[SOLVED] Laptop Going to sleep, even when all settings say don't
#1
Hi
SO i am having an issue where my laptop (ASUS G751JY) keeps going to sleep when i close the lid.
Some time i have to close the lid/screen, but still want the laptop to just keep doing what it’s doing.
I checked all the settings i could find in relation to power management and they look to be set correctly.
When I open the lid again, It will come online right away and flash my UEFI ROG logo. I can see that app’s have been suspended and the wired network get’s disconnected. so looks like it’s going into hibernate.
Every ting is fully up to date that i can find.
[lucas@G751 ~]$ cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=18.0.2
DISTRIB_CODENAME=Illyria
DISTRIB_DESCRIPTION=“Manjaro Linux”
Kernal: 4.19.16-1 LTS
Desktop: XFCE
TLDR;
Power management issues, laptop going to sleep/hibernate when screen closed.
How to continue task even the lid is closed?
#2
Have you checked on TLP to see what it is doing.
I am not on my Manjaro system but it should be something like,
lee@linux-6y72:~> systemctl status tlp.service
and config is in /etc/default/tlp
#3
What does the xfce-power-manager screen say under the “General” screen?
#4
outputs below but i coudln’t see any thing that was obvious.
[lucas@G751 ~]$ systemctl status tlp.service
● tlp.service - TLP system startup/shutdown
   Loaded: loaded (/usr/lib/systemd/system/tlp.service; enabled; vendor preset:>
   Active: active (exited) since Sat 2019-02-09 11:52:21 AEDT; 1h 48min ago
     Docs: http://linrunner.de/tlp
  Process: 682 ExecStart=/usr/bin/tlp init start (code=exited, status=0/SUCCESS)
 Main PID: 682 (code=exited, status=0/SUCCESS)
Feb 09 11:52:21 G751 systemd[1]: Starting TLP system startup/shutdown...
Feb 09 11:52:21 G751 tlp[682]: Applying power save settings...done.
Feb 09 11:52:21 G751 tlp[682]: Setting battery charge thresholds...done.
Feb 09 11:52:21 G751 systemd[1]: Started TLP system startup/shutdown.
[lucas@G751 ~]$ cat /etc/default/tlp
# tlp - Parameters for power saving
# See full explanation: http://linrunner.de/en/tlp/docs/tlp-configuration.html
# Hint: some features are disabled by default, remove the leading # to enable
# them.
# Set to 0 to disable, 1 to enable TLP.
TLP_ENABLE=1
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
TLP_DEFAULT_MODE=AC
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Hint: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
TLP_PERSISTENT_DEFAULT=0
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
# Dirty page values (timeouts in secs).
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
# Hint: CPU parameters below are disabled by default, remove the leading #
# to enable them, otherwise kernel default values are used.
# Select a CPU frequency scaling governor.
# Intel Core i processor with intel_pstate driver:
#   powersave(*), performance.
# Older hardware with acpi-cpufreq driver:
#   ondemand(*), powersave, performance, conservative, schedutil.
# (*) is recommended.
# Hint: use tlp-stat -p to show the active driver and available governors.
# Important:
#   powersave for intel_pstate and ondemand for acpi-cpufreq are power
#   efficient for *almost all* workloads and therefore kernel and most
#   distributions have chosen them as defaults. If you still want to change,
#   you should know what you're doing! You *must* disable your distribution's
#   governor settings or conflicts will occur.
#CPU_SCALING_GOVERNOR_ON_AC=powersave
#CPU_SCALING_GOVERNOR_ON_BAT=powersave
# Set the min/max frequency available for the scaling governor.
# Possible values strongly depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
#CPU_SCALING_MIN_FREQ_ON_AC=0
#CPU_SCALING_MAX_FREQ_ON_AC=0
#CPU_SCALING_MIN_FREQ_ON_BAT=0
#CPU_SCALING_MAX_FREQ_ON_BAT=0
# Set energy performance hints (HWP) for Intel P-state governor:
#   performance, balance_performance, default, balance_power, power
# Values are given in order of increasing power saving.
# Note: Intel Skylake or newer CPU and Kernel >= 4.10 required.
CPU_HWP_ON_AC=balance_performance
CPU_HWP_ON_BAT=balance_power
# Set Intel P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires an Intel Core i processor with intel_pstate driver.
