:02 peddaahhKDE plasmashell[1798]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Mai 20 20:03:02 peddaahhKDE plasmashell[1798]: qml: QQuickGridView_QML_219(0x5575079f6b30)
Mai 20 20:03:03 peddaahhKDE plasmashell[1798]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55750921cf70) QQmlContext(0x5575088cf7e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mai 20 20:03:03 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Mai 20 20:03:03 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Mai 20 20:03:03 peddaahhKDE plasmashell[1798]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5575092b1ff0) QQmlContext(0x5575088cf7e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mai 20 20:03:03 peddaahhKDE systemd[1286]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Mai 20 20:03:03 peddaahhKDE kernel: audit: type=1131 audit(1653069783.459:240): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5493, resource id: 44040259, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5494, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5495, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5496, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5497, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5501, resource id: 44040259, major code: 3 (GetWindowAttributes), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5502, resource id: 44040259, major code: 14 (GetGeometry), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5503, resource id: 44040259, major code: 8 (MapWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5504, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5505, resource id: 44040259, major code: 12 (ConfigureWindow), minor code: 0
Mai 20 20:03:03 peddaahhKDE kernel: audit: type=1131 audit(1653069783.513:241): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:03 peddaahhKDE plasmashell[1798]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x557508ed0ec0) QQmlContext(0x5575088cf7e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mai 20 20:03:08 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17104, resource id: 44040283, major code: 15 (QueryTree), minor code: 0
Mai 20 20:03:13 peddaahhKDE plasmashell[1798]: kf.service.services: The action "QuitTeams" in the desktop file "/var/lib/snapd/desktop/applications/teams_teams.desktop" has no Name or no Exec key
Mai 20 20:03:13 peddaahhKDE plasmashell[1798]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Mai 20 20:03:13 peddaahhKDE plasmashell[1798]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Mai 20 20:03:13 peddaahhKDE kernel: audit: type=1131 audit(1653069793.959:242): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.033:243): prog-id=0 op=UNLOAD
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.033:244): prog-id=0 op=UNLOAD
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.033:245): prog-id=0 op=UNLOAD
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1131 audit(1653069794.069:246): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.183:247): prog-id=0 op=UNLOAD
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.183:248): prog-id=0 op=UNLOAD
Mai 20 20:03:14 peddaahhKDE kernel: audit: type=1334 audit(1653069794.183:249): prog-id=0 op=UNLOAD
Mai 20 20:03:15 peddaahhKDE plasmashell[1798]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5575085832a0) QQmlContext(0x5575088cf7e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mai 20 20:03:15 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Mai 20 20:03:15 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Mai 20 20:03:15 peddaahhKDE kernel: audit: type=1325 audit(1653069795.176:250): table=firewalld:97 family=1 entries=6 op=nft_register_rule pid=876 subj==unconfined comm="firewalld"
Mai 20 20:03:15 peddaahhKDE kernel: audit: type=1300 audit(1653069795.176:250): arch=c000003e syscall=46 success=yes exit=1396 a0=6 a1=7ffc7a706ac0 a2=0 a3=7ffc7a6f595c items=0 ppid=1 pid=876 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="firewalld" exe="/usr/bin/python3.10" subj==unconfined key=(null)
Mai 20 20:03:17 peddaahhKDE plasmashell[1798]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5575082c8d50) QQmlContext(0x5575088cf7e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Mai 20 20:03:17 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Mai 20 20:03:17 peddaahhKDE plasmashell[1798]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Mai 20 20:03:17 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30403, resource id: 44040334, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:03:18 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31793, resource id: 44040335, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:03:18 peddaahhKDE geoclue[2246]: Failed to query location: No WiFi networks found
Mai 20 20:03:19 peddaahhKDE xdg-desktop-por[2013]: Error reading netlink message: Error on netlink socket: Error receiving message: No buffer space available
Mai 20 20:03:19 peddaahhKDE kernel: kauditd_printk_skb: 25 callbacks suppressed
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.499:261): table=cloudflare-warp:102 family=1 entries=172 op=nft_register_chain pid=3537 subj==unconfined comm="nft"
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.499:261): table=cloudflare-warp:102 family=1 entries=60 op=nft_unregister_table pid=3537 subj==unconfined comm="nft"
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1300 audit(1653069799.499:261): arch=c000003e syscall=46 success=yes exit=54544 a0=3 a1=7ffebd641820 a2=0 a3=7f6a97af9ae8 items=0 ppid=790 pid=3537 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="nft" exe="/usr/bin/nft" subj==unconfined key=(null)
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1327 audit(1653069799.499:261): proctitle=6E6674002D66002D
Mai 20 20:03:19 peddaahhKDE geoclue[2246]: Error reading netlink message: Error on netlink socket: Error receiving message: No buffer space available
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.563:262): table=cloudflare-warp:103 family=1 entries=166 op=nft_register_chain pid=3553 subj==unconfined comm="nft"
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.563:262): table=cloudflare-warp:103 family=1 entries=172 op=nft_unregister_table pid=3553 subj==unconfined comm="nft"
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1300 audit(1653069799.563:262): arch=c000003e syscall=46 success=yes exit=53032 a0=3 a1=7ffc9d7e38d0 a2=0 a3=7fa7f6d50ae8 items=0 ppid=790 pid=3553 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="nft" exe="/usr/bin/nft" subj==unconfined key=(null)
