[SOLVED] libvirt/virsh fails to initialize default network at boot on Ryzen 3000
Hi,
cant figure out whats wrong with this thing...
When i manually initialize libvirt and fire up the default network via virsh everything works fine,
if i enable the network to autostart however, virsh will just hang indefinetely after boot.
Restarting libvirt allows me to again manually start the default network. Oo
Any suggestions? Because i couldnt find any solution on the internets thus far. :frowning:
regards
Found the issue, its apparently a Ryzen 3000 thing, where KVM isnt initialized in time.
What you do is insert MODULES=(kvm_amd) into your /etc/mkinitcpio.conf and rewrite it with mkinitcpio -p linux52 (or whichever Kernel your using).
Hope that eleviates some headaches. :stuck_out_tongue:
