[SOLVED] Lightdm-deepin-greeter segmentation fault
Roughly a year ago I switched from Windows to Manjaro Deepin.
(Felt like coming home after 20 years... used IRIX on SGIs back then).
Everything worked fine until around November when I suddenly could not log in as the greeter screen did not appeared.
I figured out that the lightdm-deepin-greeter is causing a segmentation fault.
I installed the gtk-greeter and continued to use the machine this way.
The small On/Off Icon in the lower right corner of the desktop (Shutdown, restart, suspend, etc.) is not working since then as it probably tied to the greeter.
After every update I tested if it's working again but it did not.
My System Details:
System:    Host: Sattellte Kernel: 4.20.17-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Console: tty 0
           Distro: Manjaro Linux
Machine:   Type: Laptop System: TOSHIBA product: SATELLITE P70-A v: PSPLPE-00600EGR serial: 8D027323C
           Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1 v: Type2 - Board Version
           serial: Type2 - Board Serial Number UEFI: Insyde v: 1.40 date: 09/18/2013
Graphics:  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Toshiba America Info Systems driver: i915
           v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GK107M [GeForce GT 745M] driver: N/A bus ID: 01:00.0
           Display: server: X.Org 1.20.4 driver: intel resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.0.2 direct render: Yes
Lightdm Log:
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.28.0, UID=0 PID=792
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/60-deepin.conf
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Registered seat module unity
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.00s] DEBUG: Seat seat0: Creating display server of type x
[+0.00s] DEBUG: posix_spawn avoided (fd close requested)
[+0.01s] DEBUG: Using VT 1
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 1
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 798: /usr/bin/X -background none :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt1 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.03s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.03s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.90s] DEBUG: Got signal 10 from process 798
[+0.90s] DEBUG: XServer 0: Got signal from X server :0
[+0.90s] DEBUG: XServer 0: Connecting to XServer :0
[+0.90s] DEBUG: posix_spawn avoided (fd close requested) (child_setup specified)
[+0.90s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+0.90s] DEBUG: Session pid=931: Started with service 'lightdm-greeter', username 'lightdm'
[+0.92s] DEBUG: Session pid=931: Authentication complete with return value 0: Success
[+0.92s] DEBUG: Seat seat0: Session authenticated, running command
[+0.92s] DEBUG: Session pid=931: Running command /usr/bin/lightdm-gtk-greeter
[+0.92s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+0.92s] DEBUG: Session pid=931: Logging to /var/log/lightdm/seat0-greeter.log
[+1.01s] DEBUG: Activating VT 1
[+1.01s] DEBUG: Activating login1 session c1
[+1.01s] DEBUG: Seat seat0 changes active session to c1
[+1.01s] DEBUG: Session c1 is already active
[+1.26s] DEBUG: Greeter connected version=1.28.0 api=1 resettable=false
[+1.42s] DEBUG: Greeter start authentication for steve
[+1.42s] DEBUG: Session pid=977: Started with service 'lightdm', username 'steve'
[+1.43s] DEBUG: Session pid=977: Got 1 message(s) from PAM
[+1.43s] DEBUG: Prompt greeter with 1 message(s)
[+6.16s] DEBUG: Continue authentication
[+6.18s] DEBUG: Session pid=977: Authentication complete with return value 0: Success
[+6.18s] DEBUG: Authenticate result for user steve: Success
[+6.18s] DEBUG: User steve authorized
[+6.19s] DEBUG: Greeter requests session deepin
[+6.19s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
[+6.19s] DEBUG: Terminating login1 session c1
[+6.19s] DEBUG: Session pid=931: Sending SIGTERM
[+6.19s] DEBUG: Greeter closed communication channel
[+6.20s] DEBUG: Session pid=931: Exited with return value 0
[+6.20s] DEBUG: Seat seat0: Session stopped
[+6.20s] DEBUG: Seat seat0: Greeter stopped, running session
[+6.20s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+6.20s] DEBUG: posix_spawn avoided (fd close requested) (child_setup specified)
