My system boots, Yakuake, the dropdown Terminal is loaded. manjaro Hello Is loaded. But, I dont see my taskbar (positioned to the left) or the wallpaper. Screen remains black. I can see the cursor.
I can then use plasmashell --replace in the yakuake dropdown to start plasma again. Ususally, the first attempt leads to crashed plama, and after 2 or 3 tries, plasma starts.
I do not have the calender. I executed:
grep Version ~/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/metadata.desktop /usr/share/plasma/plasmoids/org.kde.plasma.eventcalendar/metadata.desktop
Answer :
grep: /home/monsoon_east/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/metadata.desktop: Datei oder Verzeichnis nicht gefunden
grep: /usr/share/plasma/plasmoids/org.kde.plasma.eventcalendar/metadata.desktop: Datei oder Verzeichnis nicht gefunden
Here is my uname -a
Linux planetGlass 5.10.19-1-MANJARO #1 SMP PREEMPT Fri Feb 26 11:38:34 UTC 2021 x86_64 GNU/Linux
Here is my graphics hardware :
12: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.p+Z1JA96Pa3
Parent ID: vSkL.xta5pj6a3m6
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "nVidia GK107M [GeForce GTX 660M]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x0fd4 "GK107M [GeForce GTX 660M]"
SubVendor: pci 0x1558 "CLEVO/KAPOK Computer"
SubDevice: pci 0x3700
Revision: 0xff
Memory Range: 0xf6000000-0xf6ffffff (rw,non-prefetchable)
Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
Memory Range: 0xf0000000-0xf1ffffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xe07f (rw)
Memory Range: 0xf7000000-0xf707ffff (ro,non-prefetchable)
IRQ: 16 (31 events)
Module Alias: "pci:v000010DEd00000FD4sv00001558sd00003700bc03sc00i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is not active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is not active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #10 (PCI bridge)
21: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.fH_EJiEe_JC
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Onboard IGD"
Model: "Intel 3rd Gen Core processor Graphics Controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x0166 "3rd Gen Core processor Graphics Controller"
Revision: 0x09
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xf7400000-0xf77fffff (rw,non-prefetchable)
Memory Range: 0xd0000000-0xdfffffff (ro,non-prefetchable)
I/O Ports: 0xf000-0xf03f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 35 (109338 events)
Module Alias: "pci:v00008086d00000166sv00001558sd00003700bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Primary display adapter: #12
I run : sudo systemctl --failed
Output :
[sudo] Passwort für monsoon_east:
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
What can be done ?
