[Solved] No Forum Logout
hello together,
I don´t know the correct kategorie, but since some time ago the button to logout the forum is lost.
Does somebody find it :thinking:
No_Logout
regards
caho
Click on your avatar in the top right and then on your name. At the bottom, you will see the Log Out link.
Thread moved from #technical-issues-and-assistance to #meta.
Hello @Aragorn,
thank you very much for the solution.
Logout-2
regard
caho
Mein Deutsch ist nicht so gut, aber du hast mein English verstanden. :slight_smile:
