[SOLVED] Octopi: command finished with errors!
#21
Couple of ways from the terminal
Using pacman …
pacman -Si kdesu
This only gives the first level of dependencies, you can also use pactree to show them all in a hierarchical tree…
pactree kdesu
Or to make more readible you can play with the tree depth … change the number depending on how deep you want to go.
pactree -d3 kdesu
#22
That’s great!
Thank you so much!
#23
Thank you all for replying to this thread. I am grateful for every opportunity to learn new things. And I have thanks to you.
I’ll mark the topic as solved.
greetings,
philotux
#24
You solve a thread using this forum software by clicking the tick icon on the post with the solution, makes it easier for a user to find it when searching the forum with a similar issue.
#25
I missed that! Thanks for pointing it out.
Acknowledging that both yours and scachemaille’s posts pointed me towards the solution, I just pick one :blush:
closed #26