#CPU_MIN_PERF_ON_AC=0
#CPU_MAX_PERF_ON_AC=100
#CPU_MIN_PERF_ON_BAT=0
#CPU_MAX_PERF_ON_BAT=30
# Set the CPU "turbo boost" feature: 0=disable, 1=allow
# Requires an Intel Core i processor.
# Important:
# - This may conflict with your distribution's governor settings
# - A value of 1 does *not* activate boosting, it just allows it
#CPU_BOOST_ON_AC=1
#CPU_BOOST_ON_BAT=0
# Minimize number of used CPU cores/hyper-threads under light load conditions:
#   0=disable, 1=enable.
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
# Kernel NMI Watchdog:
#   0=disable (default, saves power), 1=enable (for kernel debugging only).
NMI_WATCHDOG=0
# Change CPU voltages aka "undervolting" - Kernel with PHC patch required.
# Frequency voltage pairs are written to:
#   /sys/devices/system/cpu/cpu0/cpufreq/phc_controls
# CAUTION: only use this, if you thoroughly understand what you are doing!
#PHC_CONTROLS="F:V F:V F:V F:V"
# Set CPU performance versus energy savings policy:
#   performance, balance-performance, default, balance-power, power.
# Requires kernel module msr and x86_energy_perf_policy from linux-tools.
ENERGY_PERF_POLICY_ON_AC=performance
ENERGY_PERF_POLICY_ON_BAT=power
# Disk devices; separate multiple devices with spaces (default: sda).
# Devices can be specified by disk ID also (lookup with: tlp diskid).
DISK_DEVICES="sda sdb"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
# Hard disk spin down timeout:
#   0:        spin down disabled
#   1..240:   timeouts from 5s to 20min (in units of 5s)
#   241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select IO scheduler for the disk devices: cfq, deadline, noop (Default: cfq).
# to keep the kernel default scheduler for the particular disk.
#DISK_IOSCHED="cfq cfq"
# AHCI link power management (ALPM) for disk devices:
#   min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) Kernel >= 4.15 required, then recommended.
# Multiple values separated with spaces are tried sequentially until success.
SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
SATA_LINKPWR_ON_BAT="med_power_with_dipm max_performance"
# Exclude host devices from AHCI link power management.
# Separate multiple hosts with spaces.
#SATA_LINKPWR_BLACKLIST="host1"
# Runtime Power Management for AHCI host and disks devices:
#   on=disable, auto=enable.
# EXPERIMENTAL ** WARNING: auto will most likely cause system lockups/data loss.
#AHCI_RUNTIME_PM_ON_AC=on
#AHCI_RUNTIME_PM_ON_BAT=on
# Seconds of inactivity before disk is suspended.
AHCI_RUNTIME_PM_TIMEOUT=15
# PCI Express Active State Power Management (PCIe ASPM):
#   default, performance, powersave.
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
# Radeon graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC; default = use hardware defaults.
RADEON_POWER_PROFILE_ON_AC=default
RADEON_POWER_PROFILE_ON_BAT=low
# Radeon dynamic power management method (DPM): battery, performance.
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
# Radeon DPM performance level: auto, low, high; auto is recommended.
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# WiFi power saving mode: on=enable, off=disable; not supported by all adapters.
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=on
# Disable wake on LAN: Y/N.
WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >=1 enables power saving (recommended: 1).
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
# Disable controller too (HDA only): Y/N.
SOUND_POWER_SAVE_CONTROLLER=Y
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
BAY_POWEROFF_ON_AC=0
BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off (default sr0).
