when i logged on today i was greeted by some strange files in my home directory, two of them. named “��#�gU” and “�;�X�U” in dolphin (without quotes), and in zsh, using ls they appear as: [‘’$‘\340\313’‘#’$‘\362’‘gU’] and [‘’$‘\340’‘;’$‘\367’‘X’$‘\370’‘U’]. (i added the square brackets for this post).
each file is listed as 0 bytes in size
using ls -l shows perms on the files as: -rw-r–r-- for both files
trying to rm the files errors saying “rm: cannot remove ‘$\340$\313#$\362gU’: No such file or directory”
trying to delete them or rename them in dolphin leads to simmilar errors.
using touch on the files creates a new file that doesnt match the name given to it. leading me to believe the file names are some sort of escape sequence.
any idea what these are and how/if i should remove them?
boot disk (the one which also has the home directory) appears to be in good health, showing 0 bad sectors. i am currently using ext4. my other disk is also in relatively good health, with 72 bad sectors, not bad for a 10 year old hdd with 4 years of power on hours.
i am currently executing the backup now, good idea on that one.
i really dont want to have to reinstall manjaro yet again (ive done so several times in the past when i messed things up playing with the configuration to get things how i wanted them), this time i actually have files on here that matter and very little free space on my other computers… not to mention all the configuration and tweaking ive done on here…
had to look up what a cow system is, sounds clever.
the command snipped you gave for the logs didnt work however. so i had to modify the args and then scrub through til i found the day in question…
looks like baloo_file crashed that day. but it also crashed on many other days. i dont know what makes this day special.
log from that day:
-- Boot 9a440ea9ef3945aeb50d0e24d023444e --
Jun 15 10:28:51 Blufox kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Jun 15 10:29:10 Blufox nmbd[960]: [2022/06/15 10:29:10.554494, 0] ../../source3/nmbd/nmbd.c:901(main)
Jun 15 10:29:10 Blufox nmbd[960]: nmbd version 4.16.1 started.
Jun 15 10:29:10 Blufox nmbd[960]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Jun 15 10:29:11 Blufox smbd[971]: [2022/06/15 10:29:11.199511, 0] ../../source3/smbd/server.c:1741(main)
Jun 15 10:29:11 Blufox smbd[971]: smbd version 4.16.1 started.
Jun 15 10:29:11 Blufox smbd[971]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Jun 15 10:29:35 Blufox nmbd[960]: [2022/06/15 10:29:35.299008, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Jun 15 10:29:35 Blufox nmbd[960]: *****
Jun 15 10:29:35 Blufox nmbd[960]: Samba name server BLUFOX is now a local master browser for workgroup WORKGROUP on subnet [ip redacted]
Jun 15 10:33:59 Blufox systemd-coredump[1433]: [🡕] Process 1221 (baloo_file) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 8b63de227f9be5e432cb1af8193f45411ff0194e
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libdl.so.2 with build-id 94198b268228074fa9f405bbedbbae94112593ed
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 9577a5fe1921756af97b2af318ff1c9a03f10a84
Module libnettle.so.8 with build-id a2cc6a257b0729585e870b345b83497c478ee28b
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module libQt5Widgets.so.5 with build-id a975fdcde9ab16194afb85f72bdfa36754c221f6
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libgnutls.so.30 with build-id a4f42d33fc809cb6f596998001cedc0bce06c751
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id c58fe082cbde02fc176e3c3663a6d81386eb5027
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libglib-2.0.so.0 with build-id f1d15261ce1317b9003a1f0957d5a528d063f630
Module libzstd.so.1 with build-id bd9a65f663b7f48e1427c418714eb8d005c37f71
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libsystemd.so.0 with build-id 6430b2bd03335142b596061e30d2508dc604a1b4
Module liblmdb.so with build-id 2b7a4c600c93825e729c1810a3d4a29e30cf55a1
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libX11.so.6 with build-id 310f8f1b8d7457d326407e0eb794353c62769b73
Module libQt5X11Extras.so.5 with build-id cc47e381ac9469803fd53bee418d952ad2782202
Module libKF5WindowSystem.so.5 with build-id b4733339e1c479aa3aeaf0b6a6335509b39f7c61
Module libKF5CoreAddons.so.5 with build-id 273e7c5a7cb2fbabf0d895cb82de5e5f191e9f6b
Module libKF5I18n.so.5 with build-id cf7ec4c5553f328a931bf91583809338409c3e52
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libudev.so.1 with build-id bce2b8a5c23fcbcf5542f34b741e18db4452160a
Module libQt5Gui.so.5 with build-id 95f8814f57816338b77f1ee4e5eefc233c4ac1b7
Module libQt5Xml.so.5 with build-id 76adbc3352f238c19f022496533dd239a8ad0f78
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module libQt5Core.so.5 with build-id 20e730c5e451c6dc0e3d1db771d53ce89097b92e
Module libKF5BalooEngine.so.5 with build-id c77599300a359ecc9ae63c73cdac56858a5645db
Module libQt5DBus.so.5 with build-id 6f6c582da4c0fed28f1e4595552cf5ee3792447a
Module libKF5ConfigCore.so.5 with build-id 834d1bd13d3bbac5fd141fa08b79d19e7727674d
Module libKF5Crash.so.5 with build-id 5793e2b3bf81a9142cfb833115d1bbb7ffaf669d
Module libKF5FileMetaData.so.3 with build-id 325aaf839853b0737d0ce8e1348c4de20325daef
Module libKF5Solid.so.5 with build-id 145412e41ec1eb1b7fb70653e938232d1216da07
Module baloo_file with build-id 8e3c1fa7eac4da47ae410c92534e553266eb033c
Stack trace of thread 1431:
#0 0x00007f4dea931ef9 n/a (liblmdb.so + 0x6ef9)
#1 0x00007f4dea932644 n/a (liblmdb.so + 0x7644)
#2 0x00007f4dea932c50 mdb_get (liblmdb.so + 0x7c50)
#3 0x00007f4debde2bc5 _ZN5Baloo12IdFilenameDB3getEy (libKF5BalooEngine.so.5 + 0x11bc5)
#4 0x00007f4debde3188 _ZNK5Baloo13DocumentUrlDB3getEy (libKF5BalooEngine.so.5 + 0x12188)
#5 0x00007f4debdef968 _ZNK5Baloo11Transaction11documentUrlEy (libKF5BalooEngine.so.5 + 0x1e968)
#6 0x000055bc55a2cb5d n/a (baloo_file + 0x1bb5d)
