Kobold
19 September 2023 17:12
1
Timeshift crash, while deleting snapshots in UI also see Log1 from posting2:
Failed to read file
systemd-coredump[3795]: [π‘] Process 3680 (timeshift-gtk) of user 0 dumped core.
Stack trace of thread 3793:
#0 0x00007fa59fc4b8b5 n/a (libc.so.6 + 0x4b8b5)
#1 0x000055871b0fe861 n/a (timeshift-gtk + 0x24861)
#2 0x000055871b0fedd0 n/a (timeshift-gtk + 0x24dd0)
#3 0x00007fa5a0f169a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#4 0x00007fa59fc8c9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007fa59fd10dfc n/a (libc.so.6 + 0x110dfc)
Stack trace of thread 3714:
#0 0x00007fa59fd0359f __poll (libc.so.6 + 0x10359f)
#1 0x00007fa5a0f43206 n/a (libglib-2.0.so.0 + 0xb8206)
#2 0x00007fa5a0ee3112 g_main_context_iteration (libglib-2.0.so.0 + 0x58112)
#3 0x00007fa5a0ee3162 n/a (libglib-2.0.so.0 + 0x58162)
#4 0x00007fa5a0f169a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#5 0x00007fa59fc8c9eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007fa59fd10dfc n/a (libc.so.6 + 0x110dfc)
Stack trace of thread 3739:
#0 0x00007fa59fcd5835 clock_nanosleep (libc.so.6 + 0xd5835)
#1 0x00007fa59fce7ef7 __nanosleep (libc.so.6 + 0xe7ef7)
#2 0x00007fa5a0f13319 g_usleep (libglib-2.0.so.0 + 0x88319)
#3 0x000055871b14188b n/a (timeshift-gtk + 0x6788b)
#4 0x000055871b0e8bc8 n/a (timeshift-gtk + 0xebc8)
#5 0x00007fa5a0f169a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#6 0x00007fa59fc8c9eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007fa59fd10dfc n/a (libc.so.6 + 0x110dfc)
Stack trace of thread 3680:
#3 0x000055871b11a07b n/a (timeshift-gtk + 0x4007b)
#4 0x000055871b11a47b n/a (timeshift-gtk + 0x4047b)
#5 0x00007fa5a0ee639e n/a (libglib-2.0.so.0 + 0x5b39e)
#6 0x00007fa5a0ee4f19 n/a (libglib-2.0.so.0 + 0x59f19)
#7 0x00007fa5a0f432b7 n/a (libglib-2.0.so.0 + 0xb82b7)
#8 0x00007fa5a0ee5b47 g_main_loop_run (libglib-2.0.so.0 + 0x5ab47)
#9 0x00007fa5a07ecf6f gtk_main (libgtk-3.so.0 + 0x1ecf6f)
#10 0x000055871b0e6ca8 n/a (timeshift-gtk + 0xcca8)
#11 0x00007fa59fc27cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007fa59fc27d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x000055871b0e7b45 n/a (timeshift-gtk + 0xdb45)
Stack trace of thread 3737:
#0 0x00007fa59fd0ed6d syscall (libc.so.6 + 0x10ed6d)
#1 0x00007fa5a0f3e247 g_cond_wait (libglib-2.0.so.0 + 0xb3247)
#2 0x00007fa5a0eb01b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007fa5a0f18a2e n/a (libglib-2.0.so.0 + 0x8da2e)
ββ Subject: Process 3680 (timeshift-gtk) dumped core
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ Documentation: man:core(5)
ββ
ββ Process 3680 (timeshift-gtk) crashed and dumped core.
ββ
ββ This usually indicates a programming error in the crashing program and
ββ should be reported to its vendor as a bug.
Edit:
I have this timeshift snapshots, saved on my External Drive. Should i format this Partition now
or is it okay to manually delete the few files?
The last snapshot that still showed up in timeshift wasnt selected for deleting btw.
