[SOLVED] Hauppage 2250 firmware fail to upload in Mythtv
Moving a Mythtv from Ubuntu to Manjaro, backend requires drivers.https://www.linuxtv.org/wiki/index.php/Hauppauge_WinTV-HVR-2200
These are the same that worked in Ubuntu (for over 5 years), but when loaded into /lib/firmware they fail to load, from journalctl -b 0
Apr 30 18:16:14 KISE-055 kernel: saa7164_downloadfirmware() no first image
Apr 30 18:16:14 KISE-055 kernel: saa7164_downloadfirmware() Waiting for firmware upload (NXP7164-2010-03-10.1.fw)
Apr 30 18:16:14 KISE-055 systemd-vconsole-setup[308]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
Apr 30 18:16:14 KISE-055 systemd-vconsole-setup[308]: Fonts will not be copied to remaining consoles
Apr 30 18:16:14 KISE-055 kernel: nouveau 0000:01:00.0: bios: version 70.15.27.00.02
Apr 30 18:16:14 KISE-055 kernel: nouveau 0000:01:00.0: fb: 512 MiB GDDR5
Apr 30 18:16:14 KISE-055 kernel: saa7164 0000:02:00.0: Direct firmware load for NXP7164-2010-03-10.1.fw failed with error -2
Apr 30 18:16:14 KISE-055 kernel: saa7164_downloadfirmware() Upload failed. (file not found?)
Apr 30 18:16:14 KISE-055 kernel: Failed to boot firmware, no features registered
Trying the alternative directory /lib/firmware/4.19.36-1-MANJARO/ also failed.
From the wiki you posted, for that error, you have to:
You might have to:
sudo cp v4l-saa7164-1.0.2.fw /lib/firmware/4.19.36-1-MANJARO
sudo cp v4l-saa7164-1.0.3.fw /lib/firmware/4.19.36-1-MANJARO
sudo cp dvb-fe-tda10048-1.0.fw /lib/firmware/4.19.36-1-MANJARO
but/and also
sudo cp NXP7164-2010-03-10.1.fw /lib/firmware
Worked right off the bat..!
It was NXP7164-2010-03-10.1.fw that was missing.
Thanks..!