#7 0x00007f4debdf712b _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#8 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#9 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#10 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#11 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#12 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#13 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#14 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#15 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#16 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#17 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#18 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#19 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#20 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#21 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#22 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#23 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#24 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#25 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#26 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#27 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#28 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#29 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#30 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#31 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#32 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#33 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#34 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#35 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#36 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#37 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#38 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#39 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#40 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#41 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#42 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#43 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#44 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#45 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#46 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#47 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#48 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#49 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#50 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#51 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#52 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#53 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#54 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#55 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#56 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#57 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#58 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#59 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#60 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#61 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#62 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
#63 0x00007f4debdf7179 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngin>
Stack trace of thread 1277:
#0 0x00007f4deb48a5f1 pselect (libc.so.6 + 0x1085f1)
#1 0x00007f4de9af0524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007f4de9af18a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007f4deb40e54d n/a (libc.so.6 + 0x8c54d)
#4 0x00007f4deb493874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 1235:
#0 0x00007f4deb487c3f __poll (libc.so.6 + 0x105c3f)
#1 0x00007f4dea11bf68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2 0x00007f4dea0c3392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3 0x00007f4debb8427c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (>
#4 0x00007f4debb322ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2862ec)
#5 0x00007f4deb99352f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe752f)
#6 0x00007f4debe2575a n/a (libQt5DBus.so.5 + 0x2375a)
#7 0x00007f4deb99035a n/a (libQt5Core.so.5 + 0xe435a)
#8 0x00007f4deb40e54d n/a (libc.so.6 + 0x8c54d)
#9 0x00007f4deb493874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 1221:
#0 0x00007f4deb45abc7 getdents64 (libc.so.6 + 0xd8bc7)
#1 0x00007f4deb45ac75 readdir64 (libc.so.6 + 0xd8c75)
#2 0x00007f4debae81ab n/a (libQt5Core.so.5 + 0x23c1ab)
#3 0x00007f4deba80cb4 n/a (libQt5Core.so.5 + 0x1d4cb4)
#4 0x00007f4deba81719 n/a (libQt5Core.so.5 + 0x1d5719)
#5 0x00007f4deba81be5 _ZN12QDirIteratorC2ERK7QString6QFlagsIN4QDir6FilterEES3_INS_12IteratorFlagEE (libQt5C>
#6 0x000055bc55a2f114 n/a (baloo_file + 0x1e114)
#7 0x000055bc55a329d5 n/a (baloo_file + 0x219d5)
#8 0x000055bc55a3b2b9 n/a (baloo_file + 0x2a2b9)
#9 0x00007f4debb5d430 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b1430)
#10 0x00007f4debb39b0c _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28db0c)
#11 0x00007f4debb3a623 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.s>
#12 0x00007f4debb80448 n/a (libQt5Core.so.5 + 0x2d4448)
#13 0x00007f4dea0c5c6b g_main_context_dispatch (libglib-2.0.so.0 + 0x54c6b)
#14 0x00007f4dea11c001 n/a (libglib-2.0.so.0 + 0xab001)
#15 0x00007f4dea0c3392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#16 0x00007f4debb8427c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (>
#17 0x00007f4debb322ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2862ec)
#18 0x00007f4debb3cdd9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x290dd9)
#19 0x000055bc55a1fdab n/a (baloo_file + 0xedab)
#20 0x00007f4deb3ab290 n/a (libc.so.6 + 0x29290)
#21 0x00007f4deb3ab34a __libc_start_main (libc.so.6 + 0x2934a)
#22 0x000055bc55a20245 n/a (baloo_file + 0xf245)
Jun 15 10:34:07 Blufox pulseaudio[1279]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out>
Jun 15 15:33:10 Blufox dolphin[11168]: inotify_add_watch(/boot/efi) failed: (Permission denied)
Jun 16 01:55:44 Blufox nmbd[960]: [2022/06/16 01:55:44.635350, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Jun 16 01:55:44 Blufox nmbd[960]: Got SIGTERM: going down...
maybe those ‘mysterious’ files are from baloo crashing during indexing … disable baloo - go to system settings/search/file search - and uncheck all options, click apply …
i used to do a lot of networked file transfers over samba (i use sshfs now which is a lot more reliable), it used to crash a lot, could that be related?
i get the same kind of error as when i tried to delete them when doing so from dolphin, but using mv worked, surprisingly. deleting the folder also worked after that, thanks!