Kobold
19 September 2023 17:52
2
Log1:
[18:56:03] Session log file: /var/log/timeshift/2023-09-19_18-56-03_gui.log
[18:56:03] Distribution: ManjaroLinux 23.0.2 (Uranos)
[18:56:03] DIST_ID: ManjaroLinux
[18:56:03] Main: check_dependencies()
[18:56:03] Main: add_default_exclude_entries()
[18:56:03] Main: add_default_exclude_entries(): exit
[18:56:03] update_partitions()
[18:56:03] Device: get_disk_space_using_df(): 6
[18:56:03] Device: get_mounted_filesystems_using_mtab(): 6
[18:56:03] Device: get_filesystems(): 18
[18:56:03] partition list updated
[18:56:03] detect_system_devices()
[18:56:03] / is mapped to device: /dev/sdc1, UUID=eb235aa7-d461-413d-800e-ea57385703fb
[18:56:03] /boot is mapped to device: /dev/sdc3, UUID=26eda82e-b403-49b8-abca-202167417020
[18:56:03] /home is mapped to device: /dev/sdc4, UUID=ada4a6a2-bd0a-4652-b386-7c637bba7ee9
[18:56:03] Searching subvolume for system at path: /
[18:56:03] Users: koboldx root
[18:56:03] Encrypted home users:
[18:56:03] Encrypted home dirs:
[18:56:03] Encrypted private dirs:
[18:56:03] Main: load_app_config()
[18:56:03] App config loaded: /etc/timeshift/timeshift.json
[18:56:03] IconManager: init()
[18:56:03] found images directory: /usr/share/timeshift/images
[18:56:03] Main(): ok
[18:56:03] Main: initialize_repo()
[18:56:03] backup_uuid=8a779c83-ea89-4c23-acdb-8524194cd97f
[18:56:03] backup_parent_uuid=
[18:56:03] Setting snapshot device from config file
[18:56:03] repo: creating from uuid
[18:56:03] SnapshotRepo: from_uuid(): RSYNC
[18:56:03] uuid=8a779c83-ea89-4c23-acdb-8524194cd97f
[18:56:03] SnapshotRepo: init_from_device()
[18:56:03]
[18:56:03] SnapshotRepo: unlock_and_mount_devices()
[18:56:03] device=/dev/sdd1
[18:56:03] SnapshotRepo: unlock_and_mount_device()
[18:56:03] ------------------
[18:56:03] arg=8a779c83-ea89-4c23-acdb-8524194cd97f, device=/dev/sdd1
[18:56:03] /run/media/koboldx/Backup PC
[18:56:03] Mounted '/dev/sdd1' at '/run/timeshift/3680/backup'
[18:56:03] SnapshotRepo: load_snapshots()
[18:56:03] loading snapshots from '/run/timeshift/3680/backup/timeshift/snapshots': 5 found
[18:56:03] SnapshotRepo: unlock_and_mount_device(): exit
[18:56:03] Selected snapshot device: /dev/sdd1
[18:56:03] Free space: 419,3 GB
[18:56:03] SnapshotRepo: check_status()
[18:56:03] SnapshotRepo: available()
[18:56:03] is_available: ok
[18:56:03] SnapshotRepo: has_snapshots()
[18:56:03] SnapshotRepo: has_space() - 0 required (0 B)
[18:56:03] Device: get_disk_space_using_df(): 1
[18:56:03] Snapshot device: '/dev/sdd1'
[18:56:03] Snapshot location: /run/timeshift/3680/backup
[18:56:03] OK
[18:56:03] 5 snapshots, 419,3 GB free
[18:56:03] Status: HAS_SNAPSHOTS_HAS_SPACE
[18:56:03]
[18:56:03] SnapshotRepo: check_status(): exit
[18:56:03] SnapshotRepo: init_from_device(): exit
[18:56:03] SnapshotRepo: from_uuid(): exit
[18:56:03] Main: initialize_repo(): exit
[18:56:03] MainWindow: MainWindow()
[18:56:03] SnapshotListBox: SnapshotListBox()
[18:56:03] SnapshotListBox: SnapshotListBox(): exit
[18:56:03] MainWindow: MainWindow(): exit
