Help! I configured python-validity as in this link:
then changed my pam.d/login pam.d/sudo pam.d/su as in this link:
the changes made to each file are:
auth required pam_env.so
auth sufficient pam_fprintd.so
auth sufficient pam_unix.so try_first_pass likeauth nullok
auth required pam_deny.so
#auth required pam_securetty.so
#auth requisite pam_nologin.so
#auth include system-local-login
#account include system-local-login
#session include system-local-login
now when i try fprintd-verify I get this message:
Using device /net/reactivated/Fprint/Device/0
ListEnrolledFingers failed: Traceback (most recent call last):
File "/usr/lib/python3.9/site-packages/dbus/service.py", line 711, in _message_cb
retval = candidate_method(self, *args, **keywords)
File "/usr/lib/python-validity/dbus-service", line 90, in ListEnrolledFingers
raise e
File "/usr/lib/python-validity/dbus-service", line 81, in ListEnrolledFingers
usr = self.user2record(user)
File "/usr/lib/python-validity/dbus-service", line 64, in user2record
return db.lookup_user(self.user2identity(user))
File "/usr/lib/python3.9/site-packages/validitysensor/db.py", line 163, in lookup_user
stg = self.get_user_storage(name='StgWindsor')
File "/usr/lib/python3.9/site-packages/validitysensor/db.py", line 149, in get_user_storage
return parse_user_storage(tls.cmd(pack('<BHH', 0x4b, dbid, len(name)) + name))
File "/usr/lib/python3.9/site-packages/validitysensor/tls.py", line 122, in cmd
rsp = self.app(cmd)
File "/usr/lib/python3.9/site-packages/validitysensor/tls.py", line 152, in app
return self.parse_tls_response(self.usb.cmd(self.make_app_data(b)))
File "/usr/lib/python3.9/site-packages/validitysensor/tls.py", line 351, in parse_tls_response
raise Exception('Unexpected TLS version %d %d' % (mj, mn))
Exception: Unexpected TLS version 4 0
and when I try to use sudo or su, I get this message:
[sudo] password for alonp:
sudo: account validation failure, is your account locked?
sudo: a password is required
The thing is is that when prompted for my password through the GUI (for example, in the settings window) My password works, but it doesn’t work in the terminal. It would help me if I could figure out a way to launch gedit from the GUI as an admin maybe then I could revert the changes that I made