BAY_DEVICE="sr0"
# Runtime Power Management for PCI(e) bus devices: on=disable, auto=enable.
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
# Exclude PCI(e) device adresses the following list from Runtime PM
# (separate with spaces). Use lspci to get the adresses (1st column).
#RUNTIME_PM_BLACKLIST="bb:dd.f 11:22.3 44:55.6"
# Exclude PCI(e) devices assigned to the listed drivers from Runtime PM.
# Default when unconfigured is "amdgpu nouveau nvidia radeon" which
# prevents accidential power-on of dGPU in hybrid graphics setups.
# Use "" to disable the feature completely.
# Separate multiple drivers with spaces.
RUNTIME_PM_DRIVER_BLACKLIST="amdgpu nouveau nvidia radeon pcieport"
# Set to 0 to disable, 1 to enable aggressive USB autosuspend feature.
USB_AUTOSUSPEND=0
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) are excluded automatically
#USB_BLACKLIST="1111:2222 3333:4444"
# Bluetooth devices are excluded from USB autosuspend:
#   0=do not exclude, 1=exclude.
USB_BLACKLIST_BTUSB=0
# Phone devices are excluded from USB autosuspend:
#   0=do not exclude, 1=exclude (enable charging).
USB_BLACKLIST_PHONE=0
# Printers are excluded from USB autosuspend:
USB_BLACKLIST_PRINTER=1
# WWAN devices are excluded from USB autosuspend:
USB_BLACKLIST_WWAN=1
# Include listed devices into USB autosuspend even if already excluded
# by the blacklists above (separate with spaces).
#USB_WHITELIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# (workaround for USB devices that cause shutdown problems).
#USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=1
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Hint: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
#   are ignored when this is enabled!
RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, wifi, wwan.
# Separate multiple devices with spaces.
#DEVICES_TO_DISABLE_ON_STARTUP="bluetooth wifi wwan"
# Radio devices to enable on startup: bluetooth, wifi, wwan.
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, wifi, wwan.
# (workaround for devices that are blocking shutdown).
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth wifi wwan"
# Radio devices to enable on shutdown: bluetooth, wifi, wwan.
# (to prevent other operating systems from missing radios).
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, wifi, wwan.
#DEVICES_TO_ENABLE_ON_AC="bluetooth wifi wwan"
# Radio devices to disable on battery: bluetooth, wifi, wwan.
#DEVICES_TO_DISABLE_ON_BAT="bluetooth wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
#   bluetooth, wifi, wwan.
#DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth wifi wwan"
# Battery charge thresholds (ThinkPad only, tp-smapi or acpi-call kernel module
# required). Charging starts when the remaining capacity falls below the
# START_CHARGE_THRESH value and stops when exceeding the STOP_CHARGE_THRESH value.
# Main / Internal battery (values in %)
#START_CHARGE_THRESH_BAT0=75
#STOP_CHARGE_THRESH_BAT0=80
# Ultrabay / Slice / Replaceable battery (values in %)
#START_CHARGE_THRESH_BAT1=75
#STOP_CHARGE_THRESH_BAT1=80
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
#RESTORE_THRESHOLDS_ON_BAT=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Hints:
# - Parameters are disabled by default, remove the leading # to enable them
# - Separate multiple radio devices with spaces
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
#DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
#5
Buttons;
Power = Shutdown
Sleep = do nothing
hibernate = Do nothing
Handle Display brightness keys = Enabled
Laptop Lid;
On battery = Switch off display
Plugged in = Switch off display
appearance;
status notifications = Disabled
System try icon = Enabled
also on the system tab,
On battery = Hibernate/Never
Plugged in = Suspend/Never
Critical power;
Cirt power level = 10
On crit power = Ask
#6
Any other options or some thing i am not thinking of?
I don’t think i have installed any thing else that could be altering the power settings.
Is there a way to check the config file for XFce and make sure it matches the Manjaro settings one?
#7
Edit file:
/etc/systemd/logind.conf
change line
#HandleLidSwitch=suspend
for:
HandleLidSwitch=ignore
After:
sudo service systemd-logind restart
You can read more about it if you read the manual
type i console : man 5 logind.conf
#8
That indeed did fix the issue thank you!
#9
Tremendous, that works for Budgie as well. Thanks!
closed #10
