hexchat spellcheck isn’t working when i look into preferences spell check is checked and dictionary in use is en_US but when I spell something incorrectly nothing happens
If you have the hunspell-en-US
package installed, make sure you restart the client so is starts using it. Then make sure to enable spelling under Settings ‣ Preferences ‣ Interface ‣ Input box.
Alternatively you can use LANG=en_US hexchat
to launch it, or add that to the Exec=
line in the desktop file.
Thanks installing hunspell-en_US did the trick
