Manjaro 20.1
After recent update my Nvidia 340 driver is no longer displayed when I run mhwd -l in a tty
I can see driver for video-linux is displayed which I believe is the nouveau driver.
How can I default to this driver to enable booting into the desktop?
Thanks!
Hello lappetspm,
you can install and set the ‘video-linux’ driver with
sudo mhwd -a pci free 0300
If this wont help, please provide the output from these commands:
inxi -Fxa
mhwd -l
mhwd -li
Hello lappetspm,
‘mhwd -l’ shows you which drivers are available for your system. And ‘mhwd -li’ shows you which drivers are installed on your system.
So when I look at your ‘mhwd -li’-output it say that there are only the network driver are installed.
Is this the output of ‘sudo mhwd -a pci free 0300’ ? If so try:
sudo mhwd -f -i pci video-linux
Hm, seems to be there is a problem with you network. Have you proof your internet connection?
Yes network is working ok I’ve just booted into live cd
Please try to update mirror servers with:
sudo pacman-mirrors -f 0
Hm, first INFO says ‘Internet connection appears to be down’ and the 3 warnings befor looks like DNS didnt work.
What is the output from
ping -c 4 manjaro.org
Normaly it should look like
PING manjaro.org (176.9.38.148) 56(84) bytes of data.
64 Bytes von mail.manjaro.org (176.9.38.148): icmp_seq=1 ttl=53 Zeit=35.9 ms
64 Bytes von mail.manjaro.org (176.9.38.148): icmp_seq=2 ttl=53 Zeit=35.6 ms
64 Bytes von mail.manjaro.org (176.9.38.148): icmp_seq=3 ttl=53 Zeit=35.5 ms
64 Bytes von mail.manjaro.org (176.9.38.148): icmp_seq=4 ttl=53 Zeit=35.8 ms
--- manjaro.org ping statistics ---
4 Pakete übertragen, 4 empfangen, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 35.504/35.706/35.938/0.180 ms
Also try:
ping -c 4 176.9.38.148
And could you ping the IP Adress I posted above?
ping: connect: Network is unreachable
Hardware seems ok from live CD working
If your hardware(cable/router/wifi) seems to ok you can use
nmtui
to configure the network connection.
Ok I’ll take a look
Ok network is working after installing kernel 5.10
When I run sudo mhwd -a pci free 0300 it says successfully installed.
I tried re-booting but still black screen
Should I reinstall kernel 5.4 as this was the one I was using before the latest update?
Dont think that the Kernel is the problem. How did you install Kernel 5.10 without internet connection?
And what does
mhwd -li
outputs now?
