Is there any output when use this command:
grep EE /var/log/Xorg.0.log
I am near to the end of my knowledge. What says
less /etc/X11/xorg.conf.d/90-mhwd.conf
Ok, so it try to load nonfree drivers.
Can you still post the output from
ls -la /etc/X11/xorg.conf.d/
I reinstalled Linux 5.4 and now the network is working again but still unable to access my desktop getting a black screen with blinking cursor.
System is down can’t do that sorry
Ok, seems there is the problem. First it loads the ‘20-nouveau.conf’ which is the free driver configuration and after then it loads ‘90-mhwd.conf’ which are the unfree driver configuration where the driver is removed.
So you have to delete ‘90-mhwd.conf’.
sudo rm /etc/X11/xorg.conf.d/90-mhwd.conf
Than restart the PC
Removed the file and restarted the pc but I’m still getting a black screen. I tried using both kernels 5.4 and 5.10. Is there anything else you can suggest ?
If you type
is there ‘90-mhwd.conf’ still in the output?
Please provide output of
ls -la /etc/modprobe.d
cat /etc/modules-load.d/modules.conf
No only 3 files
00-keyboard.conf
10-libinput.conf
20-nouveau.conf
Wollie
Contents of /etc/modprobe.d
Mhwd-gpu.conf
R8169_blacklist.conf
Contents of/etc/modules-load.d/modules.conf
# List of modules to load at boot
Please show
cat /etc/modprobe.d/Mhwd-gpu.conf
cat /etc/modprobe.d/R8169_blacklist.conf
Wollie
I think you solved it !
Contents of /etc/modprobe.d/mhwd-gpu.conf
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
Contents of /etc/modprobe.d/r8169_blacklist.conf
blacklist r8169
So presumably I just remove the entry for blacklist nouveau and restart the pc?
Remove blacklist nouveau and blacklist ttm then run
sudo depmod -a
Then reboot.
Do you have a good reason to blacklist r8169? r8169 is the kernel built in module which usually works pretty good.
Wollie
No. I don’t know why that is blacklisted.
I’m editing this from the desktop instead of a mobile phone!
Thanks very much to you and kisun for resolving this issue.
Thanks for all your help with this - it’s now resolved!