[18:56:04] MainWindow(): init_delayed()
[18:56:04] SnapshotRepo: available()
[18:56:04] is_available: ok
[18:56:04] SnapshotRepo: load_snapshots()
[18:56:04] loading snapshots from '/run/timeshift/3680/backup/timeshift/snapshots': 5 found
[18:56:04] SnapshotRepo: check_status()
[18:56:04] SnapshotRepo: has_snapshots()
[18:56:04] SnapshotRepo: has_space() - 0 required (0 B)
[18:56:04] Device: get_disk_space_using_df(): 1
[18:56:04] Snapshot device: '/dev/sdd1'
[18:56:04] Snapshot location: /run/timeshift/3680/backup
[18:56:04] OK
[18:56:04] 5 snapshots, 419,3 GB free
[18:56:04] Status: HAS_SNAPSHOTS_HAS_SPACE
[18:56:04]
[18:56:04] SnapshotRepo: check_status(): exit
[18:56:04] MainWindow(): init_delayed(): exit
[18:57:32] main window: delete_selected()
[18:57:32] SnapshotRepo: available()
[18:57:32] is_available: ok
[18:57:32] SnapshotRepo: has_snapshots()
[18:57:32] main window: delete_selected(): count=4
[18:57:32] DeleteWindow: DeleteWindow()
[18:57:32] SnapshotListBox: SnapshotListBox()
[18:57:32] SnapshotListBox: SnapshotListBox(): exit
[18:57:32] DeleteBox: DeleteBox()
[18:57:32] DeleteBox: DeleteBox(): exit
[18:57:32] DeleteFinishBox: DeleteFinishBox()
[18:57:32] DeleteFinishBox: DeleteFinishBox(): exit
[18:57:32] DeleteWindow: DeleteWindow(): exit
[18:57:32]
[18:57:32] page: 1
[18:57:32] DeleteBox: delete_snapshots()
[18:57:32] Main: delete_begin()
[18:57:32] delete_begin(): thread created
[18:57:32] Main: delete_begin(): exit
[18:57:32] delete_thread()
[18:57:33] ------------------------------------------------------------------------------
[18:57:33] Removing '2023-08-14_04-57-43'...
[18:57:33] RsyncTask:execute()
[18:57:33] rm -rfv '/run/timeshift/3680/backup/timeshift/snapshots/2023-08-14_04-57-43/'
[18:57:33] RsyncTask:prepare(): saved: /tmp/JsLLxFWT/2023-09-19_18-56-04/script.sh
[18:57:33] AsyncTask: child_pid: 3743
[18:58:57] AsyncTask: finish(): enter
[18:58:57] exit_code: 0
[18:58:57] Removed '2023-08-14_04-57-43'
[18:58:57] ------------------------------------------------------------------------------
[18:58:57] Removing '2023-09-11_06-06-22'...
[18:58:57] RsyncTask:execute()
[18:58:57] rm -rfv '/run/timeshift/3680/backup/timeshift/snapshots/2023-09-11_06-06-22/'
[18:58:57] RsyncTask:prepare(): saved: /tmp/JsLLxFWT/2023-09-19_18-56-04/script.sh
[18:58:57] AsyncTask: child_pid: 3759
[18:59:18] AsyncTask: finish(): enter
[18:59:18] exit_code: 0
[18:59:18] Removed '2023-09-11_06-06-22'
[18:59:18] ------------------------------------------------------------------------------
[18:59:18] Removing '2023-09-14_03-55-00'...
[18:59:18] RsyncTask:execute()
[18:59:18] rm -rfv '/run/timeshift/3680/backup/timeshift/snapshots/2023-09-14_03-55-00/'
[18:59:18] RsyncTask:prepare(): saved: /tmp/JsLLxFWT/2023-09-19_18-56-04/script.sh
[18:59:18] AsyncTask: child_pid: 3775
[18:59:36] AsyncTask: finish(): enter
[18:59:36] exit_code: 0
[18:59:37] Removed '2023-09-14_03-55-00'
[18:59:37] ------------------------------------------------------------------------------
[18:59:37] Removing '2023-09-17_04-46-16'...
