[SOLVED] No sound on pinebook 1080
I cannot hear any sound from my pinebook 1080 with manjaro and kernel 5.2.0-1.
Alsamixer finds three sound cards:
  • pulseaudio
  • sun50i-a64-audio
  • allwinner,hdmi
I tried the first two (I have not hdmi cable to try).
I raised the volume but without any result.
In dmesg I found this error:
[ 12.555985] ALSA device list:
[ 12.559010] No soundcards found.
What do I need?
First $ inxi -Fxxxz
Second , is pavucontrol installed?
Output related to audio from
inxi -Fxxxz
  Device-1: sun50i-a64-dw-hdmi driver: sun8i_dw_hdmi bus ID: N/A
  chip ID: allwinner:1ee0000
  Device-2: simple-audio-card driver: asoc_simple_card bus ID: N/A
  chip ID: simple-audio-card:soc
  Device-3: simple-audio-card driver: asoc_simple_card bus ID: N/A
  chip ID: simple-audio-card:sound
  Device-4: simple-audio-card driver: N/A bus ID: N/A
  chip ID: simple-audio-card:sound_spdif
  Sound Server: ALSA v: k5.2.0-1-MANJARO-ARM
pavucontrol is installed and this the output:
Please check with alsamixer to see if the DAC audio device is muted.
Ok, I solved.
I needed to change the output from pavucontrol from one device to another (with the same name?).
Thanks too much!
Yeah, Device naming is a bit weird on ARM devices. :slight_smile:
In configuration :wink:
