Hi All,
First time Manjaro user, coming from Ubuntu
I just installed a new version of Manjaro, I also see a “Virtual output” in my sound but no Hardware Output. The sound was working with the original Windows10 that was on the laptop. Any help is greatly appreciated, thanks!
inxi -Fazy
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=4c1c2cbe-bf0a-4dcb-9eca-e7f29fe7ab24 rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20TKCTO1WW v: ThinkPad X1 Extreme Gen 3
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20TKCTO1WW v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: N2VET19W (1.04 ) date: 07/10/2020
ID-1: BAT0 charge: 76.2 Wh condition: 80.0/80.0 Wh (100%) volts: 17.2/15.4
model: Celxpert 5B10X19050 type: Li-poly serial: <filter> status: Unknown
cycles: 2
Topology: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 2 microcode: C8 L2 cache: 16.0 MiB
bogomips: 76816
Speed: 800 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 801 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f95
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:3
chip ID: 04f2:b6cb serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel,modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: eDP1 res: 2560x1440 hz: 60 dpi: 186 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:06c8
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:06f0
Local Storage: total: 1.86 TiB used: 10.71 GiB (0.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB2T0HALB-000L7 size: 1.86 TiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 3M2QEXG7 scheme: GPT
ID-1: / raw size: 1.86 TiB size: 1.83 TiB (98.38%) used: 10.71 GiB (0.6%)
fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 59.0 C mobo: 46.0 C gpu: nouveau temp: 38 C
Fan Speeds (RPM): cpu: 2536
Processes: 389 Uptime: 6h 43m Memory: 62.45 GiB used: 5.53 GiB (8.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1152 pacman: 1148
lib: 341 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