[18:59:37] RsyncTask:execute()
[18:59:37] rm -rfv '/run/timeshift/3680/backup/timeshift/snapshots/2023-09-17_04-46-16/'
[18:59:37] RsyncTask:prepare(): saved: /tmp/JsLLxFWT/2023-09-19_18-56-04/script.sh
[18:59:37] AsyncTask: child_pid: 3789
[18:59:57] AsyncTask: finish(): enter
[18:59:57] E: Failed to get attributes of file β/tmp/JsLLxFWT/2023-09-19_18-56-04/statusβ: fstat() failed: Bad file descriptor
[18:59:57] exit_code: 0
[18:59:57] E: Failed to read file: /tmp/JsLLxFWT/2023-09-19_18-56-04/status
Log2 ([19:09:13] [Warning] Deleted invalid lock):
[19:09:13] Session log file: /var/log/timeshift/2023-09-19_19-09-13_gui.log
[19:09:13] Distribution: ManjaroLinux 23.0.2 (Uranos)
[19:09:13] DIST_ID: ManjaroLinux
[19:09:13] Main: check_dependencies()
[19:09:13] Main: add_default_exclude_entries()
[19:09:13] Main: add_default_exclude_entries(): exit
[19:09:13] update_partitions()
[19:09:13] Device: get_disk_space_using_df(): 6
[19:09:13] Device: get_mounted_filesystems_using_mtab(): 6
[19:09:13] Device: get_filesystems(): 18
[19:09:13] partition list updated
[19:09:13] detect_system_devices()
[19:09:13] / is mapped to device: /dev/sdc1, UUID=eb235aa7-d461-413d-800e-ea57385703fb
[19:09:13] /boot is mapped to device: /dev/sdc3, UUID=26eda82e-b403-49b8-abca-202167417020
[19:09:13] /home is mapped to device: /dev/sdc4, UUID=ada4a6a2-bd0a-4652-b386-7c637bba7ee9
[19:09:13] Searching subvolume for system at path: /
[19:09:13] Users: koboldx root
[19:09:13] Encrypted home users:
[19:09:13] Encrypted home dirs:
[19:09:13] Encrypted private dirs:
[19:09:13] Main: load_app_config()
[19:09:13] App config loaded: /etc/timeshift/timeshift.json
[19:09:13] IconManager: init()
[19:09:13] found images directory: /usr/share/timeshift/images
[19:09:13] Main(): ok
[19:09:13] Main: initialize_repo()
[19:09:13] backup_uuid=8a779c83-ea89-4c23-acdb-8524194cd97f
[19:09:13] backup_parent_uuid=
[19:09:13] Setting snapshot device from config file
[19:09:13] repo: creating from uuid
[19:09:13] SnapshotRepo: from_uuid(): RSYNC
[19:09:13] uuid=8a779c83-ea89-4c23-acdb-8524194cd97f
[19:09:13] SnapshotRepo: init_from_device()
[19:09:13]
[19:09:13] SnapshotRepo: unlock_and_mount_devices()
[19:09:13] device=/dev/sdd1
[19:09:13] SnapshotRepo: unlock_and_mount_device()
[19:09:13] ------------------
[19:09:13] arg=8a779c83-ea89-4c23-acdb-8524194cd97f, device=/dev/sdd1
[19:09:13] /run/timeshift/3680/backup
[19:09:13] /run/media/koboldx/Backup PC
[19:09:13] Mounted '/dev/sdd1' at '/run/timeshift/3832/backup'
[19:09:13] SnapshotRepo: load_snapshots()
[19:09:13] loading snapshots from '/run/timeshift/3832/backup/timeshift/snapshots': 1 found
[19:09:13] SnapshotRepo: unlock_and_mount_device(): exit
[19:09:13] Selected snapshot device: /dev/sdd1
[19:09:13] Free space: 438,0 GB
[19:09:13] SnapshotRepo: check_status()
[19:09:13] SnapshotRepo: available()
[19:09:13] is_available: ok
[19:09:13] SnapshotRepo: has_snapshots()
[19:09:13] SnapshotRepo: has_space() - 0 required (0 B)
[19:09:13] Device: get_disk_space_using_df(): 1
[19:09:13] Snapshot device: '/dev/sdd1'
[19:09:13] Snapshot location: /run/timeshift/3832/backup
[19:09:13] OK
[19:09:13] 1 snapshots, 438,0 GB free
[19:09:13] Status: HAS_SNAPSHOTS_HAS_SPACE
[19:09:13]
[19:09:13] SnapshotRepo: check_status(): exit
[19:09:13] SnapshotRepo: init_from_device(): exit
[19:09:13] SnapshotRepo: from_uuid(): exit
[19:09:13] Main: initialize_repo(): exit
[19:09:13] MainWindow: MainWindow()
[19:09:13] SnapshotListBox: SnapshotListBox()
[19:09:13] SnapshotListBox: SnapshotListBox(): exit
[19:09:13] MainWindow: MainWindow(): exit
[19:09:13] MainWindow(): init_delayed()
[19:09:13] OK
[19:09:13]
[19:09:13] MainWindow(): init_delayed(): exit
