Hi Manjaro,
I’ve got a small question regarding my second monitor in i3wm. From time to time I have to change the name of my second monitor. Running “xrandr” confirms the monitor’s name has been changed.
How do I make a certain monitor’ name “fixed”. Is this possible? How does this mechanism work?
Example 1:
exec xrandr --output HDMI-A-1-1 --auto --left-of eDP-1
Example 2:
exec xrandr --output HDMI-1-2 --auto --left-of eDP-1
Thank you in advance
Hi @Deville-ee,
AFAIK it’ll only change if it has been connected to a different port. So, check that.
Edit:
In more than a year, mine’s not changed:
$ xrandr
Screen 0: minimum 8 x 8, current 5120 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 673mm x 284mm
2560x1080 60.00*+
1920x1080 60.00 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 connected 2560x1080+2560+0 (normal left inverted right x axis y axis) 673mm x 284mm
2560x1080 60.00*+
1680x1050 59.95
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
Hi @Mirdarthos
Ty for your response,
I’ve got the same setup throughout the i3wm installation with only one hdmi port present on my laptop. My setup works fine for about a month or so but it is very irregular.
The only 2 things I can imagine are: Sometimes I work without the extra monitor and sometimes I update my system.
Well, then I recommend not updating your system with the extra monitor disconnected.
Little update,
I needed to switch again to the other monitor’s name today. There was no update, only a full working day without this second monitor attached to the HDMI port.