[+6.20s] DEBUG: Session pid=977: Running command /etc/lightdm/Xsession /usr/bin/startdde
[+6.20s] DEBUG: Creating shared data directory /var/lib/lightdm-data/steve
[+6.20s] DEBUG: Session pid=977: Logging to .xsession-errors
[+6.28s] DEBUG: Activating VT 1
[+6.28s] DEBUG: Activating login1 session 2
[+6.28s] DEBUG: Seat seat0 changes active session to
[+6.28s] DEBUG: Seat seat0 changes active session to 2
[+6.28s] DEBUG: Session 2 is already active
[+60.77s] DEBUG: Got signal 15 from process 1
[+60.77s] DEBUG: Caught Terminated signal, shutting down
[+60.77s] DEBUG: Stopping display manager
[+60.77s] DEBUG: Seat seat0: Stopping
[+60.77s] DEBUG: Seat seat0: Stopping display server
[+60.77s] DEBUG: Sending signal 15 to process 798
[+60.77s] DEBUG: Seat seat0: Stopping session
[+60.77s] DEBUG: Terminating login1 session 2
[+60.80s] DEBUG: Session pid=977: Sending SIGTERM
[+60.82s] DEBUG: Session pid=977: Exited with return value 1
[+60.82s] DEBUG: Seat seat0: Session stopped
[+60.82s] DEBUG: Launching process 1447: /usr/sbin/deepin-fix-xauthority-perm
[+60.85s] DEBUG: Process 1447 exited with return value 0
[+60.85s] DEBUG: Seat seat0: Exit status of /usr/sbin/deepin-fix-xauthority-perm: 0
[+60.85s] DEBUG: Seat seat0 changes active session to
[+61.05s] DEBUG: Process 798 exited with return value 0
[+61.05s] DEBUG: XServer 0: X server stopped
[+61.05s] DEBUG: Releasing VT 1
[+61.05s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+61.05s] DEBUG: Seat seat0: Display server stopped
[+61.05s] DEBUG: Seat seat0: Stopped
[+61.05s] DEBUG: Display manager stopped
[+61.05s] DEBUG: Stopping daemon
[+61.05s] DEBUG: Exiting with return value 0
Starting /usr/bin/lightdm-deepin-greeter by hand:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
2019-04-21, 14:05:26.562 [Warning] [lockworker.cpp       LockWorker::LockWorker              95] greeter connect fail !!!
2019-04-21, 14:05:26.568 [Debug  ] [lockworker.cpp       LockWorker::recoveryUserKBState     582] restore numlock status to  false
Segmentation fault (core dumped)
Lightdm.conf (only Seat section):
[Seat:*]
#type=local
#pam-service=lightdm
#pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-backend=
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
#unity-compositor-command=unity-system-compositor
#unity-compositor-timeout=60
greeter-session=lightdm-deepin-greeter
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
user-session=deepin
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
#autologin-user=
#autologin-user-timeout=0
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
lightdm-deepin-greeter.conf:
[General]
ScreenScaleFactor=1
Is there some sort of debug function for the deeepin-greeter?
Are there any options which I could put in the configuration to see where the problem is?
Thanks for any Help.
Steve
You could try to replace dubus package with dbus-x11 and see if that makes a difference.
Thanks for the suggestion. Unfortunately it still crashes.
seat0-greeter.log:
2019-04-21, 15:03:05.908 [Debug  ] [lockworker.cpp       LockWorker::recoveryUserKBState     582] restore numlock status to  false
/etc/deepin/greeters.d/lightdm-deepin-greeter: Zeile 3:  1137 Speicherzugriffsfehler  (Speicherabzug geschrieben) /usr/bin/lightdm-deepin-greeter
Funny that it switched back to German although system Language is still English.
(Speicherabzug geschrieben means core dumped.)
but are you using the GTK version of LightDM or lightdm-deepin-greeter now ?
I'm using the Deepin Desktop and would like to use the deepin greeter as well.
I only switched to the GTK greeter to be able to use the graphic system.
It was working a couple of months then it suddenly broke down.
I don't know what was the cause of that. Maybe a system update?
deepin comes with its own implementation of greeter, the packages you need for this are:
lightdm
liblightdm-qt5
deepin-session-ui
just add, you don't need to modify any files for it to work.
All of these packages are already installed. It was working for some months but something broke it.
Is there a way to see at which point /usr/bin/lightdm-deepin-greeter crashes.
According to the above log, it's after it tries to set the numloc to off.