[19:40:36] MainWindow: btn_settings_clicked()
[19:40:36] SettingsWindow: SettingsWindow()
[19:40:36] SnapshotBackendBox: SnapshotBackendBox()
[19:40:36] SnapshotBackendBox: SnapshotBackendBox(): exit
[19:40:36] BackupDeviceBox: BackupDeviceBox()
[19:40:36] BackupDeviceBox: BackupDeviceBox(): exit
[19:40:36] ScheduleBox: ScheduleBox()
[19:40:36] ScheduleBox: ScheduleBox(): exit
[19:40:36] ExcludeBox: ExcludeBox()
[19:40:36] treeview_add_item(): + /home/koboldx/**
[19:40:36] treeview_add_item(): + /root/**
[19:40:36] treeview_add_item(): + /home/koboldx/.var/app/info.beyondallreason.bar/***
[19:40:36] ExcludeBox: ExcludeBox(): exit
[19:40:36] UsersBox: UsersBox()
[19:40:36] UsersBox: UsersBox(): exit
[19:40:36] MiscBox: MiscBox()
[19:40:36] MiscBox: init_date_format_option()
[19:40:36] MiscBox: init_date_format_option(): exit
[19:40:36] MiscBox: MiscBox(): exit
[19:40:36] SettingsWindow: SettingsWindow(): exit
[19:40:36] update_partitions()
[19:40:36] Device: get_disk_space_using_df(): 6
[19:40:36] Device: get_mounted_filesystems_using_mtab(): 6
[19:40:36] Device: get_filesystems(): 18
[19:40:36] partition list updated
[19:40:36] SnapshotRepo: check_status()
[19:40:36] SnapshotRepo: available()
[19:40:36] is_available: ok
[19:40:36] SnapshotRepo: has_snapshots()
[19:40:36] SnapshotRepo: has_space() - 0 required (0 B)
[19:40:36] Device: get_disk_space_using_df(): 1
[19:40:36] Snapshot device: '/dev/sdd1'
[19:40:36] Snapshot location: /run/timeshift/3832/backup
[19:40:36] OK
[19:40:36] 1 snapshots, 438,0 GB free
[19:40:36] Status: HAS_SNAPSHOTS_HAS_SPACE
[19:40:36]
[19:40:36] SnapshotRepo: check_status(): exit
[19:41:40] removed item: + /home/koboldx/.var/app/info.beyondallreason.bar/***
[19:41:40] treeview_add_item(): + /home/koboldx/**
[19:41:40] treeview_add_item(): + /root/**
[19:41:40] treeview_add_item(): + /home/koboldx/.var/app/info.beyondallreason.bar
[19:41:40] save_changes(): exclude_list_user:
[19:41:40] + /home/koboldx/**
[19:41:40] + /root/**
[19:41:40] + /home/koboldx/.var/app/info.beyondallreason.bar
[19:41:40]
[19:41:52] removed item: + /home/koboldx/.var/app/info.beyondallreason.bar
[19:41:52] treeview_add_item(): + /home/koboldx/**
[19:41:52] treeview_add_item(): + /root/**
[19:41:52] save_changes(): exclude_list_user:
[19:41:52] + /home/koboldx/**
[19:41:52] + /root/**
[19:41:52]
[19:42:02] save_changes(): exclude_list_user:
[19:42:02] + /home/koboldx/**
[19:42:02] + /root/**
[19:42:02]
[19:42:02] treeview_add_item(): + /home/koboldx/**
[19:42:02] treeview_add_item(): + /root/**
[19:42:02] crontab -l
[19:42:02] Failed to read cron tab
[19:42:02] Main: save_app_config()
[19:42:02] SnapshotRepo: available()
[19:42:02] is_available: ok
[19:42:02] SnapshotRepo: has_snapshots()
[19:42:02] App config saved: /etc/timeshift/timeshift.json
[19:42:02] SnapshotRepo: load_snapshots()
[19:42:02] loading snapshots from '/run/timeshift/3832/backup/timeshift/snapshots': 1 found
[19:42:02] SnapshotRepo: check_status()
[19:42:02] SnapshotRepo: has_space() - 0 required (0 B)
[19:42:02] Device: get_disk_space_using_df(): 1
[19:42:02] Snapshot device: '/dev/sdd1'
[19:42:02] Snapshot location: /run/timeshift/3832/backup
[19:42:02] OK
[19:42:02] 1 snapshots, 438,0 GB free
[19:42:02] Status: HAS_SNAPSHOTS_HAS_SPACE
[19:42:02]
[19:42:02] SnapshotRepo: check_status(): exit
Edit:
I manually deleted this 4 symlink (or what ever that was stored in there) in /run/timeshift/5236/backup/timeshift/snapshots-ondemand/
because of the UI crash i think they got somehow corrupted.
The Warning message also vanished now that was showing up in Log2.
But im still worrie that my future backups maybe could damaged from the unsuccessfull removing.