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1327 audit(1653069799.563:262): proctitle=6E6674002D66002D
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.586:263): table=cloudflare-warp:104 family=1 entries=130 op=nft_register_chain pid=3563 subj==unconfined comm="nft"
Mai 20 20:03:19 peddaahhKDE kernel: audit: type=1325 audit(1653069799.586:263): table=cloudflare-warp:104 family=1 entries=166 op=nft_unregister_table pid=3563 subj==unconfined comm="nft"
Mai 20 20:03:24 peddaahhKDE geoclue[2246]: Failed to query location: No WiFi networks found
Mai 20 20:03:25 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44576, resource id: 44040292, major code: 15 (QueryTree), minor code: 0
Mai 20 20:03:27 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48292, resource id: 44040327, major code: 15 (QueryTree), minor code: 0
Mai 20 20:03:30 peddaahhKDE kernel: kauditd_printk_skb: 14 callbacks suppressed
Mai 20 20:03:30 peddaahhKDE kernel: audit: type=1131 audit(1653069810.053:267): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:30 peddaahhKDE kernel: audit: type=1334 audit(1653069810.186:268): prog-id=0 op=UNLOAD
Mai 20 20:03:30 peddaahhKDE kernel: audit: type=1334 audit(1653069810.186:269): prog-id=0 op=UNLOAD
Mai 20 20:03:30 peddaahhKDE kernel: audit: type=1334 audit(1653069810.186:270): prog-id=0 op=UNLOAD
Mai 20 20:03:34 peddaahhKDE kernel: audit: type=1131 audit(1653069814.699:271): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:37 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59827, resource id: 71303169, major code: 15 (QueryTree), minor code: 0
Mai 20 20:03:41 peddaahhKDE ktraderclient5[4091]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-477175586805252107" not found
Mai 20 20:03:47 peddaahhKDE kernel: audit: type=1131 audit(1653069827.771:272): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:03:47 peddaahhKDE kernel: audit: type=1334 audit(1653069827.853:273): prog-id=0 op=UNLOAD
Mai 20 20:03:47 peddaahhKDE kernel: audit: type=1334 audit(1653069827.853:274): prog-id=0 op=UNLOAD
Mai 20 20:03:47 peddaahhKDE kernel: audit: type=1334 audit(1653069827.853:275): prog-id=0 op=UNLOAD
Mai 20 20:04:44 peddaahhKDE kernel: audit: type=1131 audit(1653069884.228:276): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:04:49 peddaahhKDE plasmashell[1798]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mai 20 20:04:49 peddaahhKDE baloorunner[4245]: QFSFileEngine::open: No file name specified
Mai 20 20:04:50 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14777, resource id: 44040372, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:05:01 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22611, resource id: 121636839, major code: 15 (QueryTree), minor code: 0
Mai 20 20:05:28 peddaahhKDE kstart5[4701]: Omitting both --window and --windowclass arguments is not recommended
Mai 20 20:05:28 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41406, resource id: 125829129, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:05:39 peddaahhKDE kernel: audit: type=1100 audit(1653069939.174:277): pid=4760 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="peddaahh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Mai 20 20:05:39 peddaahhKDE sudo[4760]: peddaahh : TTY=pts/1 ; PWD=/home/peddaahh ; USER=root ; COMMAND=/usr/bin/pacman -S fuse2 gtkmm linux-headers pcsclite libcanberra
Mai 20 20:05:39 peddaahhKDE kernel: audit: type=1101 audit(1653069939.177:278): pid=4760 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="peddaahh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Mai 20 20:05:39 peddaahhKDE kernel: audit: type=1110 audit(1653069939.177:279): pid=4760 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Mai 20 20:05:39 peddaahhKDE kernel: audit: type=1105 audit(1653069939.184:280): pid=4760 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:281): prog-id=33 op=LOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:282): prog-id=34 op=LOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:283): prog-id=0 op=UNLOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:284): prog-id=0 op=UNLOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:285): prog-id=35 op=LOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.124:286): prog-id=0 op=UNLOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.134:287): prog-id=36 op=LOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.134:288): prog-id=0 op=UNLOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.134:289): prog-id=37 op=LOAD
Mai 20 20:06:04 peddaahhKDE kernel: audit: type=1334 audit(1653069964.134:290): prog-id=38 op=LOAD
Mai 20 20:06:12 peddaahhKDE kstart5[5218]: Omitting both --window and --windowclass arguments is not recommended
Mai 20 20:06:12 peddaahhKDE kwin_x11[1753]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63011, resource id: 127926281, major code: 18 (ChangeProperty), minor code: 0
Mai 20 20:06:14 peddaahhKDE kernel: kauditd_printk_skb: 20 callbacks suppressed
Mai 20 20:06:14 peddaahhKDE kernel: audit: type=1334 audit(1653069974.590:311): prog-id=48 op=LOAD
Mai 20 20:06:14 peddaahhKDE kernel: audit: type=1334 audit(1653069974.590:312): prog-id=49 op=LOAD
Mai 20 20:06:14 peddaahhKDE kernel: audit: type=1334 audit(1653069974.590:313): prog-id=50 op=LOAD
Mai 20 20:06:14 peddaahhKDE kernel: audit: type=1130 audit(1653069974.690:314): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mai 20 20:06:16 peddaahhKDE sudo[5691]: peddaahh : TTY=pts/2 ; PWD=/home/peddaahh ; USER=root ; COMMAND=/usr/bin/journalctl --boot=0 --priority=5 --no-pager
Mai 20 20:06:16 peddaahhKDE kernel: audit: type=1100 audit(1653069976.740:315): pid=5691 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="peddaahh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mai 20 20:06:16 peddaahhKDE kernel: audit: type=1101 audit(1653069976.740:316): pid=5691 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="peddaahh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mai 20 20:06:16 peddaahhKDE kernel: audit: type=1110 audit(1653069976.740:317): pid=5691 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Mai 20 20:06:16 peddaahhKDE kernel: audit: type=1105 audit(1653069976.744:318): pid=5691 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
