[Solved] Grub loader failed to install efi
This is a BLANK SSD drive.
Boost.Python error in job "bootloader".
Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force' returned non-zero exit status 1.
Installing for x86_64-efi platform. Could not add entry to BootOrder: No space left on device grub-install: error: efibootmgr failed to register the boot entry: No such device or address.
Traceback:
File "/usr/lib/calamares/modules/bootloader/main.py", line 457, in run
prepare_bootloader(fw_type)
File "/usr/lib/calamares/modules/bootloader/main.py", line 429, in prepare_bootloader
install_grub(efi_directory, fw_type)
File "/usr/lib/calamares/modules/bootloader/main.py", line 293, in install_grub
check_target_env_call([libcalamares.job.configuration["grubInstall"],
File "", line 6, in
Welcome at the forum, @DouglasEKnapp,
Maybe you have missed something, I would recommend to restudy the installation guide, step by step.
https://wiki.manjaro.org/index.php?title=Main_Page#Installation
can you
boot on usb manjaro ( not your disk )
open a terminal
and returns
inxi -Fxxxza
sudo parted -l
I am running from a usb drive live kde install
inxi -Fxxxza
  Host: manjaro Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us
  tz=UTC driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=0
  misobasedir=manjaro misolabel=MJRO1815 quiet systemd.show_status=1
  apparmor=1 security=apparmor
  Desktop: KDE Plasma 5.17.4 tk: Qt 5.14.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop System: MSI product: MS-7850 v: 1.0 serial: <filter>
  Mobo: MSI model: Z87-G41 PC Mate(MS-7850) v: 1.0 serial: <filter>
  UEFI: American Megatrends v: 1.8 date: 07/21/2014
  Device-1: hidpp_battery_0
  model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
  status: Discharging
  Topology: Quad Core model: Intel Core i7-4770 bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 27
  L2 cache: 8192 KiB
  bogomips: 54416
  Speed: 1400 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1400
  2: 1400 3: 1401 4: 1401 5: 1400 6: 1402 7: 1402 8: 1402
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
  SMT vulnerable
  Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: PNY driver: nvidia
  v: 418.113 bus ID: 01:00.0 chip ID: 10de:1b82
  Display: x11 server: X.Org 1.20.6 driver: nvidia compositor: kwin_x11
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 418.113
  direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:8c20
  Device-2: NVIDIA GP104 High Definition Audio vendor: PNY
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
  Device-3: Creative Labs CA0110 [Sound Blaster X-Fi Xtreme Audio]
  driver: snd_hda_intel v: kernel bus ID: 07:00.0 chip ID: 1102:0009
  Sound Server: ALSA v: k5.4.6-2-MANJARO
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000
  bus ID: 03:00.0 chip ID: 10ec:8168
  Local Storage: total: 126.73 GiB used: 7.75 GiB (6.1%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDHII120G size: 111.79 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 00RL scheme: GPT
  ID-2: /dev/sdc type: USB model: USB 2.0 Flash Disk size: 14.94 GiB
  block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100
  scheme: MBR
  ID-1: / raw size: N/A size: 11.69 GiB used: 1008.8 MiB (8.4%)
  fs: overlay source: ERR-102
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 36 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
  Processes: 260 Uptime: 2h 15m Memory: 15.58 GiB used: 2.08 GiB (13.4%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
  running in: konsole inxi: 3.0.37
sudo parted -l
Model: ATA SanDisk SDSSDHII (scsi)
Disk /dev/sda: 120GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 102GB 101GB ext4
3 102GB 120GB 18.4GB linux-swap(v1) swap
Model: USB 2.0 Flash Disk (scsi)
Disk /dev/sdc: 16.0GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2895MB 2899MB 4194kB primary esp
ok , missing parittion /boot/efi type vfat on install
you will have to reinstall
on bios for boot USB stick
choose only <partition 1> ( for EFI )
GPT is ok
redo partitions ( 2 is the minimum )
/boot/efi type fat32 100Mo with flag boot & esp
you can always check before install
open a terminal and check Bios or EFI
inxi -Fxxxza
efibootmgr -v
How can this be? Live boot disk and a blank SDD drive? I did nothing to cause this. It is just a fresh install with only newbie options picked.
I tried everything. Could it be that the USB live drive does not have the memory? I don't get this problem. the drive is partitioned, there is room there. I don't get why it can't just install the system.
Also RTFM will not help. (not to you Stephane!)
PS I am no pro but 20 years with Linux.
See. this first post
If installing efi loader fails it is usual one of two reasons
  1. The system had compatibility mode enabled in the firmware - which usually results in a BIOS MBR boot.
  2. Wrong filesystem for $esp (EFI System Partition) partition.
Ensure your system boots using EFi by disabling CSM in firmware.
you have to check carefully all options in bios
  • no fast boot , no legacy , no csm , secure boot disable and disk in AHCI , EFI only or others
  • maybe keep USB mass storage on
If it were in the bios would not the thumb drive booting fail? It is the same version (current) of Manjaro?
check carefully on bios ( you have the choice for boot in bios )
< EFI >< USB vendor name >< partition 1 > --> boot EFI for manjaro
Have you tried this?
Gohlip, it was looking good and I am in a running system but it says:
Error: target not found: grub-vanilla
I did pacman -Sy and tried again but still no go. Ideas?
Thanks!
PS I tried the graphical updater and installer but it says that my program versions installed are newer that what is in the database. example ver 10 installed and version 9 in the database.??????
Do at terminal
sudo pacman-mirrors -f5
sudo pacman -Syu
sudo pacman -Ss grub-vanilla
Found it? Then
sudo pacman -S grub-vanilla
Continue the rest of commands in terminal.
it replaced grub with grub-vanilla and then . . .
sudo grub-install /dev/sda
Continue with rest of commands, nevertheless.
sudo cp /boot/grub/x86_64-efi/core.efi /boot/efi/EFI/boot/bootx64.efi
cp: cannot create regular file '/boot/efi/EFI/boot/bootx64.efi': No such file or directory
[douglas@Frog-pc ~]$ sudo mkdir /boot/efi/efi/boot
[douglas@Frog-pc ~]$ sudo cp /boot/grub/x86_64-efi/core.efi /boot/efi/EFI/boot/bootx64.efi
[douglas@Frog-pc ~]$ sudo efibootmgr -c -d /dev/sda -p 1 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
efibootmgr: ** Warning ** : Boot0000 has same label manjaro
Could not prepare Boot variable: No space left on device
Reboot, anyway.
No. Shutdown. Then restart. That's for your firmware to clear some space on your bios (uefi) memory.
Then, if you still cannot boot.Do again the commands.
But before doing the commands, either at livecd OS or at booted up OS, clear some efiboot-entries with
sudo efibootmgr -b xxxx -B
Remove the entries you know are obsolete, not the ones that you need.
Check that with 'efibootmgr' to see which ones you can remove.
Repeat the 'xxxx' if there are several entries to remove.
Be aware that even when removing efiboot-entries, you may still get the error message
"Could not prepare Boot variable: No space left on device". Shutdown and repeat.
Your firmware memory is tiny.
After rebooting it is working with the one exception of an error, something about the hibernation drive is not correct.
Thanks again for your help. Without it I think I would have had to switch to a new distro which is sad because other than this install nightmare (the worst I have ever found in 20 years of Linux) I love Manjaro!