In terminal:
sudo journalctl -p 3 -xb
or
dmesg
sudo journalctl -p 3 -xb:
-- Logs begin at Fri 2018-11-16 21:51:55 CET, end at Sun 2019-04-21 18:52:28 CEST. --
Apr 21 15:07:17 Sattellte kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ae0000000040110a
Apr 21 15:07:17 Sattellte kernel: mce: [Hardware Error]: TSC 0 ADDR ff8870c0 MISC 38a0000086
Apr 21 15:07:17 Sattellte kernel: mce: [Hardware Error]: PROCESSOR 0:306c3 TIME 1555852034 SOCKET 0 APIC 0 microcode 25
Apr 21 15:07:17 Sattellte kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20181003/psargs-3>
Apr 21 15:07:17 Sattellte kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.DD02._BCL, AE_NOT_FOUND (20181003/pspa>
Apr 21 15:07:26 Sattellte systemd[1]: Failed to mount /Linux_PhotoBackup.
-- Subject: A start job for unit Linux_PhotoBackup.mount has failed
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- A start job for unit Linux_PhotoBackup.mount has finished with a failure.
-- The job identifier is 97 and the job result is failed.
Apr 21 15:07:33 Sattellte lightdm[994]: gkr-pam: unable to locate daemon control file
Apr 21 15:11:47 Sattellte systemd-coredump[2444]: Process 2437 (dde-shutdown) of user 1000 dumped core.
                                                  Stack trace of thread 2437:
                                                  #0  0x00005650ed0c1735 n/a (dde-shutdown)
                                                  #1  0x00005650ed0c5084 n/a (dde-shutdown)
                                                  #2  0x00005650ed0c59a0 n/a (dde-shutdown)
                                                  #3  0x00005650ed0c5bda n/a (dde-shutdown)
                                                  #4  0x00005650ed0c8030 n/a (dde-shutdown)
                                                  #5  0x00005650ed0abe19 main (dde-shutdown)
                                                  #6  0x00007feef177f223 __libc_start_main (libc.so.6)
                                                  #7  0x00005650ed0ac4be n/a (dde-shutdown)
                                                  Stack trace of thread 2438:
                                                  #0  0x00007feef184bc21 __poll (libc.so.6)
                                                  #1  0x00007feef07c9630 n/a (libxcb.so.1)
                                                  #2  0x00007feef07cb2db xcb_wait_for_event (libxcb.so.1)
                                                  #3  0x00007feeeb9ba989 n/a (libQt5XcbQpa.so.5)
                                                  #4  0x00007feef1b8696c n/a (libQt5Core.so.5)
                                                  #5  0x00007feef04c5a9d start_thread (libpthread.so.0)
                                                  #6  0x00007feef1856b23 __clone (libc.so.6)
                                                  Stack trace of thread 2441:
                                                  #1  0x00007feef1467690 n/a (libglib-2.0.so.0)
                                                  #2  0x00007feef14686d2 g_main_loop_run (libglib-2.0.so.0)
                                                  #3  0x00007feef15db568 n/a (libgio-2.0.so.0)
                                                  #4  0x00007feef1442c21 n/a (libglib-2.0.so.0)
                                                  Stack trace of thread 2439:
                                                  #2  0x00007feef146777e g_main_context_iteration (libglib-2.0.so.0)
                                                  #3  0x00007feef14677d2 n/a (libglib-2.0.so.0)
                                                  Stack trace of thread 2440:
                                                  #3  0x00007feeebad7bde n/a (libdconfsettings.so)
                                                  Stack trace of thread 2442:
                                                  #3  0x00007feef1d98c99 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoo>
                                                  #4  0x00007feef1d41a8c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5>
                                                  #5  0x00007feef1b85569 _ZN7QThread4execEv (libQt5Core.so.5)
                                                  #6  0x00007feef204dba6 n/a (libQt5DBus.so.5)
                                                  #7  0x00007feef1b8696c n/a (libQt5Core.so.5)
                                                  #8  0x00007feef04c5a9d start_thread (libpthread.so.0)
                                                  #9  0x00007feef1856b23 __clone (libc.so.6)
-- Subject: Process 2437 (dde-shutdown) dumped core
-- Documentation: man:core(5)
-- Process 2437 (dde-shutdown) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Apr 21 16:26:47 Sattellte daemon/session/power[1099]: utils.go:121: Lock failed: Process com.deepin.dde.lockFront received signal 11
                                                        ->  utils.go:93
                                                        ->  manager_events.go:55
                                                        ->  sleep_inhibit.go:47
                                                        ->  auto.go:762
                                                        ->  signal.go:59
                                                        ->  signal.go:41
                                                        ->  asm_amd64.s:1337
Apr 21 16:26:48 Sattellte systemd-coredump[4340]: Process 4331 (dde-lock) of user 1000 dumped core.
