Force reinstall of packages or check for inconsistency
Hi there,
during the last Manjaro update (couple of days ago, quite a lot of packages updated) I unfortunately had a file system full. Root cause found and solved (thanks to Manjaro community :smiley:), and now system boots again.
But, I see a few coredumps I did not have before, including brave browser. For brave was an easy solution, I removed and reinstalled it.
In log file I have “Systemd-coredum” related to: org.gnome.Nauti, evolution-sourc, evolution-alarm. After booting, logging in DE and opening logs I see ( I add the last line of each stack trace):
systemd-coredum: Process 3304 (org.gnome.Nauti) of user 1002 dumped core
#0  0x00007f9861b03c2a n/a (ld-linux-x86-64.so.2 + 0x22c2a
systemd-coredum: Process 3110 (evolution-sourc) of user 1002 dumped core
#0  0x00007f98610a5ebe n/a (libc.so.6 + 0x8bebe)
systemd-coredum: Process 2833 (evolution-sourc) of user 1002 dumped core
#0  0x00007f086211dc2a n/a (ld-linux-x86-64.so.2 + 0x22c2a)
systemd-coredum: Process 2884 (evolution-alarm) of user 1002 dumped core
#0  0x00007faae7ff6c2a n/a (ld-linux-x86-64.so.2 + 0x22c2a)
systemd-coredum: Process 1494 (evolution-sourc) of user 1003 dumped core
#0  0x00007f9061b40c2a n/a (ld-linux-x86-64.so.2 + 0x22c2a)
systemd-coredum: Process 1261 (evolution-sourc) of user 1003 dumped core
#0  0x00007f8f61fe3c2a n/a (ld-linux-x86-64.so.2 + 0x22c2a)
I recall I saw during the update process a few messages on screen about truncated libraries … and above I see a lot of ld-linux* and libc*
Not having a backup (I know I know … :roll_eyes:), is there a way to force a reinstall process of packages? Something along the line “force reinstall all the package related to my installation that have been published in the last 7 days”…
Many thanks!
You’ll have to check pacman.log and manually reinstall whatever you updated in past 7 days.
You can also install pacutils and see what you get running
sudo paccheck --list-broken --files
Search for missing files first:
sudo pacman -Qk 2>/dev/null | grep -v ' 0 missing files'
… ooook so mixed news …
  1. the above paccheck and ‘missing files’ both give no outcome : good!
  2. I checked the pacman.log and I’ve about 30 lines like
    '[ALPM-SCRIPTLET] ldconfig: file /usr/lib/libwebkit2gtk-4.1.so is truncated'. I guess BAD :frowning:
Should I reinstall libwebkit2gtk? Which package contains libwebkit2gtk?
Thx! :slight_smile:
    ~  pamac search -f /usr/lib/libwebkit2gtk-4.1.so                                                          ✔
/usr/lib/libwebkit2gtk-4.1.so is owned by webkit2gtk-4.1
/usr/lib/libwebkit2gtk-4.1.so.0 is owned by webkit2gtk-4.1
/usr/lib/libwebkit2gtk-4.1.so.0.12.8 is owned by webkit2gtk-4.1
:man_shrugging:
May be easier and faster reinstalling all packages, to be sure they are all ok:
https://wiki.archlinux.org/title/Pacman/Tips_and_tricks#Reinstalling_all_packages
pacman -Fyx path/to/file
… and @megavolt win again the context :grinning:
I just force reinstall webkit2gtk and the systemd-coredum gone away.
Thanks to @Arrababiski and @zbe for valuable hints, I’ll come back to this message when (and not if) I’ll mess up things again :slight_smile:
Cheers!
