[Solved] Manjaro KDE is incredibly slow, but Cinnamon and XFCE are snappy
kde
desktop-environment
performance
desktop-hopping
#21
Anything showing in system monitor?
#22
As the name says, it manages your modem (if you have one). It’s related to NetworkManager.
If you do not have a modem, you can safely remove/mask/disable it.
#23
Nothing. It looks all normal on the system monitor, at least on the graphical widget that I can add to the panel.
#24
Try htop in a terminal, keep it running (yakuake is good for this).
#25
Alright. Will do.
#26
I have htop running now. What’s yakuake?
#27
Plasma’s drop down terminal, press F12 (the default) to show it. You may need to install and add to startup as you added Plasma to existing install.
#28
F12 at desktop doesn’t do anything.
You mean Konsole isn’t the Plasma terminal?
#29
you can also remove akonadi and pim suite if you dont use it
#30
Install it… It is based on konsole, but is a quake style dropdown terminal.
#31
Just had htop and the GUI Task Manager running at the same time and tried running a bunch of things I haven’t started up this session. Memory never reaches 50% and CPU usage is negligible, but they all still take quite a while to start up.
#32
Oh wait. Isn’t that just htop?
#33
Yes, but running in yakuake and slightly modified by me.
#34
change compositer to xrender and animation speed to very fast
#35
I definitely don’t. Great idea.
Tried that already but applications still took a while to start up.
#36
Alright. I’ll give it a try.
#37
most credible is to use ssd
#38
Which apps are slow to start?
#39
I kid you not: everything. Even the widgets in the panel. But once they’ve been started up once, they open and restart just fine. For example, pacman is an anomaly really good for illustarting this: If I’d just turned my laptop on and opened pacman, it’d take 2-3 minutes just to show me the borders of the pacman window. But close it and reopen it afterwards, 1 second.
#40
You mean pamac?
Try running from a terminal, does it report any errors? (command is pamac-manager).