                                                  Stack trace of thread 4331:
                                                  #0  0x000055f88e1e0da5 n/a (dde-lock)
                                                  #1  0x000055f88e1e46f4 n/a (dde-lock)
                                                  #2  0x000055f88e1e5010 n/a (dde-lock)
                                                  #3  0x000055f88e1e524a n/a (dde-lock)
                                                  #4  0x000055f88e1e76a0 n/a (dde-lock)
                                                  #5  0x000055f88e1cafbc main (dde-lock)
                                                  #6  0x00007fee0e54d223 __libc_start_main (libc.so.6)
                                                  #7  0x000055f88e1cbb2e n/a (dde-lock)
                                                  Stack trace of thread 4332:
                                                  #0  0x00007fee0e619c21 __poll (libc.so.6)
                                                  #1  0x00007fee0e50b630 n/a (libxcb.so.1)
                                                  #2  0x00007fee0e50d2db xcb_wait_for_event (libxcb.so.1)
                                                  #3  0x00007fee08777989 n/a (libQt5XcbQpa.so.5)
                                                  #4  0x00007fee0e95496c n/a (libQt5Core.so.5)
                                                  #5  0x00007fee0d28ea9d start_thread (libpthread.so.0)
                                                  #6  0x00007fee0e624b23 __clone (libc.so.6)
                                                  Stack trace of thread 4333:
                                                  #1  0x00007fee0e206690 n/a (libglib-2.0.so.0)
                                                  #2  0x00007fee0e20677e g_main_context_iteration (libglib-2.0.so.0)
                                                  #3  0x00007fee0e2067d2 n/a (libglib-2.0.so.0)
                                                  #4  0x00007fee0e1e1c21 n/a (libglib-2.0.so.0)
                                                  Stack trace of thread 4334:
                                                  #3  0x00007fee1023cbde n/a (libdconfsettings.so)
                                                  Stack trace of thread 4336:
                                                  #3  0x00007fee0eb66c99 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoo>
                                                  #4  0x00007fee0eb0fa8c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5>
                                                  #5  0x00007fee0e953569 _ZN7QThread4execEv (libQt5Core.so.5)
                                                  #6  0x00007fee0ee1bba6 n/a (libQt5DBus.so.5)
                                                  #7  0x00007fee0e95496c n/a (libQt5Core.so.5)
                                                  #8  0x00007fee0d28ea9d start_thread (libpthread.so.0)
                                                  #9  0x00007fee0e624b23 __clone (libc.so.6)
                                                  Stack trace of thread 4335:
                                                  #2  0x00007fee0e2076d2 g_main_loop_run (libglib-2.0.so.0)
                                                  #3  0x00007fee0e378568 n/a (libgio-2.0.so.0)
-- Subject: Process 4331 (dde-lock) dumped core
-- Process 4331 (dde-lock) crashed and dumped core.
Apr 21 16:27:37 Sattellte kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 5: ae0000000040110a
Apr 21 16:27:37 Sattellte kernel: mce: [Hardware Error]: TSC 0 ADDR ff882100 MISC 38a0000086
Apr 21 16:27:37 Sattellte kernel: mce: [Hardware Error]: PROCESSOR 0:306c3 TIME 1555856857 SOCKET 0 APIC 0 microcode 25
Apr 21 16:27:37 Sattellte kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ae0000000040110a
Apr 21 16:27:37 Sattellte kernel: mce: [Hardware Error]: TSC 0 ADDR ff8820c0 MISC 38a0000086
Apr 21 16:45:47 Sattellte daemon/session/power[1099]: utils.go:121: Lock failed: Process com.deepin.dde.lockFront received signal 11
                                                        ->  utils.go:93
                                                        ->  auto.go:762
                                                        ->  signal.go:59
                                                        ->  signal.go:41
                                                        ->  asm_amd64.s:1337
Apr 21 16:45:47 Sattellte systemd-coredump[5113]: Process 5106 (dde-lock) of user 1000 dumped core.
