[SOLVED] Lightdm fails to start
After lastest upgrade I tried to restart lightdm and it hanged. I reboot the machine and the lightdm.service fails to start.
I have tried to disable and enable the module, uninstall and install it along with slick-greeter, but it didn’t work.
Display Server: X.org 1.19.3
Kernel: 4.4.73-1-MANJARO x86_64 (64 bit gcc: 7.1.1)
Desktop environment: Gnome 3
$systemctl status lightdm output:
`● lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2017-07-03 21:31:21 CDT; 7min ago
Docs: man:lightdm(1)
Process: 1748 ExecStart=/usr/bin/lightdm (code=exited, status=1/FAILURE)
Main PID: 1748 (code=exited, status=1/FAILURE)
Jul 03 21:31:20 pc systemd[1]: lightdm.service: Unit entered failed state.
Jul 03 21:31:20 pc systemd[1]: lightdm.service: Failed with result ‘exit-code’.
Jul 03 21:31:21 user systemd[1]: lightdm.service: Service hold-off time over, scheduling restart.
Jul 03 21:31:21 user systemd[1]: Stopped Light Display Manager.
Jul 03 21:31:21 user systemd[1]: lightdm.service: Start request repeated too quickly.
Jul 03 21:31:21 user systemd[1]: Failed to start Light Display Manager.
Jul 03 21:31:21 user systemd[1]: lightdm.service: Unit entered failed state.
Jul 03 21:31:21 user systemd[1]: lightdm.service: Failed with result ‘exit-code’.
#journactl -xe output:
Jul 03 21:31:19 pc systemd[1]: Starting Light Display Manager…
– Subject: Unit lightdm.service has begun start-up
– Defined-By: systemd
– Support:
– Unit lightdm.service has begun starting up.
Jul 03 21:31:19 pc systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 21:31:19 pc systemd[1]: Failed to start Light Display Manager.
– Subject: Unit lightdm.service has failed
– Support:
– Unit lightdm.service has failed.
– The result is failed.
Jul 03 21:31:19 pc systemd[1]: lightdm.service: Unit entered failed state.
Jul 03 21:31:19 pc systemd[1]: lightdm.service: Failed with result ‘exit-code’.
Jul 03 21:31:19 pc sudo[1714]: pam_unix(sudo:session): session closed for user root
Jul 03 21:31:20 pc systemd[1]: lightdm.service: Service hold-off time over, scheduling restart.
Jul 03 21:31:20 pc systemd[1]: Stopped Light Display Manager.
– Subject: Unit lightdm.service has finished shutting down
– Unit lightdm.service has finished shutting down.
Jul 03 21:31:20 pc systemd[1]: Starting Light Display Manager…
Jul 03 21:31:20 pc systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 21:31:20 pc systemd[1]: Failed to start Light Display Manager.
– Support:
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Support:
– Support:
– Support:
Jul 03 21:3`1:20 pc systemd[1]: Starting Light Display Manager…
– Support:l
– Support:
– Support:
– Support:
– Support:
Jul 03 21:31:21 pc systemd[1]: lightdm.service: Service hold-off time over, scheduling restart.
Jul 03 21:31:21 pc systemd[1]: Stopped Light Display Manager.
– Support:
Jul 03 21:31:21 pc systemd[1]: lightdm.service: Start request repeated too quickly.
Jul 03 21:31:21 pc systemd[1]: Failed to start Light Display Manager.
– Support:
Jul 03 21:31:21 pc systemd[1]: lightdm.service: Unit entered failed state.
Jul 03 21:31:21 pc systemd[1]: lightdm.service: Failed with result ‘exit-code’.
I cannot find anything significant in the system output.
Any sugguestions?
try sudo lightdm –-test-mode --debug
Thanks for the tip!
Lightdm was searching for another greeter than the one installed.
On /etc/lightdm/lightdm.conf I had to add explicitly the greeter by adding this line on the [Seat:*] section:
greeter-session=lightdm-slick-greeter
Now the service starts correctly.
