Hi,
I am new to Manjaro. I installed it a few days ago. Now I am trying to pair my BT headphones (Bose QC35) and a boom 2 bluetooth speaker. The bluetooth menu detects the Bose headphones but it says “not connected” and there is no way I can pair them. I can pair them with my smartphone, so it shouldn’t be an issue of the headphones. Regarding the bluetooth speaker, it pairs also with the smartphone. However it doesn’t show up on the list of bluetooth devices detected by Manjaro. So, not able to pair the headphones and speaker not detected.
I appreciate your help.
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0611fba7-d9d4-46c0-86c4-c223bad5b669 rw quiet splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 82FG v: IdeaPad 5 15ITL05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 15ITL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: FHCN24WW date: 01/14/2021
ID-1: BAT0 charge: 70.0 Wh (100.0%) condition: 70.0/70.0 Wh (100.0%)
volts: 17.3 min: 15.1 model: LGC L19L4PF1 type: Li-poly serial: <filter>
status: Full cycles: 3
RAM: total: 15.43 GiB used: 6.9 GiB (44.7%)
Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
cache: L2: 12 MiB bogomips: 44864
Speed: 1284 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 1284 2: 1291
3: 1300 4: 1240 5: 1300 6: 1301 7: 1299 8: 1297
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:2
chip-ID: 04f2:b6ee class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:3 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 17.02 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
lanes: 4 type: SSD serial: <filter> rev: BL2QFXV7 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 17.02 GiB (3.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0611fba7-d9d4-46c0-86c4-c223bad5b669
label: NO_LABEL uuid: 7A65-0E5E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-5:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6ee
Device-2: 3-10:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 266 Uptime: 1d 5h 56m wakeups: 44482 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1358 lib: 335
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