                                                  Stack trace of thread 5106:
                                                  #0  0x000055cce68dfda5 n/a (dde-lock)
                                                  #1  0x000055cce68e36f4 n/a (dde-lock)
                                                  #2  0x000055cce68e4010 n/a (dde-lock)
                                                  #3  0x000055cce68e424a n/a (dde-lock)
                                                  #4  0x000055cce68e66a0 n/a (dde-lock)
                                                  #5  0x000055cce68c9fbc main (dde-lock)
                                                  #6  0x00007f62141c7223 __libc_start_main (libc.so.6)
                                                  #7  0x000055cce68cab2e n/a (dde-lock)
                                                  Stack trace of thread 5108:
                                                  #0  0x00007f6214293c21 __poll (libc.so.6)
                                                  #1  0x00007f6213e80690 n/a (libglib-2.0.so.0)
                                                  #2  0x00007f6213e8077e g_main_context_iteration (libglib-2.0.so.0)
                                                  #3  0x00007f6213e807d2 n/a (libglib-2.0.so.0)
                                                  #4  0x00007f6213e5bc21 n/a (libglib-2.0.so.0)
                                                  #5  0x00007f6212f08a9d start_thread (libpthread.so.0)
                                                  #6  0x00007f621429eb23 __clone (libc.so.6)
                                                  Stack trace of thread 5111:
                                                  #2  0x00007f6213e816d2 g_main_loop_run (libglib-2.0.so.0)
                                                  #3  0x00007f6213ff2568 n/a (libgio-2.0.so.0)
                                                  Stack trace of thread 5110:
                                                  #3  0x00007f62147e0c99 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoo>
                                                  #4  0x00007f6214789a8c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5>
                                                  #5  0x00007f62145cd569 _ZN7QThread4execEv (libQt5Core.so.5)
                                                  #6  0x00007f6214a95ba6 n/a (libQt5DBus.so.5)
                                                  #7  0x00007f62145ce96c n/a (libQt5Core.so.5)
                                                  #8  0x00007f6212f08a9d start_thread (libpthread.so.0)
                                                  #9  0x00007f621429eb23 __clone (libc.so.6)
                                                  Stack trace of thread 5109:
                                                  #3  0x00007f6215eb6bde n/a (libdconfsettings.so)
                                                  Stack trace of thread 5107:
                                                  #1  0x00007f6214185630 n/a (libxcb.so.1)
                                                  #2  0x00007f62141872db xcb_wait_for_event (libxcb.so.1)
                                                  #3  0x00007f620e3f1989 n/a (libQt5XcbQpa.so.5)
                                                  #4  0x00007f62145ce96c n/a (libQt5Core.so.5)
-- Subject: Process 5106 (dde-lock) dumped core
-- Process 5106 (dde-lock) crashed and dumped core.
Apr 21 18:51:44 Sattellte kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 5: ae0000000040110a
Apr 21 18:51:44 Sattellte kernel: mce: [Hardware Error]: TSC 0 ADDR ff882100 MISC 38a0000086
Apr 21 18:51:44 Sattellte kernel: mce: [Hardware Error]: PROCESSOR 0:306c3 TIME 1555865504 SOCKET 0 APIC 0 microcode 25
Apr 21 18:51:44 Sattellte kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ae0000000040110a
Apr 21 18:51:44 Sattellte kernel: mce: [Hardware Error]: TSC 0 ADDR ff8820c0 MISC 38a0000086
Seems like a lot of errors, just don't know how to handle them...
Today I can not login, no deepin greeter.
In tty sudo lightdm my deepin login start. Only "sudo" lightdm. startx failed.
Zusammenfassung
Searching:
mvision
dalto
Juli '17
sudo lightdm –-test-mode --debug
Thanks for the tip!
Lightdm was searching for another greeter than the one installed.
On /etc/lightdm/lightdm.conf I had to add explicitly the greeter by adding this line on the [Seat:*] section:
greeter-session=lightdm-slick-greeter
I changed from
to
greeter-session=lightdm-gtk-greeter
Deepin start. But deepin-greeter login (blur blue see) not.
Zusammenfassung
[mint@deepin ~]$ pacman -Qs lightdm
local/deepin-session-ui 4.9.4-1.2 (deepin)
    Deepin desktop-environment - Session UI module
local/liblightdm-qt5 1:1.28.0-3
    LightDM Qt client library
local/lightdm 1:1.28.0-3
    A lightweight display manager
local/lightdm-gtk-greeter 1:2.0.6-1
    GTK+ greeter for LightDM
local/lightdm-gtk-greeter-settings 1.2.2-3
    Settings editor for the LightDM GTK+ Greeter
I am back to lightdm-deepin-greeter , work :slight_smile:
Just to close my topic: yesterday there was a 2.6 GB system update and today when I opened up my notebook I was greeted by the Deepin Greeter! Miracles Happen!
Great System and many great contributors. Thanks for your work!
Cheers,
Steve
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
